Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  0
Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 73 of 73
Thread: battery life
  1. #61
    750+ Posts
    Aug 2011
    Lake Murray, SC
    Default Re: battery life
    $5 my butt!
  2. #62
    350+ Posts Woolie's Avatar
    Jun 2011
    Lubbock, TX
    A couple years ago the battery went bad on my Electra Glide, no warning. We were riding and it was fine, we shut it off for a break and it was gone from then on. Couldn't push it or boost it to start it. Had to borrow a battery from my brother to get the bike home. It will go bad when you least expect it.
    2009 Honda Gold Wing Motor Trike Adventure Kit
  3. #63
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    You could buy a battery analizer if you are flush, or just have someone at an autoparts store use theirs.....
    They are a bit expensive to just use once a year or so.
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  4. #64
    750+ Posts
    Aug 2011
    Lake Murray, SC
    Are you talking about a load test? If so they are not expensive.
  5. #65
    Jul 2012
    Chubbuck Idaho
    Quote Originally Posted by Lakeman View Post
    No not just a load test. The analyzer tests the voltage under a slight load, then watches the volt drop, then watches the recovery of the voltage back to a static charge that batteries should have. The draw test is a low amperage draw as to not damage the cells. But just enough to make a slight voltage drop. Then rates the battery for life. Quite accurate.
    To get an idea for current price do a search for battery analyzers. It is much less expensive to just stop by an auto parts store, or any place that sells batteries. Batteries Plus is one place here.
  6. DKCustoms postbit
  7. #66
    Jul 2012
    Chubbuck Idaho
    Here is a good example of a load tester that does AGM, Gel, & standard batteries.:Pulse Tech 6 Volt 12 Volt Battery Analyzer Tester | eBay
  8. #67
    30+ Posts
    Aug 2012
    lewisville texas usa
    My 2012 battery died last week , just replaced with H D new one . Before it went dead had the check engine and battery light come on while going down hwy. the volt gauge also dropped below 12 volts . I bought and installed the new one . Took it for a ride and the check engine and battery light came on again . Took it to H D shop only thing they could find was battery bolts needed about half turn more on each . Went for a ride yesterday and volt gauge went down to 10 volts twice . Has anyone had this happen ? Trike still in warranty but still had to pay half hour labor !
  9. #68
    2500+ Posts trikermutha's Avatar
    Oct 2010
    USA
    Quote Originally Posted by rae2012 View Post
    did they check the regulator and stator voltage readings..one or the other is bad..I am guessing the regulator at this point..If you have a manual and a meter you can check youself..
  10. #69
    200+ Posts KindaOldTriker's Avatar
    Sep 2012
    Hartville, Ohio USA
    Failing during 2 yr warranty, that seems like a pretty crummy battery. I just replaced my wifes Sportster battery after 6 years. It still started fine but she added a bunch of LEDs and I didn't trust it sitting for a few hours somewhere with the lights running. I've never had one go bad in under 5 years while using a tender whenever it's not being run.
    But, when I bought my Victory which sat in a showroom for two years with only 35 miles on it as a 'demo' the battery was dead and they had to replace it. That was 4 years ago, with a tender attached now.
  11. #70
    Oct 2010
    USA
    I have seen charging systems kill a battery..Lucky I am still using my orginal 2010 battery and seems to be still holding up..
  12. #71
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Like trikermutha said, might be your regulator. HD had a regulator recall campaign for early 2012's. Click on the bulletin number and you can check yours out to see if it is part of the recall M1325.
    http://i1347.photobucket.com/albums/...pswnuweejq.jpg
    Red Ultra Powered By Head-Quarters 120, Easy Clutch Pull By ClutchWIZ. 2012 GL1800 Hannigan. I've yet to ride a stock Harley which wasn't in need of a mechanical intervention.
  13. #72
    Jul 2012
    Chubbuck Idaho
    Now that is where a battery analyzer would be handy ! Well worth the time taken to have the battery tested before purchase of a new one.
    My regulator went out on my 2012 trike also just after I bought it. It did the same thing you are describing. Harley had a bad run of them out of China!
  14. #73
    1+ Posts
    May 2018
    Neoga
    Quote Originally Posted by FRR View Post
    Take this suggestion and save yourself some grief. Every three years switch your battery out. Like the gentleman said, some last 2 yrs and some last 7. Nothing is worse than to be on a trip or a ride and have the battery die. And when they die most do not give you a warning. It's not worth the headache to have to worry about it. I usually buy a Harley battery for my Ultra and a Westco, for my "other" bike. (I understand I'm not permitted to mention it on this site)
    I have a 2015 Triglide, just installed 4th battery. They keep telling me all systems fine, must be bad batteries ( OEM replacements under warranty) . Can't believe this is true. Anybody else have this problem?
  1. The Dad Life
    By Papa Zook in forum General Discussion
    Last Post: 10-31-2011, 01:14 PM
  2. Life's dream
    By Free on 3 in forum New Member Introductions
    Last Post: 09-18-2011, 09:52 PM
  3. Life
    By caveman50 in forum General Discussion
    Last Post: 02-03-2011, 05:41 PM
  4. Battery life during the sad time of year
    By Chuck in forum General Discussion
    Last Post: 03-11-2010, 12:03 AM
  5. Gold Wing Battery Life?
    By Okie in forum Honda Trikes
    Last Post: 05-01-2009, 06:10 AM
