Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  1
Results 1 to 13 of 13
Thread: Tri Glide differential lubrication.
    30+ Posts
    Jan 2013
    Slidell, LA
    Default Tri Glide differential lubrication.
    Can anyone tell me how the Tri-Glide differential is lubricated?
    Bob
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Default Re: Tri Glide differential lubrication.
    It is filled with grease from the factory, there is no service required.
    http://i1347.photobucket.com/albums/...pswnuweejq.jpg
    Red Ultra Powered By Head-Quarters 120, Easy Clutch Pull By ClutchWIZ. 2012 GL1800 Hannigan. I've yet to ride a stock Harley which wasn't in need of a mechanical intervention.
    80+ Posts
    Jun 2009
    50 Miles North Of N.Y.C.
    The rear diff cost better then 5K to replace. Thats why I have HD ESP on my 9 TriGlide.
    2250+ Posts
    Oct 2011
    Ocala, Florida
    Good question, Bob. It isn't listed in the owners manual. I've only been under the backend to change the mufflers and don't recall seeing anything that looked like it would require routine Maint or anything big enough to look like a differential. What is it that's filled with grease, Socko?
    Might have to buya 2X8 and cut it down to make a ramp for the rear end.
    Phu Cat
    550+ Posts
    Feb 2012
    tupelo MS
    Quote Originally Posted by msocko3 View Post
    what do you do if it leaks.
  6. DKCustoms postbit
  7. #6
    1500+ Posts
    Oct 2011
    salt lake city, ut
    I am very curious about this topic as well. I am thinkin you could download maintenance instructions directly from Lehman. One thing is for sure - there are not and drain or fill plugs visible.::
  8. #7
    80+ Posts
    Jun 2009
    There are grease fittings ( zurks ) But HD Service says not to add grease. MOSOCKO3 is right. do nothing it the Diff is greased for life. Whos life I dont know. But leave well enough alone. The Diff cost is over $5,000 Dollars.
  9. #8
    30+ Posts
    Jan 2013
    Slidell, LA
    Looking at the parts list, it shows one "grease plug" in the differential. That could be replace with a Zerk, but I think they don't want anyone adding too much grease and blowing out the axle seals that are in each end of the differential case. Anyone know what the recommended grease is when serviced by the dealer? Just for the record, if you do manage to wear out the differential or run it without grease, the price is $428 from an online Harley dealer. Part number 83450-09
    Bob
  10. #9
    30+ Posts
    Jan 2013
    Slidell, LA
    Quote Originally Posted by saab9k View Post
    Replace the axle seals.
    Bob
  11. #10
    Sep 2009
    NE Ohio
    Quote Originally Posted by Phu Cat View Post
    Phu Cat
    The rear differential is filled with grease, it doesn't use gear lube.
  12. #11
    30+ Posts
    Sep 2021
    lake wales fl. USA
    Default differential
    Just bought a 2014 tri glide. Was looking to see if their was and was needed to service the diff. I see a grease fitting on the diff drive section. Now that being said I have a 1949 service car rear end and it has spider gears in it. It is filled too full with that grease fitting. How do you know because it is hard on the handle of the grease gun when it is full. NO more room so you stop. After ridding it you do check it and may just get one or three pumps on the grease gun handle be fore it becomes firm. Just down loaded the service manual and was looking at the brake down of the diff. Center drive dose not show spider gear's. Still trying to figure if it is able to slip when turning. I see that the axels have sealed bearing on them and a plate that holds them to the column. Must press them on and read of a ring that must be put into the groove. So if any one has had them apart and serviced them their selves would be good to know when to replace the sealed outer axel bearing. Coming up on 50 thou. miles on this bike and don't want to ruin the differential and have to buy another one. Better to service it and keep it in good working shape. I do all my own mechanic work on my vehicles and always have. It saves money down the road. Been into a bunch of V twin motor's over the years and did bushing's and piston's and ring's. Have worked on the head's also and replaced worn part's their. Well if any one like I said been able to service the differential give us a low down. Thanks. Old Hippie
  13. #12
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    When you get ready to service your axle bearings have a look here
    https://www.dkcustomproducts.com/tri...ner-plates.htm
  14. #13
    30+ Posts
    Sep 2021
    lake wales fl. USA
    Now that is a good idea. When I get into it at 51000 miles will check for damage. Thanks for the info. Going to write it down in my book. When I had my tires off the bike and on stand's checked for movement and their was none yet thank good ness.
  1. zerk on differential?
    By bikerbill in forum Harley Trike Conversions
    Last Post: 04-14-2024, 06:19 PM
  2. Tri Glide differential bearings.
    By bobscogin in forum Harley Tri Glide
    Last Post: 06-23-2020, 02:34 PM
  3. Differential bearings --Tri Glide
    By bobscogin in forum Home Built Trikes
    Last Post: 01-27-2013, 10:14 AM
  4. Differential offset
    By Jakeboy in forum General Discussion
    Last Post: 01-16-2012, 12:44 AM
  5. Rear Differential
    By Davidf66 in forum General Discussion
    Last Post: 02-04-2010, 03:24 PM
