Results 1 to 20 of 20
Thread: Battery charger
    750+ Posts
    Aug 2011
    Lake Murray, SC
    Default Battery charger
    My battery charger died and I need to replace it. What is everyone using?
    Lost In The 50's rmrc51's Avatar
    Feb 2009
    Palmyra, Virginia
    Post Re: Battery charger
    My regular battery charger is a Sears. It has 2, 10 and 50 Amp settings. I have it for quite a few years and it still works perfectly.
    As far as a trickle charger, I use the "Battery Tender" exclusively. It also works great!
    Default Re: Battery charger
    I use a Battery Tender Charger over the winter.
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    Years ago I bought a Yausa battery and their charger. Worked fine for me charging up a new battery, but ride too often to need to put the battery on a charger during the life of the battery.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
    750+ Posts
    Aug 2011
    Lake Murray, SC
    I want a float or maintainer. I had a Battery Tender that died. May still go with the Battery Tender Plus. A three stage charger is the way to go.
    3250+ Posts Hot Rod 1's Avatar
    Jun 2012
    Saratoga County, New York
    I have three Battery Tenders. I use one on each of my Goldwings and one on my Simplicity lawn tractor. I also have a Craftsman 2 amp-10 amp charger I've had for thirty years. The Yuasa Battery in my 89 Wing will be 10 years old in the spring. The battery in my new lawn tractor failed after 6 months, go figure.
    100+ Posts donjack's Avatar
    Jun 2011
    Danville Ky USA
    I use the Smart Charger fom Harley, not expensive and works great all winter. Have three of them, on three different machines.
    100+ Posts
    Nov 2011
    kernersville NC. USA
    I've been using the " Battery Tender" for years.First thing I do with a new bike/trike is install a Battery Tender pigtail.
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Battery Tender here - 3 - on second car and another bike. I think you'll find about 90% recommend the BT.
    I also have a 40 year old 2/10/30 amp car charger - I never use that on a bike.
    I plug the Harley in every time I return home.
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    I have used this
    Schumacher Onboard Battery Maintainer — 12 Volt, 1.5 Amp, Model# SE-1-125 | Battery Maintainers| Northern Tool + Equipment
    I also have it hooked up to an out door Christmas light control. The control allows the power to be turned on at dusk and off to dawn. I found that running it 24/7 it dries out the battery. I have 5 maintainers running this way.
    2750+ Posts Rosy's Avatar
    Jan 2012
    Dover, NH USA
    I have three of these and bought at Wally World:
    Schumacker Battery Companion SEM 1562A 6/12 Volts
    Lawnmover/Motorcycle/ATV
    Tricle Charge 1.5 Amps
    Plug them in, in Novenber time frame and forget about them till April comes around.
    Good luck!
    Regards,
    Rosy
    From NH
    70+ Posts
    Feb 2011
    St.Petersbrg,Fl,USA
    I use Yuasa Automatic 12V 900 mA battery chargers and the Battery Tender jr. chargers. I have pigtails on all my bikes and my car. I keep one on my car all the time and the bikes I'm not riding. I just bought six volt Battery Tenders for my model T and model A and when I buy new batteries for them they will get the Battery Tenders and pigtails put on. I have a Palmer electric trike that has two golf cart batteries that I also keep on a Yuasa battery charger. So yes I think they worth using.
    Nov 2012
    Waterloo, Iowa
    I love my battery tenders! I think I have 4 or 5 of them.
    800+ Posts
    Aug 2011
    Evansville, IN
    It depends on what you need the charger for, I have a regular roll around unit that does 6 & 12 volt with a bunch of settings including a 200 amp jump, I have a smaller unit that I used on the RV & use on the batteries in the 28ft enclosed trailer and I have at least 5 or 6 Battery Tenders for the bikes, ATV & Ford tractor. So it really depends what it's for, you can't beat Battery Tenders or something similar for maintenance charging.
    150+ Posts Teal's Avatar
    Jun 2011
    tenn
    Battery tenders boils my batterys
    Battery minder is what i use ,,,
    supposedly it desulfates the battery when needed and maintains.
    39$ on line or northern tool..
    i recovered a 8 yr old car battery that was laying in the garage with this.
    1500 2011 Champion trike
    KR4VA
    US Navy Aviation
    Surely Goodness and mercy shall follow you all the days of your life:)
    TOI - New Jersey 87Trike1200's Avatar
    Feb 2008
    The Jersey Shore
    I've always had good luck with Battery Tender - I have 3. Also, I recently got one of these. Seems to get good reviews and has worked well for me so far. Not exactly a "bargain" at around $80 (shop around, I got mine new in box on eBay) - but it's supposed to be the "latest & greatest" technology...we'll find out.
    "Only a biker knows why a dog sticks it's head out of a car window."
    - - - '95 GL1500 / '12 MT Phoenix IRS - & - '87 GL1200 / TriKing - - -
    150+ Posts Blueribbon's Avatar
    Oct 2012
    Savage, MD (near Columbia)
    I use Battery Tender Jr., but I do not leave it on the Trike. When the light changes to solid green, I take it off.
    Even on the coldest winters, this only has to be done every 3 or 4 weeks, though if this winter is like last winter, I won't use the Battery Tender, Jr. at all. I'll ride and ride and ride
    2008 Wing Roadsmith (above The Dragon's Tail - 318 turns in 11 miles)
    Vietnam Vet * * * Saddlesore 1000 * * * N8HDW
    If you want to do something, do it now!
    GLEN ELLYN, IL. USA
    Mine is connected all the time except when riding. That's the whole idea of a smart charger. If I was to go out to the freezing garage and disconnect it every time it turned green, I might as well use my cars 2/10/30 charger and save the money.
    I'm lazy so I don't want to have to keep going out to check the battery and worry if I forgot to.
  19. #19
    Sep 2013
    HUNTINGTOWN, MD, USA
    The "battery tender" is a must, if your bike has a constant draw, such as an alarm or clock, the other trickle chargers will over charge and burn up your bike battery.
    I found out the hard way. You can keep the "BATTERY TENDER" plugged in all the time.
  20. #20
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by FOX HOLE View Post
    Not really. You can buy battery chargers that have a maintainance feature that act as a tender for less dollars often than a regular tender.
  1. Battery Charger
    By Grandpa1 in forum Honda Trikes
    Last Post: 12-06-2013, 02:32 PM
  2. "X-treme" (brand) Battry Charger
    By 87Trike1200 in forum General Discussion
    Last Post: 01-13-2013, 07:56 PM
  3. 12v Battery Charger @ $6.98
    By ben721364 in forum General Discussion
    Last Post: 07-04-2012, 04:43 AM
  4. Battery Bug
    By Shimpy in forum Honda Trikes
    Last Post: 05-04-2012, 11:45 AM
  5. Gel Battery
    By docb in forum General Discussion
    Last Post: 03-17-2008, 02:44 PM
