Results 1 to 8 of 8
Thread: CSC electric reverse
    10+ Posts bflonez's Avatar
    Dec 2012
    North Fort Myers,Fl
    Angry CSC electric reverse
    Have a CSC with electric reverse. It works well most of the time but will blow the 10 amp fuse every so often. The same fuse works the trunk. Seems the 10 amp is to small to run that reverse motor. Anyone have any ideas? Thanks
    Default Re: CSC electric reverse
    i think a 10 amp might be to small also for a motor. can you look on the wires and see what gauge you are working with. maybe try a 15 amp to see if it solves the problem if the wiring supports it.
    150+ Posts Tinbasher's Avatar
    Oct 2012
    North West UK
    Can you get a 10 amp "Slow Blow" fuse? It sometimes helps when the motor has a high initial load.
    BMW R1200c Grinnall conversion. With Klictronic shifter, combined brakes and electric reverse.
    Dec 2012
    North Fort Myers,Fl
    Talking Re: CSC electric reverse
    Put a 15 amp in. Will see what happens. Dealer had to install newer style reverse switch last week so that may be a problem. Should have put the reverse in the Baker 6 speed. I think the electric one is going to be trouble. Thanks for the reply's.
    400+ Posts
    Feb 2008
    Central Texas
    I would suspect the initial wiring of the trunk switch, when the trike kit was installed. I would also be reluctant to over fuse a circuit on a Honda. There's always the chance of frying wiring...
    Dec 2012
    North Fort Myers,Fl
    Thumbs up Re: CSC electric reverse
    It's not a Honda but a Harley Road Glide. Had it built at the factory and when I picked it up I was instructed not to use the electric reverse without the bike running as the electric reverse motor would kill the battery. That's a lot of draw. I think a 10 amp fuse is to small for that motor. Have been using a 15 amp for a week with out it blowing.
    400+ Posts
    Feb 2008
    Central Texas
    Quote Originally Posted by bflonez View Post
    My mistake and I apologize. I know of folks with Hondas who have reported similar circumstances. Since your is a factory built trike (Tri-Glide) the H-D dealership Service Manager is the person to talk with. He/she can give better advice with regard to electrical circuitry and may have seen a service bulletin addressing this very issue. Good luck!
    400+ Posts
    Feb 2008
    Central Texas
    OOps. I made another mistake. You said that yours is a CSC conversion! In that case, I would talk with that company. If a CSC representative advises replacing the 10 A fuse with a 15 A or stronger, get it in writing.
  1. Electric Shifter
    By prowler in forum Accessories
    Last Post: 12-18-2014, 08:36 PM
  2. electric reverse for trike
    By Fabio70 in forum Harley Trike Conversions
    Last Post: 10-15-2011, 03:56 PM
  3. Electric Fuse Box
    By drumdoctor in forum General Discussion
    Last Post: 09-27-2011, 12:31 PM
  4. Electric Reverse
    By Ironhorsepilot in forum Harley Trike Conversions
    Last Post: 02-16-2011, 12:42 AM
  5. Electric antenna
    By molinoman in forum Stallion Trikes
    Last Post: 09-13-2010, 04:19 PM
