Results 1 to 20 of 25
Thread: Rear Tire Pressure
    1500+ Posts
    salt lake city, ut
    Default Rear Tire Pressure
    I know that this subject has been beat to death....but I am hitting it anyway! On my Victory trike, with the standard Lehman "no lean" straight axle.....I am experiencing a jolting rear suspension. The dealer says that the suspension is set right, but when I go over RR tracks or cattle guards at highway speeds-it feels like my kidneys are being pushed through my sphincter!!
    I have experimented with tire pressure, but cannot find a better resolution between high and low. Right now I have 20 lbs in each rear tire, and have tried 22, 24, with about the same outcome. Any suggestions would be appreciated. One thing I have been trying to do is push up with my legs to ease the compression....but it's a pain in the a$$!
    Jun 2010
    Coram, NY USA
    Default Re: Rear Tire Pressure
    Since you ask for "any suggestions". I suggest you suck it up and stop being a woose!
    Apparently being forced to take my wife shopping in the truck, instead of riding has left me in a nasty mood. And yes, I am a woose also for giving in to the whining.
    1500+ Posts
    salt lake city, ut
    Quote Originally Posted by Bikerbozo View Post
    ....what the hell... who you talkin too.....
    1500+ Posts
    salt lake city, ut
    Quote Originally Posted by oahe View Post
    I generally just slow down.
    Real helpfull advise...I always slow down at least 10 MPH....
    1500+ Posts
    salt lake city, ut
    Well excuse me!!!
    .............there is no excuse for you..............
    1500+ Posts
    salt lake city, ut
    I also have a trike with IRS...and it is a Cadillac in comparison. I bought this trike for long hauls and club riding, because my other trike has apehangers and a built motor...so it gets pizz poor gas mileage.
    ....Just trying to figure out a solution, so I don't have to get a spinal decompression after each long ride!!!
    1500+ Posts
    salt lake city, ut
    Well aren't you just full of ambiance and good will! All I can say that if you're riding around here you'd darn better slow down for an auto gate and a bit more than to 10 mph or you just might be walking. A long way! Have a nice day!
    I hope your daddy takes his keyboard away soon........
    150+ Posts jackpoet's Avatar
    Dec 2012
    Alvin, Texas USA
    I think you have done what can be done. One question, do you have air shocks on the rear? What pressure do you run in them?
    [SIGPIC][/SIGPIC]
    96 Wing with Motortrike.
    Love to ride, Love this bike
    Dec 2012
    Alvin, Texas USA
    I have a Motor Trike on mine, move the air shocks up or down if riding two up or sing.e. Don't know if you have that.
    [SIGPIC][/SIGPIC]
    1500+ Posts
    salt lake city, ut
    Quote Originally Posted by jackpoet View Post
    No dual shocks at all-just a spring loaded shock in the center. Maybe I can research it, and figure out a way to loosen it a bit! Pic enclosed. Thanks Jack!
    1750+ Posts slick rick's Avatar
    Aug 2012
    Dora Al
    Really got nothing to do with your suspension but may help your spine,,DID MINE... I had a jel pad put in my seat . You can always fab pads to mount air bags on suspension for a few DOLLARS !!!!! GOOD LUCK
    1500+ Posts
    salt lake city, ut
    Quote Originally Posted by slick rick View Post
    Planning on that, meantime I put 25 lbs in the rear tires and will try it tomorrow...weather permitting!
    50+ Posts willom's Avatar
    Mar 2013
    killeen, texas, usa
    Don't know what kind of suspension the trike has, but my 06' glide with the air ride is running 50 lbs. in the shocks, which is much more than was used when it was on 2 wheels then taking about 15 lbs. It is not wonderful on rr tracks but is not a bad ride, smoother than when it was a bike.
    IF you don't go too far too fast, you won't get too lost too soon.:xzqxz:
    550+ Posts Mick's Avatar
    Feb 2008
    Midwest
    I run my Lehman shock on the middle setting unless Im towing a trailer and have the missus on the back. When I 1st bought her I asked the dealer what the shock wrench was for. They told me with the wings adjustable suspension I wouldnt need the wrench. Some preload on the shock is needed for the suspension to work correctly. Of course the shock was on the bottom setting. I can understand why that dealer went out of business. Be careful running your tires at 25psi. If you keep it there youll wear the center tread of the left side tire more than the right.
    Sep 2012
    Lakeland, FL
    Yikes, BadAss, you are a BadAss.....
    TOI - Michigan retdpd's Avatar
    Mar 2008
    Eastpointe
    I normaly run 24lbs on champion solid axle..if it helps you
    250+ Posts cscsonny's Avatar
    Dec 2011
    St.Louis,Mo.
    ABA.I don't think people should be picking on you just because you look like you do,if that is you in the photo!
    Now for your problem.This is something I played with for over a year going back to when the bike was a 2-wheeler.It is the shock,here's why.
    The shock being mounted almost directly form the axel to the frame right under where your seat is mounted,will transmit any harsh impact to the frame area where the seat is mounted,thus transmitting it to your tailbone area and where you sit.Most bikes,the seat is mounted directly on the frame,except the Harley air ride seat used on police bikes.
    I tried several ideas to isolate the seat from the frame,even had an heavt duty air pillow under ther for a while,it really helped,but developed a leak and didn't last long.
    Progressive Suspension makes shocks that does not allow the harsh axle impact to get to the frame under the seat.I always had tailbone pain after a few hundred miles.
    I put a Progressive 455 ,adjustable spring shock on the Wing and it was amazing difference in the ride and no more pain.The wife could tell the difference in the ride within 5 miles from home.
    Our CSC conversion now has 2 Progressive adjustable shocks and I did play with the adjustments to get the best ride.
    Maybe Progressive has a solution for you.
    250+ Posts SEABILL's Avatar
    Dec 2012
    Juneau, Alaska, USA
    A while back there was a thread on this subject (not sure if it was on the board). The theme appeared to be that folks were softening up the springs thinking they would get a better ride, when they should have been adding preload to keep them from bottoming out.
    Something to think about.
  19. #19
    1500+ Posts
    salt lake city, ut
    UPDATE...today I put 150 miles on, and with 25 lbs in each rear tire...it was a little better . That is the highest pressure I have ever run in either trike. I think I will have some gel put in my seat, and I may be able to live with it.
  20. #20
    1500+ Posts
    salt lake city, ut
    Thanks...wish I was "hardass" instead of badass!
  1. Rear tire pressure
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 11-14-2013, 05:11 PM
  2. mpg/tire pressure
    By geraldlanc in forum Honda Trikes
    Last Post: 01-05-2012, 02:43 PM
  3. tire pressure
    By steelman0933 in forum Honda Trikes
    Last Post: 07-21-2011, 10:08 AM
  4. tire pressure
    By Frang in forum Harley Trike Conversions
    Last Post: 06-14-2011, 08:45 AM
  5. Replies: 15
    Last Post: 12-22-2009, 11:19 PM
