Likes Likes:  1
Results 1 to 3 of 3
Thread: New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    20+ Posts
    Jun 2012
    St. Augustine Florida, USA
    Default New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    For the hydraulic clutch set up, I looked at using the &quot;specialty&quot; type long hydraulic cylinder available from sand rail parts suppliers. When I added up the brackets, slave and master cylinder, and flex hose installation prices, it was almost $280.00. After some research, I ended up using the clutch master cylinder and slave cylinder from a 1977 Toyota pick up truck. The slave cylider travel adjustment rod is already threaded and has half-moon and jam nuts which fit the clutch arm perfectly with plenty of travel. I used a rear brake hose for the same vehicle for the flexible connection point. Total investment was $49.75 from Advanced Auto Parts. I made the mounting bracket from 2 pieces of 1 inch wide X 3/8&quot; inch flat bar welded perpendicular to each other. Drilled 2 holes 5/16&quot; diameter to mount the slave cylinder to one side of the bracket and drilled a 3/8&quot; hole to install the whole set up with a bell housing bolt. <br />
    <br />
    I have also attached a brake &amp; clutch pedal fabrication drawing which I used for my trike. They work great.
    Hope this helps another &quot;trike jockey&quot;!
    20+ Posts
    Jun 2012
    Default Re: New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    I forgot to note that the clutch slave cylinder pushes the clutch arm because it's mounted on the engine side of the bell housing.
    20+ Posts
    Jun 2012
    Also the brake and clutch pedal fabrication drawing came the from Triker Ox website.
  1. brake==clutch levers
    By meredog in forum Honda Trikes
    Last Post: 07-13-2013, 06:24 AM
  2. Over size brake pedal
    By felixpirozzi in forum Honda Trikes
    Last Post: 12-08-2011, 09:54 AM
  3. Replies: 1
    Last Post: 09-18-2011, 01:23 PM
  4. Brake Pedal Extension
    By rmrc51 in forum Honda Trikes
    Last Post: 10-11-2010, 12:44 PM
  5. moving a brake pedal plus other
    By acmeactor in forum General Discussion
    Last Post: 11-05-2009, 04:55 PM
