ADSavarese8ol' schoolNew Member Introduct...New member from FL
ADSavarese8GorillaNew Member Introduct...New member from FL
ADSavarese8Marc HNew Member Introduct...New member from FL
ADSavarese8ADSavareseNew Member Introduct...New member from FL
ADSavarese8Phu CatNew Member Introduct...New member from FL
ADSavarese8trike ladyNew Member Introduct...New member from FL
ADSavarese8Uncle FesterNew Member Introduct...New member from FL
ADSavarese8rhino 2New Member Introduct...New member from FL
Results 1 to 5 of 5
Thread: Question about rear tires
    Aug 2009
    Riverview, Michigan
    Default Question about rear tires
    I have a 2006 Goldwing trike. I have 26000 miles on the trike. Next year the rear tires will be 7 years old. I am worried about dry rot Has anyone had any problems with rear tires getting dry rot
    Lost In The 50's rmrc51's Avatar
    Feb 2009
    Palmyra, Virginia
    Post Re: Question about rear tires
    Do you see any indication of cracking on the sidewalls? Another observation I use to look for is the rubber itself becoming hard to the touch. I have a 57 Chevy that doesn't get as much road time as it should and those tires have been on the car for at least 9 years. They're still pliable and show no signs of cracking. I'm sure others will also chime in with more information.
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    Default Re: Question about rear tires
    That's a little longer than I like to run Tires, especially if They aren't used every day....I would keep a close eye for knots or bulges, even slight ones.....
    80+ Posts 3FOR2's Avatar
    Jun 2013
    Moyock, NC. USA
    Personally, I'd replace them. Just google age of tires, and check the results... here's a couple of interesting ones...
    Tire Safety |
    How Old - and Dangerous - Are Your Tires?
    It's becoming more widely known that older tires, even if they look ok, can be dangerous...
    Safe Wheels? States Launch Crackdown on Sale of Aged Tires - ABC News
    Hope this helps. $300-$400 vs ???
    Apr 2010
    Yep, the newer Tires now, are less likely to get the "age cracks" than older versions were..........New Tires ALWAYS feel Great on ANYTHING though.....
  1. Rear Tires
    By sprinkman in forum Harley Trike Conversions
    Last Post: 05-13-2013, 10:15 AM
  2. rear tires
    By JUSFUN in forum Honda Trikes
    Last Post: 01-28-2013, 09:46 AM
  3. Rear tires???????????????
    By americanbadass in forum Tires, Wheels, Brakes, Front End
    Last Post: 04-15-2012, 01:49 AM
  4. Hd rear tires
    By Mr Bulldog in forum Harley Trike Conversions
    Last Post: 11-27-2011, 06:47 PM
  5. rear tires
    By brokebikerbill in forum VW Powered Trikes
    Last Post: 09-03-2011, 11:01 AM
