ABA.I don't think people should be picking on you just because you look like you do,if that is you in the photo!
Now for your problem.This is something I played with for over a year going back to when the bike was a 2-wheeler.It is the shock,here's why.
The shock being mounted almost directly form the axel to the frame right under where your seat is mounted,will transmit any harsh impact to the frame area where the seat is mounted,thus transmitting it to your tailbone area and where you sit.Most bikes,the seat is mounted directly on the frame,except the Harley air ride seat used on police bikes.
I tried several ideas to isolate the seat from the frame,even had an heavt duty air pillow under ther for a while,it really helped,but developed a leak and didn't last long.
Progressive Suspension makes shocks that does not allow the harsh axle impact to get to the frame under the seat.I always had tailbone pain after a few hundred miles.
I put a Progressive 455 ,adjustable spring shock on the Wing and it was amazing difference in the ride and no more pain.The wife could tell the difference in the ride within 5 miles from home.
Our CSC conversion now has 2 Progressive adjustable shocks and I did play with the adjustments to get the best ride.
Maybe Progressive has a solution for you.
