ThirdWheel
The Spaminator
Mary, the sure and quick fix for this would be to trade it for a Honda!
Hang on! I think we've found one.
reksul
My gauge is an oil temp gauge. When I built my trike I installed that. The sender comes off the engine oil pan. When I wrote that response I figured those that understood would realize I was talking about an oil temp gauge. Next time I will be more specific. My lowers make no difference in the oil temperature on or off. They are designed to force air to the inside and that flows over the heads. Because of the slight scoop effect of the lowers there is actually more air flow directed at the heads. What makes the difference in heat is the 10 tube oil cooler and the re-programmed ECM by the Power Commander along with a stage one air cleaner with true dual V & H exhaust. It still gets hot when riding real slow or idling, but that's why I added a blower where the horn used to be. If I know I'm going to be in slow mode I turn on the blower before it gets hot and that helps some.
Ted
Ted
What are you getting for head temp vs a given oil temp?
Thanks,
Ted
I wrote this article, as well as others, to help with this problem, posting them right here on this site. Unfortunately, those that would be helped, or at least be given some understanding of these problems, don't seem to be able to locate these articles. Here is the link to the heat related subject:
http://www.triketalk.com/forum/dave-...ur-harley.html
You all are getting too high-tech for me:gah:
Joan.... you crack me up. But if you all are going down to harass reksul, let me know. I'll ride down and help
You got it girl!!! Now that would be a fun trip!:yes:
