Results 1 to 4 of 4
Thread: Crossply vs RAdial Car tyres on for front
    Feb 2013
    Invercargill, Southland, New Zealand
    Default Crossply vs RAdial Car tyres on for front
    I am building a scratch built v8 trike and I am interested in using a car tyre on the front. Has anyone used a crossply for their front tyre? Just want some feedback as the tyres I can get, the 15" crossply tyre is 2" taller than the Radial. I know a radial is a better constructed tyre than a cross-ply but does it present any adverse handling characteristics on the front?
    Here are links to the tyres I am talking about- Radial Mickey Thompson Sportsman S/R Tires 6652 - SummitRacing.com
    Cross-ply Mickey Thompson Sportsman Front Tires 1574 - SummitRacing.com
    Cheers Reaper
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Default Re: Crossply vs RAdial Car tyres on for front
    Not sure effect on a V8 trike , but on a standard trike you do not want the flex of the sidewall you get when a radial is used on the front. The bias ply is stiffer and prevents the hop in turns.
    Sep 2009
    Near Myrtle Beach SC
    If your running bias ply tires front and rear you should be good to go. If you use radials on the rear and the bias on the front the radials will handle better and get better traction, pushing the bias front tire with the V8 power you want to use
    Feb 2013
    I have just had a major rethink in the design of my front end. Just bought a set of harley alloy mags. 1x 19" and a 16" rear. Thinking of using the rear wheel in the front with a 130/90B16 73H Michelin Motorcycle Tires . Max load 805 lbs.
  1. CSC tyres wearing on the inside....
    By The Wolf in forum Honda Trikes
    Last Post: 12-02-2021, 09:16 PM
  2. Dunlop Elite 3 Radial
    By msrvpeig in forum Honda Trikes
    Last Post: 04-17-2013, 10:37 AM
  3. Cross Ply vs Radial Tyres for the front wheel
    By Reaper in forum Home Built Trikes
    Last Post: 02-11-2013, 01:09 AM
  4. Bias-ply or radial, outriggers for MTC Voyager
    By smilinjohn in forum Outrigger Style Trikes
    Last Post: 11-27-2012, 08:42 AM
  5. Radial vs Bias Ply
    By ny_winemaker in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-17-2011, 10:13 PM
