Likes Likes:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 27 of 27
Thread: Steering problem
  1. #21
    700+ Posts
    Jan 2012
    Cayce SC
    Default Re: Steering problem
    Quote Originally Posted by americanbadass View Post
    Sounds like a good theory...but...what if you can't walk and chew gum at the same time
    I thought that's why we ride Trikes !
  2. #22
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    Still not a "Great" Idea to add a Raked Tree Kit on These if You think there might be a chance that You'll go back to 2 Wheels with it. I've owned, ridden, and installed Raked Trees on 2-Wheelers in the past (especially Choppers) to keep Them "Low-n-Level".....I've had no real issues, but I don't recommend it except for Really, Really Long Term Experienced, Seasoned Riders......
  3. #23
    May 2022
    china grove,nc,usa
    Default death wobble
    i have a tow pac kit on my 2001 roadstar, when i it about 40-45 mph and hit a bump the whole bike starts a death wobble. its feels mostly the hanlebars
  4. #24
    Quote Originally Posted by rob50152 View Post
    Rob welcome to Trike Talk 👍👍..
    Make sure The steering head bearings are tighten down they have to be Torqued down more than when it was a two wheeler …
  5. #25
    750+ Posts
    Jan 2010
    east windsor ct
    this will most likely continue until you reduce the trail.
  6. #26
    100+ Posts AJ1500's Avatar
    Apr 2014
    Midway Ga
    what is your pre- load set at, is it real soft and leans easy or is it stiff. what are you running your tires at on the kit. I had a Voyager on a Venture and the only issue we had before we changed out the tree was it was a bear to turn, never once tried to go into a wobble at any speed. I agree about tightening your steer head bearings a little but I would look over the install carefully to be sure nothing in the back is loose or able to sway.
  7. #27
    100+ Posts
    Feb 2017
    DE
    Yamaha, probally honda too, have made electronic steering assits, yamaha, was supposed to be testing it this year. I cant wait, to find one, and use it on my trike
  1. Steering Stabilizer
    By scanel in forum Accessories
    Last Post: 10-08-2014, 08:40 AM
  2. Steering
    By MangoMike in forum Honda Trikes
    Last Post: 06-08-2013, 03:48 PM
  3. Wobble in the steering
    By liberty58 in forum Honda Trikes
    Last Post: 06-04-2012, 08:58 AM
  4. steering damper pro/con ?
    By krazybob in forum Outrigger Style Trikes
    Last Post: 10-04-2011, 12:24 PM
  5. H.D. trike steering
    By apulizzi in forum General Discussion
    Last Post: 04-15-2011, 06:37 PM
