Likes Likes:  1
Results 1 to 19 of 19
Thread: Best Heat Wrap??
    400+ Posts Aussie Annie's Avatar
    Dec 2011
    Port Kennedy, Western Australia
    Question Best Heat Wrap??
    What would you all recommend??
    I want to wrap the exhaust, to help reduce heat on my right leg. My leg is stiff so I am closer to the exhaust... and the heat catches me in the back of the knee, and upper thigh.
    Thanks for the help
    [SIGPIC][/SIGPIC]
    Threedom to Ride!!
    2011 FLHTCU/Motortrike
    100+ Posts Bigbill's Avatar
    Southeast Missouri, USA
    Default Re: Best Heat Wrap??
    I just went to my local Autozone (auto parts store) and bought some header tape. I dont remember the brand but it wasent very expensive and works well.
    2009 Harley FLHTCUTG TriGlide
    Vivid Black and Chrome
    SE A/C, Rush Big Louies, Dynojet Power Vision from FuelMoto, Lift Kit and Tour Pac relo by Dennis, Floorboard relo by Harley Goodies, LRS, Crotch Cooler by Capt Itch, Dis and Dat bling.
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Can you re-install the chrome covers after putting the wrap on? I've seen bikes with the wrap and it wasn't a pretty picture.
    What helped me alot was floorboard extenders and a "crotch cooler". All that for about $180. Makes a big difference. I remove the crotch cooler for winter riding - very easy - remove seat - lift coolers up and out.
    TheBobs
    Guest
    Gary, the heat shields fit perfectly fine over the wrap.
    TheBobs
    Guest
    Quote Originally Posted by Aussie Annie View Post
    Thanks for the help
    DEI makes a Titanium wrap. I like it because I didn't have to soak it. DEI also makes a 1,500 degree silicone sealer as well. I got mine at O'Riley's Auto Parts.
    No problem putting the chrome covers back on.
    800+ Posts
    Aug 2011
    Evansville, IN
    Anyone have or know of a picture of a TG with the wrap on and anyone seen the DEI Titanium wrap in person? I was wondering about the silver color, if it blended in well with the chrome pipes or really stuck out?
    TheBobs
    Guest
    Quote Originally Posted by 92fxsts View Post
    Uhhhhm, see my post above You should use the silicone sealer. It's black and makes the wrap disappear behind the shields.
    Oct 2010
    USA
    I see accell sells a heat rap for motorcycles.
  11. #10
    40+ Posts
    Oct 2012
    W.Paducah Ky. U.S.A.
    Thanks for the help
    I used the titainium 50 ft roll from DEI .I found it on amazon for $30.00 plus shipping .no need to wet it but wear some gloves and long shirt.Wrap from the rear toward the front I lapped it at 3/4 " and had enough to do every thing that is covered by heat shields even the area of thecrossover next to the oil / tran.pan .I did the wrap with pipes still installed on the bike. take a little time but It does help with the heat issue.
    Semper-Fi
    68-71
  12. #11
    1000+ Posts
    Mar 2011
    Muncie, Indiana
    Mine after two years. Still in very good shape.
  13. #12
    2250+ Posts
    Ocala, Florida
    The first 8-10 miles it smells horrible. Might even be something that's not good to breathe. After that, it's fine. Got my wrap from Drag and probably paid too much: $60.
    Phu Cat
  14. #13
    1000+ Posts
    Mar 2011
    Muncie, Indiana
    I burnt mine off several times before putting deflectors back on.
  15. #14
    800+ Posts
    Aug 2011
    Evansville, IN
    iaff84, Thanks for posting the pics, the wraps look good. I might have to try some of the titanium wrap on my TG and see if it makes it cooler on the leg.
  16. #15
    1000+ Posts
    Mar 2011
    Muncie, Indiana
    The bad part of seeing the pictures again is how good the paint looked a few years ago. I need to think about doing a good detail on this ride!
    Dennis
  17. DKCustoms postbit
  18. #16
    Oct 2010
    USA
    What temp changes are you seeing with the pipe wrapped?? or how much cooler is it wrapped?
  19. #17
    1000+ Posts
    Mar 2011
    Muncie, Indiana
    It has been two years ago that I did it so hard to remember how much it helped. All I can remember is it was allot better. At the time all I had done was cut the CAT out, wrapped pipe and changed slip ons.
    I used Thermo Tec brand. Got a package of 2 inch wide by 50 foot and have allot left over if I wrap another set. I also got their spray on sealer. This wrap was Graphite black and you had to soak it before wrapping, let dry then coat. It seems to be holding up very well.
  20. #18
    5+ Posts Phatbag's Avatar
    Apr 2013
    Fort Mohave
    Hey Annie,
    Did wrapping the pipe make a difference?
  21. #19
    Jun 2019
    Pauls Valley, OK
    Default titanium wrap
    just wrapped my 2017 and cut the converter out . wow what a diff the wife almost could not bare the heat with jeans . now were riding with shorts unbelievable the diff
  1. Exhaust wrap or not?
    By shadowrider69 in forum VW Powered Trikes
    Last Post: 04-18-2013, 01:55 PM
  2. 3M Fender Wrap
    By bikerbillone in forum Accessories
    Last Post: 02-06-2013, 10:11 PM
  3. heat wrap exhaust tape
    By tryker55 in forum Harley Trike Conversions
    Last Post: 10-07-2011, 04:45 PM
  4. Exhaust heat wrap?
    By NosMan94 in forum Harley Trike Conversions
    Last Post: 04-24-2011, 11:54 AM
