Results 1 to 20 of 27
Thread: SS tire balance beads?
    1500+ Posts
    salt lake city, ut
    Default SS tire balance beads?
    Looking for opinions on tire balance beads-in reasearching the options, the stainless steel beads look like they might hold up better than glassbeads. Any opinions would be appreciated and thanks!
    550+ Posts
    Feb 2012
    tupelo MS
    Default Re: SS tire balance beads?
    Get some small balls from a bearing suply company and see what happens
    I don't think it will work, that just my opinien.
    1500+ Posts
    salt lake city, ut
    Quote Originally Posted by saab9k View Post
    But I want my balls to be teflon coated!
    750+ Posts Bruce's Avatar
    Sep 2010
    NY, USA
    I've used the ceremic beads for 3 years now, in the tri-glide, both trailers and the rzr. When I get new tries for the truck next fall I will use them. I got 22 thousand miles on the trike front tire and probably would have got another 2 or so but I was going on an extended trip and didn't want to chance it. On my 7 x 12 flatbed I had a vibration at 40 mph, went through all the checks and everything was ok, installed the beads and the vibration went away. Had the same problem on the 7 x 12 tandem v-nose only at towing speeds 55 - 60, pulled the wheel weights off, installed the beads and now no problem loaded or empty.
    Contributing Member Big Dog's Avatar
    Jul 2008
    Sarasota
    Go with the ceramic, they are only way to go. I've used the power, it works till you get moisture when adding air, then it gets abrasive and wears the tire out from the inside. I think that the SS balls would do the same, only because I've not seen them teflon coated and I doubt that the Teflon would hold up over time.
    Miles and Big Dog
    18 Wheels or 3 Ride
    Safe & Enjoy
    2nd Stallion #792
    1st Stallion #274
    2750+ Posts Rosy's Avatar
    Jan 2012
    Dover, NH USA
    I have the beads on my front MPA (reverse mounted) and they are great. My Goldwing only shop advise I use them.
    Regards,
    Rosy
    From NH
    1500+ Posts
    salt lake city, ut
    Quote Originally Posted by Big Dog View Post
    INTERESTING.....the mfg of the SS beads (teflon coated) says tat the ceramic beads shear off after time, and the jagged edjes create wear inside the tire. They claim the SS beads don't shear off.
    Jan 2012
    Dover, NH USA
    Maybe somebody two wheeler or trike owner will chime in with results of wear on the beads after 30,000 miles or when the tire was replaced. That would be proof of how the beads stood up after long wear. I would love to SEE proof, not hearsay.
    Let's hope somebody has that info!
    Regards,
    Rosy
    From NH
    Jul 2008
    Sarasota
    Here's another option Centramatic is making balancers for certain model trikes. I'm not sure which, but they sponsor a show weekly on Sirius/XM. They mount outside the wheel.
    Miles and Big Dog
    18 Wheels or 3 Ride
    Safe & Enjoy
    2nd Stallion #792
    1st Stallion #274
    1500+ Posts
    salt lake city, ut
    Exactly what I was hoping for Rosy.
    Jan 2012
    Dover, NH USA
    Quote Originally Posted by Bruce View Post
    Bruce,
    Have you taken a tire apart to see what the beads look like after long wear? If you did were the beads whole or broken, like one manufacturer said they would be after prolong use.
    Thanks for the input!
    Regards,
    Rosy
    from NH
    30+ Posts
    Sep 2012
    Rockville Missouri USA
    took the beads out of my worn out tires and put them in the new ones, they looked fine , and are still performing well.
    900+ Posts jtilmon's Avatar
    May 2011
    Collierville, TN USA
    Don't have the beads in trike tires, but have a 20' tandem trailer that had vibration, installed the recommended glass beads in all four tires and the vibration is gone and the trailer pulls great.
    jtilmon
    GL 1800 / Roadsmith / Caliente Red
    Jan 2012
    Dover, NH USA
    Quote Originally Posted by rustic bob View Post
    rustic bob,
    About how many miles do you think you had on the tires when you looked at the beads before mounting your new tire? Did you noticed the inside of your used tire, was it cut like the other manufacturer said it would be when the ceramic beads get old?
    I think this is the first report on "used" beads that I have read. Hopefully some other riders will chime in and tell their story to see which manufacturer is correct.
    Thanks for providing this info rustic bob.
    Regards,
    Rosy
    From NH
    PS. I will send Venco Wings (my Goldwing only shop) in NH an e-mail and ask Jim what he has seem when replacing the ceramic beads.
    May 2011
    San Angelo
    Quote Originally Posted by Rosy View Post
    rustic bob,
    Regards,
    Rosy
    From NH
    I've used Dyna-Beads (cermaic) for several years now. I to harvest and reuse the beads when I can get the tire people to remember.... Other then being a bit dirty the beads were just fine. Once I actually cut the face out of a front tire to save the beads. The inside of the tire looked just like any other tire.
    2015 GL1800/Roadsmith HTS1800
    Jan 2012
    Dover, NH USA
    Gold Rush,
    Thank you very much for this information. I just don't understand why manufacturers make such statements. I guess they want to promote their products and maybe in some cases they do break into shards, but why not say so.
    Regards,
    Rosy
    From NH
    Mar 2011
    mountain home,ar. USA
    The ceramic balancing beads have been used for years and millions of miles in semi trucks. I've had great success with them when my Wing was bike. Now I use centramatics on the front wheel because I have to change tires so frequently since I wear them down quickly in the Arkansas twisties.
    My ST1300 had the beads installed with new tires and ride is velvet at any speed.
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    I can't stand the thought of anything rattling around inside my tires. I thought the standard wheel weights were fine. Then I had all this SS money laying around so I thought I'd use it to to buy the Centramatic system.
    To tell the gods honest truth, I can't really tell the difference between the wheel weights and the Centramatic, but I don't havt any ugly weights on the wheels.
  19. #19
    Jan 2012
    Dover, NH USA
    GaryD,
    I'll tell you what, in a few miles let me know how the cupping and wear is with the new weights. I know at first the balancing seemed the same, but as I look at the tires with my ceramic beads, wow, no sign of cupping and the wear, what wear?!
    So, I have written down at what milage the MPA front was put on and I will see what it looks like after a few thousand miles. According to other web sites and this one, milage should be a whole lot better.
    Regards,
    Rosy
    From NH
  20. #20
    Jan 2012
    Dover, NH USA
    I have a reply from Venco Wings, Jim says he has never seen the ceramic beads shard. He also stated the other company is trying to get and edge because they cost 4 X as much. That would explain why they are saying the ceramic beads break into shards.
    So, we have one dealer who says ceramic beads are OK to use.
    Is there anyone else on the TT site who has ceramic beads balancing their tires?
    Thanks.
    Regards,
    Rosy
    From NH
  1. Dyna Beads
    By TeNn in forum Honda Trikes
    Last Post: 04-27-2013, 07:38 PM
  2. Tire Balancing Beads
    Last Post: 07-26-2012, 04:45 PM
  3. Balancing Beads
    By Jimsjinx in forum Honda Trikes
    Last Post: 08-19-2011, 10:32 PM
  4. Beads,Gel or Air???
    By 2fromTX in forum General Discussion
    Last Post: 10-06-2010, 11:23 AM
  5. Dyna Beads?
    By 1852cc in forum Accessories
    Last Post: 08-22-2010, 10:44 AM
