Speed Bleeders
Likes Likes:  0
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 49 of 49
Thread: Stator Plug Leak
  1. #41
    90+ Posts
    Aug 2012
    Jamestown, RI USA
    Default Re: Stator Plug Leak
    I have a 2012 TG with 2700miles on it (new to me). Leaking oil out of the Stator Plug. Tech said it was because it was overfilled (FWIW previous owner used Syn3). It is covered under warranty, however, I have been waiting for a month for the replacement part. Glad this didn't happen in June!!!!
  2. #42
    2500+ Posts trikermutha's Avatar
    Oct 2010
    USA
    Quote Originally Posted by seabiz View Post
    If it was overfilled I would check to make sure you are not loosing engine oil too..The reason why is the seal from the engine could be blowing oil into the primary or from the trans..then again somebody may have overfilled but it still should have not leaked..They have problems with the stator plugs leaking..The replacement part is not due until Feb 2 per all dealers that I have checked with..the newer revised stator has a "D" at the end of the part number now..
  3. #43
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Quote Originally Posted by trikermutha View Post
    The stator isn't a dry area to begin with, it sees plenty of oil. If someone did overfill they would have had clutch problems right off the bat.
    http://i1347.photobucket.com/albums/...pswnuweejq.jpg
    Red Ultra Powered By Head-Quarters 120, Easy Clutch Pull By ClutchWIZ. 2012 GL1800 Hannigan. I've yet to ride a stock Harley which wasn't in need of a mechanical intervention.
  4. #44
    90+ Posts
    Aug 2012
    Jamestown, RI USA
    Thank you for the advice and update on the part availability. I took the bike in to have it gone through after i purchased it late this fall. As luck would have it, it just started leaking before it went in. The mechanic didn't seem concerned. He is an old timer and seems to know his stuff. He has been through it and nothing else turned up. The previous owner's son did the oil/fluid changes and switched everything to syn3 (I am switching to RedLine in primary and tranny; ams oil in the motor.) I am inclined to agree with the mechanic's observation that it was just overfilled. I did call the original dealer and they said it had been in for a clutch adjustment at 1000 miles; the oil was changed at 300 miles. So looks like your observations are consistent with the history. I will be looking forward to getting her back home soon! There is a big ugly empty spot in the garage and I have a lot of stuff to do!
    Will be visiting her this weekend.....Again! I'll run by your observations with the mechanic. THANKS MUCH!
  5. #45
    5+ Posts
    Feb 2012
    Killeen, Texas
    I thought I had a stator plug leak and it turned out to be the oil filter mount was loose. This after I tightened the oil pan bolts like nearly everyone else here has. The oil was oozing across the front of the case and over to the stator plug so I'd say check that too.
  6. DKCustoms postbit
  7. #46
    150+ Posts oleman69's Avatar
    Apr 2009
    Moulton, Al
    My old shovel leaked, pulled apart cleaned with starting fluid made sure to get ALL the oil cleaned off silicone the **** out of it and put back in let cure overnite no more leak
  8. #47
    10+ Posts
    Jan 2013
    Oxford,Ct USA
    43k on my 2009 sending it in to get stator replaced ,extended warranty best thing I ever invested in. Hate the co -pay oh well better than doing myself.
  9. #48
    60+ Posts
    Sep 2010
    St. Ann Missouri USA
    Quote Originally Posted by mustangcav View Post
    I had the oil filter leak after the first oil change. repaired it myself. Stator plug leak was next at 5 years on a 2011 machine.
    At 18000 miles I just got done replacing the compensator. Rattling like heck. I replaced it with the new modified Compensator with a glued in oiling ramp and the screaming eagle compensator was different from the old one.
    the Stator wire leak was addressed at the same time.I tried permeated ultra Black to stop the oil leak with bad results. It seems the were o-ring places on the stator wire grommet but no o-rings installed originally. I had a o-ring kit that seemed to have the right size then cleaned out the hole with brake cleaner and alcohol . Added the o-rings and liberally applied ultra black permeated to the grommet and re-installed. Dry as a bone now and the new compensator difference is really smoother. Better all the way around.
  10. #49
    150+ Posts
    Firewrench22's Avatar
    Oct 2014
    Kingston WA USA
    Once I was cleaning and I “disturbed” that stator grommet just enough to make it start leaking. Aarrggh.
    No good way to fix it, other than take the primary apart and replace stator, grommet is part of it. I wasn’t about to simply try cleaning and reassembly.
    Bottom line, be careful around that grommet!
  1. Spark plug gap
    By geraldlanc in forum Honda Trikes
    Last Post: 09-25-2022, 06:13 PM
  2. Change 5-round plug-in to 4-flat plug in for trailer
    By BinIdaho in forum Harley Trike Conversions
    Last Post: 02-26-2013, 11:42 PM
  3. Disaster ride, Stator hub, voltage regulator went out!
    By billltrhd09 in forum Harley Trike Conversions
    Last Post: 08-17-2012, 02:29 PM
  4. Diagnostic Plug
    By CUNDEL in forum Stallion Trikes
    Last Post: 12-19-2011, 11:35 AM
  5. plug question
    By xfootdoc in forum Honda Trikes
    Last Post: 09-25-2010, 09:05 PM
