Likes Likes:  1
Results 1 to 19 of 19
Thread: harbor freight trailers
    150+ Posts geraldlanc's Avatar
    austin tx usa
    Default harbor freight trailers
    Does anyone have experience with the harbor freight utility trailers. I am looking for a pull behind for my GW trike. The question I have is; are the tires good for highway speeds on long trips? I plan on adding a car top carrier for stuff, but will not overload it.
    Gerald
    350+ Posts Livin2Ride's Avatar
    Nov 2011
    Leasburg
    Default Re: harbor freight trailers
    I had this one a few years ago and did not have any problems with it at all. Pulled at 75-80 mph with no issues. I did remove one of the 2 springs on each side as I built it. Watch for the sales and use the coupons. I paid $294.00 for my kit out the door.
    78" Tag-Along Trailer - 600 Lb. Capacity
    Sam - Mid MO
    2015 Triglide.
    20+ Posts TeNn's Avatar
    Jan 2011
    middleton,tenn.
    don't even know it's behind you.
    TOI - Virginia VaThumper's Avatar
    Feb 2011
    Williamsburg Va
    I have had mine about 2 yrs now and have had no problems. I also took out 2 of the springs so when loaded lightly it doesn't bounce. The price is right and they look fine also.
    2010 HD TriGlide,FullSac,Heavy Breather,Vance&Hines Deluxe Mufflers&FuelPack,30Tooth Sprocket,Willy Shinny Wheels, Chrome&More Chrome:Party:
    80+ Posts
    Sep 2012
    Gold Country, California
    >Does anyone have experience with the harbor freight utility trailers. ... are the tires good for highway speeds on long trips? I plan on adding a car top carrier ....
    I built one a year or two ago. The trailer I bought (used) needed to be narrowed and have the tongue shortened. When I was done, it turned out to be real close to the Tag-Along trailer they now sell. It towed fine up to 70 or so mph. I didn't try any faster. Hardly knew t was there. The tires were fine, had no problems or concerns.
    The wheel bearings, however, were not. They were lubed only with a thin coat of cosmoline and one was starting to rust. I replaced all four, along with the seals, with american-made pieces and lubed them with synthetic wheel bearing grease. Again, no problems or concerns. I agree with removing the extra spring leaves and slipping some hose over the shackles. I think they work just fine, and are a bargain, especially on sale with a 20% coupon. Good luck with it.
    Jack The Machinist
    Jackson Head Works
    - If your motorcycle ain't fast enough to scare you, we can fix that. -
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    Some friends and me bought a trailer about five years ago like you are talking about. It has been pulled several thousands miles and to my knowlegde nothing has been done to it other that the yearly maintenance. Original tires are still on it.
    150+ Posts RRSCOTT's Avatar
    Feb 2012
    Maquoketa,Iowa, US
    Or You can just get this.
    Randy
    40+ Posts
    Jun 2012
    Punta Gorda FL
    Harbor F. tagalong best bang for the buck. I built my own using H.F. 4 & 6 trailer, removed one leave from springs and repacked wheel bearings with better grease. 8 inch wheels never got warm and after 3000 miles look as new kept them at 18lbs. I like wider stance of this trailer very stable and rides great no bouncing even unloaded.
    May 2011
    San Angelo
    If you choose to build your own I'd suggest pulling a leaf or two from the springs and make sure you check the wheels. I helped a friend build one last year and the supplied wheels were so warped that the trailer shook like crazy. He took the wheels in and they exchanged them and all was good.
    2015 GL1800/Roadsmith HTS1800
    20+ Posts Surdo's Avatar
    Sep 2013
    SW Missouri
    The trailers from Harbor Freight now have a 45mph speed restriction, they cost 189.00 for the frame and wheels, I was told you could put different wheels and bearings on and pull it as fast as you want. good luck.
    50+ Posts
    Jun 2012
    Humble, Texas
    People ignore the tag-along speed restriction (55 MPH) and never have any issues. The wheel bearings MUST be repacked with real grease as soon as you get it, though.
    350+ Posts bayoudave's Avatar
    Jul 2012
    Jena, LA, USA
    Saw one of the tag-along trailers last Saturday. It looks a lot like my Piggy Backer but is smaller, has smaller tires, shorter tongue, and does not have the torsion bar axles but it looked pretty good for the money. On sale at HF for $399.
    2002 Goldwing Motortrike Spider - 2007 PiggyBacker Trailer - 2009 Time Out Deluxe Camper - 2005 Desert Fox 17SV Toy Hauler --- CMA, PGR --- SaddleSore 1000/Bun Burner 1500
    40+ Posts 09Mug's Avatar
    Sep 2013
    Shrewsbury, Pa
    I have used my HF trailer for 3 years now, dont even know its there so when i get the trike back i dont think it will be any different. I didnt pull the spriings at all im a bit heavy around 300lbs empty. I did make my own axle and used harley wheels.
    30+ Posts Bigman2's Avatar
    Nov 2012
    Magnolia Ar
    I built one a few years ago. I narrowed it and took out leafs out and it towed find at any speed. I made the tongue out of aluminum conduit so it would be longer and used the braces off of a old step ladder so the lid on the car top carrier would open wider. If I made another one I would build the box instead of the car top carrier
    Attachment 9241
    I have been very happy with this trailer.
    I'm on my 3rd one.
    Made near me in Wisconsin
    http://www.countrytrailers.net/
    5+ Posts ductman's Avatar
    Nov 2011
    whitewright Texas USA
    Quote Originally Posted by RRSCOTT View Post
    I have this one all so pulls just fine with my GL1500, all i have done to it is replaced the wheel bearings and seals and added LED lights
    Feb 2014
    Snow Hill, NC USA
    I had great luck with mine. I towed it behind a couple of different Gold Wings and a couple of Street Glides.
    500+ Posts
    triwinggirl's Avatar
    Jun 2010
    Las vegas Nevada
    Cool Re: harbor freight trailers
    I still think mine is cool
  19. #19
    20+ Posts
    Feb 2014
    Crystal River,Florida. USA
    This is our harbor freight trailer.We build a box for sale that mounts directly to a harbor freight 40x48 trailer. We pulled ours 75 mph from Fl. to Tn last weekend. Repacked the bearings using synthetic wheel bearing grease and removed the center leaf in the spring pack. Checked the hubs and the tires for heat at every stop. No problems,the trailer pulled great.
  1. Harbor Freight Trailer Coupon!
    By Rsw in forum Trailers / Campers
    Last Post: 06-12-2013, 02:50 PM
  2. Bushtec Trailers.
    By spider2 in forum Trailers / Campers
    Last Post: 09-23-2012, 05:08 PM
  3. Trike Trailers
    By clint44 in forum Trailers / Campers
    Last Post: 09-04-2012, 02:57 PM
  4. Boscorp Trailers
    By Lucky in forum Trailers / Campers
    Last Post: 08-12-2012, 06:41 PM
  5. Harbor freight trailer
    By Bagger in forum Trailers / Campers
    Last Post: 04-13-2012, 10:34 AM
