Likes Likes:  0
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 49
Thread: Stator Plug Leak
  1. #21
    2500+ Posts trikermutha's Avatar
    Oct 2010
    USA
    Default Re: Stator Plug Leak
    Quote Originally Posted by Paw Paw Willie View Post
    On mine [2011] there are no O rings. The wire, plug and stator are 1 piece from factory. Entire assembly has to be replaced.
    wonder if they jusst used up there older inventory before the new design came out on certain 2011's??
  2. #22
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Quote Originally Posted by trikermutha View Post
    I am still blown away by how much oil is coming out of that plug..That should never happen..
    I agree 100% it shouldn't happen.
    http://i1347.photobucket.com/albums/...pswnuweejq.jpg
    Red Ultra Powered By Head-Quarters 120, Easy Clutch Pull By ClutchWIZ. 2012 GL1800 Hannigan. I've yet to ride a stock Harley which wasn't in need of a mechanical intervention.
  3. #23
    Sep 2009
    NE Ohio
    They use up old stock before making the change, they have a 50 - 50 chance it will either fail under warranty and they pay to replace it, or fail out of warranty and the customer gets to pay.
  4. #24
    150+ Posts KRUZR's Avatar
    Oct 2010
    Aurora, IL, USA
    I had oil coming out of the Stator plug. Needed the Crank seal replaced. Engine oil was leaking into the primary if I recall correctly.
    Black Pearl 2007 Street Glide/2010 California Side Car Conversion
  5. #25
    Oct 2010
    USA
    Quote Originally Posted by KRUZR View Post
    Yea that happens sometime too..But my oil levels in the primary are still normal..
  6. DKCustoms postbit
  7. #26
    Class Clown Bikerbozo's Avatar
    Jun 2010
    Coram, NY USA
    Stator replaced twice now. I seem to recall that plug leaking at least once. 55k on '10 TG. Still 4 1/2 years on extended warranty. Maybe next Stator will last more than 25k (Compensator clutch goes every 25k also).
  8. #27
    Sep 2009
    NE Ohio
    Quote Originally Posted by Bikerbozo View Post
    I know why the compensator is living a short life, I wish I could figure out why the Stator seal is taking a premature dump. When I got rid of my 2010 it had a bad compensator and the stator plug was starting to leak all at about 22,000 miles.
  9. #28
    Oct 2010
    USA
    I will have to look at my compensator and decide if it needs replacing at around 7600 miles. Not sure why they are going bad...
    Still got a few months yet before the replacement stator arrives..backordered till 2/12
  10. #29
    Sep 2009
    NE Ohio
    The biggest issue of the high failure rate is the design doesn't allow for good lubrication of its moving parts. They really messed up when they moved away from the style of compensator they were using with the pre 06 Dyna and 07 for the rest. The Compensator on my 06 Ultra has 35,000 miles on it and works like a champ, even with the 120.
  11. #30
    Jun 2010
    Coram, NY USA
    My HD mechanic had one apart recently and i asked his opinion about why the compensators fail. He showed me all these heavy duty plates and then this really small thin one that you could see was bending. In other words, poor design. They take too many years to investigate problems and make fixes.
  12. #31
    Oct 2010
    USA
    Wow between lube issues and plates bending..Is there a solution to the problem?
    What is on the Tri Glide Now a Screaming Eagle Compensator??
    Would a New style BDL compensator work Better??
  13. #32
    150+ Posts Frang's Avatar
    Apr 2011
    Massachsetts.,USA
    Think i'll get out of this website.Every time i read something it scares the hell out of me.This thing breaking,that thing leaking.Unless you own a motorcycle repair shop i'm beginning to think you don't want a Harley.
  14. #33
    Oct 2010
    USA
    Kinda reminds me of my old car kept blowning head gaskets..11 gaskets later it was time to dump the car..The warranty would fix the gaskets but they would not put in a better gasket that solves the problem.
    But I dont plan on dumping the Trike tho..besides a few problems it still runs great..Yea the issues should not be happening but this site and others help if there are problems..
    What I find also is there are other replacement parts out there that seem to be made in the USA..Which I find lasts longer and is a better product.
    PLan on riding the TRIGLIDE until the engine is to tired to run then either have it rebuilt or slap in a fresh engine..
  15. #34
    100+ Posts kimber45's Avatar
    Nov 2011
    Rockwall, Texas
    replaced stator and compensator, extended warranty picked up the bill.
    2013 GL1800 CSC Viper
    2010 Harley TG
    1974 Yamaha 650
    1972 Moto Guzi 750
    1969 Honda 350
  16. #35
    Oct 2010
    USA
    Quote Originally Posted by kimber45 View Post
    Just wondering did they have a part # on your stator on your bill??
  17. DKCustoms postbit
  18. #36
    Jun 2010
    Coram, NY USA
    Quote Originally Posted by Frang View Post
    55k on TG and never had to be towed from road. For some reason, both times stator went was day after 8+ hr ride, when already at destination. And rode it to HD on battery.
  19. #37
    Sep 2009
    NE Ohio
    The Triglide comes with the Screamin Eagle compensator, for some reason the BDL doesn't seem to be catching on with folks. I know of a couple guys who have been working on a device that gets more lubrication where it should be. The majority of the compensators I've seen failed has been excessive wear on the ramps, one guy I know actually had a divot warn in the ramps.
  20. #38
    Oct 2010
    USA
    Quote Originally Posted by msocko3 View Post
    Does make you wonder why they changed the compensator in the first place...The older versions seem to last forever..
  21. #39
    Nov 2011
    Rockwall, Texas
    I will check it tonight after work.
    2010 Harley TG
    1974 Yamaha 650
    1972 Moto Guzi 750
    1969 Honda 350
  22. #40
    Apr 2011
    Massachsetts.,USA
    "they lasted forever".That should answer your question about why they changed em.
  1. Spark plug gap
    By geraldlanc in forum Honda Trikes
    Last Post: 09-25-2022, 06:13 PM
  2. Change 5-round plug-in to 4-flat plug in for trailer
    By BinIdaho in forum Harley Trike Conversions
    Last Post: 02-26-2013, 11:42 PM
  3. Disaster ride, Stator hub, voltage regulator went out!
    By billltrhd09 in forum Harley Trike Conversions
    Last Post: 08-17-2012, 02:29 PM
  4. Diagnostic Plug
    By CUNDEL in forum Stallion Trikes
    Last Post: 12-19-2011, 11:35 AM
  5. plug question
    By xfootdoc in forum Honda Trikes
    Last Post: 09-25-2010, 09:05 PM
