LD-Ordie1LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Results 1 to 14 of 14
Thread: Rear Fender Removal
    5+ Posts bigb's Avatar
    Mar 2013
    Oxnard, Calif USA
    Default Rear Fender Removal
    I need to remove my left rear fender on my TriGlide and was wondering if anyone has any tips?
    Oct 2010
    USA
    Default Re: Rear Fender Removal
    its pretty simple from what i seen..remove the tire and then the nuts behind the fender.
    750+ Posts
    May 2011
    peru,in,usa
    why are you removeing them? new paint?
    Mar 2013
    Oxnard, Calif USA
    Found a small crack on the back side of the fender so I need to remove it to have it repaired.
    750+ Posts
    May 2011
    peru,in,usa
    when you get it off find the end of the crack & stopdrill the end with a 1/16" drill bit to prevent it from going further. then you can fill , sand & paint it.
    300+ Posts
    NE OHIO
    What year? I think the older ones were all one piece. My is a 2012 and is seperate.
    When the cayote hit me, it busted up the fender, and had to get a new one. The HD changed it and only charged 1 hr. But the factory painted fender was around $700.00 I think.?
    Mar 2013
    Oxnard, Calif USA
    it is a 2011
    Oct 2010
    USA
    are they not all a one piece fender???..which unbolts from the rear body of the trike..
    200+ Posts
    Aug 2010
    north
    OOPs,
    My current rides, all modified in some way.
    '10 107" Street TriGlide FLHXXX, '07 SoftTail Deluxe FLSTN, '07 Road King Custom FLHRS with Liberty Side Hack, '09 103" Dyna FatBob FXDF with Frankenstein rear, '18 FLSS SoftTail Slim, '19FLSB Sport Glide, '19 Freewheeler
  11. #10
    200+ Posts
    Aug 2010
    north
    [QUOTE=icebite1;161211]
    That is correct, all TGs from first year to date have fenders that unbolt from the box.
  12. #11
    Mar 2013
    Oxnard, Calif USA
    I took my fender off today it turned into a job 4 of the 6 Torx Bolts were stripped when they were installed at the factory so I ended up using a cut off wheel and cut them off.
  13. #12
    Oct 2010
    USA
    Quote Originally Posted by bigb View Post
    sounds like you got the hard part over..sorry to hear about the stripped bolts..
  14. #13
    May 2013
    las vegas nevada
    does anyone know what size torq tip they are
  15. #14
    150+ Posts JJHog's Avatar
    May 2013
    Pittsburgh, Pennsylvania, USA
    Are you sure they weren't tamper proof torx bolts?
  1. WTB Left Rear Fender Vivid Black
    By JJHog in forum Harley Tri Glide
    Last Post: 11-07-2013, 10:25 AM
  2. Tri Glide Rear Fender Bra?
    By Ohio Eddie in forum Harley Tri Glide
    Last Post: 06-06-2013, 11:57 AM
  3. Loose Rear fender
    By Paul_Trike in forum Honda Trikes
    Last Post: 09-24-2012, 06:55 PM
  4. Rear Fender Bra For Sale
    By Paw Paw Willie in forum Harley Trike Conversions
    Last Post: 02-14-2012, 11:39 AM
  5. Rear Fender Protection
    By Eveready in forum General Discussion
    Last Post: 01-29-2011, 10:24 AM
