Results 1 to 6 of 6
Thread: GPS - wired or battery?
    TOI - Massachusetts spiritdream's Avatar
    Sep 2008
    Central MA
    Default GPS - wired or battery?
    For those of you using gps units on your bikes/trikes - are they wired so you can use the adapter (like you can in a car), or do you just run them on battery? If they're wired, what kind of modification - if any - do you need to be sure there's enough "power" to run the bike and the gps (hope that makes sense)?
    In my uneducated non-technical English , do I need to change or add anything to the trike to make sure I have enough "oomph" to run the gps when riding? If I use battery power alone, I think the stupid thing only runs about 2 hours, so I may need to look at "wiring" it somehow.
    Cheri
    Let your dreams run wild....be brave enough to follow...Author Unknown
    TOI Member #103
    MA TOI Contact
    Rider
    Jan 2009
    United States
    Default Re: GPS - wired or battery?
    It's fairly easy to add a 12v supply (cig lighter) to just about anywhere on a bike or trike if you don't already have one. I see guys do it all the time for lighting smokes when they ride. If you add one in a less conspicuous place then you can use your 12v adapter but here's my question.
    How often do you really need to use GPS and for how long would you need to use it? I keep mine turned off for the most part and will only use it if I am unfamiliar with a certain stretch of road.
    To answer your question about power and battery... It will not affect the power (pulling HP or torque) of the bike at all. It may effect the battery charge if you leave it turned and it doesn't have an auto switch to it's own battery or your 12v adapter is powered at all times.
    When it is plugged into a 12v outlet that is switched via your key switch then the GPS will start up on it's own when you start the bike. When you turn off your bike the GPS will ask you if you want to continue using it on the internal battery or should it be turned off. Just hit the off button on the screen and walk away.
    Hope this helps even if a little.
    Contributing Member Lunchbox1983's Avatar
    South Carolina
    One note of caution if you are using a Garmin GPS and you want to hard wire it be sure to purchase the proper adaptor or you will burn it us, I think it only takes 4 volts or so, that is why the plug end is so big. Adaptors for hard wiring are available on line, ebay. I hardwired my bike because I use the GPS as an MP3 player and wanted to keep a plug free to charge my cell phone on log trips
    As Resuk stated most times you can make it on the GPS Battery alone.
    LunchBox :wave4:
    GL1500 RoadSmith
    Wife:
    2009 Stallion #580
    Candy Apple Red
    300+ Posts
    May 2009
    Nashua, NH
    Quote Originally Posted by Lunchbox1983 View Post
    Exactly what he said !
    I use a Garmin NUVI 500 which is waterproof and I hardwired the adaptor.
    I plug my GPS into it when I ride. I use a RAM mount to attach GPS to
    my handlebars.
    Rob .....
    Rider
    Jan 2009
    United States
    Hey Rob
    Did you know that Ram mount just came out with a new type of retainer? It fits under your left hand mirror shaft so you can get the clamp off of your bars. Pretty nice. You can get this piece to add to your mount for about 12 bucks.
    300+ Posts
    May 2009
    Nashua, NH
    Quote Originally Posted by reksul View Post
    Hey Rob
    Yes I use one of those on my left handlbar mirror mount. I am running
    fairing mirrors so the hole was empty.
    On the right side I use the one that uses the bolts for the handgrip.
    The mirror mount or bar clamp put the GPS too far to see it.
    On my Dyna I use a better looking clamp from Kuryakyn for my
    setups on that bike. Pictures are in my album.
    Rob ....
  1. New Battery
    By Baldy_54 in forum Honda Trikes
    Last Post: 11-17-2012, 07:49 PM
  2. 12v Battery Charger @ $6.98
    By ben721364 in forum General Discussion
    Last Post: 07-04-2012, 04:43 AM
  3. '09 t/g 22,146mi. battery chg.
    By eagle1 in forum Harley Tri Glide
    Last Post: 06-20-2012, 08:59 PM
  4. Battery Bug
    By Shimpy in forum Honda Trikes
    Last Post: 05-04-2012, 11:45 AM
  5. Gel Battery
    By docb in forum General Discussion
    Last Post: 03-17-2008, 02:44 PM
