Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
Thread: Question about heated gear
  1. #21
    Default Re: Question about heated gear
    Heated gear is the way i ride in the winter, Two things about it, You must remember to unplug when you dismount, And in case of a malfunction i.e. Blown fuse, bike stops running, Or forgetting to unplug [done that] you should have extra cloths with you!
  2. #22
    TOI - Idaho BinIdaho's Avatar
    May 2009
    Caldwell, Idaho
    I have the HD heated jacket liner and gloves. So far, I haven't had to use them but after a ride from Caldwell to Boise in 28* weather yesterday, decided the heated gear has to be worn. Stopped at the local HD shop and ordered the heated pants today.
    Barbara
    2020 HD Tri-Glide
    River Rock Gray/Black Accents
  3. #23
    2000+ Posts Rick Kay's Avatar
    Dec 2011
    Huron, Ohio
    I guess I'm getting to the age where cold is going to bother me more...very interested in heated gear, now, especially gloves-my hands seem to freeze to the bars!
    Does anyone have a line on an American made product? I can't seem to find any...
    Rick
    2006 FLHTI/2012 CSC Daytona
    1987 FLST
  4. #24
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    As I said earlier,
    One word of caution. In my case I have a problem with the pads of my fingers(finger print area) not getting any heat since the wiring of the gloves go horizontally around the fingers. The heated grips also don't heat that area because I have long fingers. so I have to scrunch up my fingers when out for a long time. That is my one and only pet peeve. I wish Gerbing would run the wires from the top of the fingers around the tips to the bottom = problem would be solved.
    I've contacted Gerbing 4 more times. At least someone finally replied back, but on all three times they couldn't answer that very simple question. I can't believe no one at Gerbing can give me a definative answer - probably because the gloves are not wired the way I need them, but at least tell me so I don't keep wasteing my time trying to get an answer.
    If I had the knowledge, I'd take the gloves apart and rewire them myself. I guess I could try a tailor.
  1. Heated Gear Connector Location
    By Jerry/MD in forum Harley Trike Conversions
    Last Post: 01-10-2014, 10:55 AM
  2. Help ! Gerbings Heated Gear
    By iron cg in forum Harley Trike Conversions
    Last Post: 10-22-2012, 11:51 AM
  3. Heated Grips Question
    By ny_winemaker in forum Accessories
    Last Post: 10-06-2012, 10:10 PM
  4. Replies: 3
    Last Post: 01-13-2012, 08:12 AM
