Results 1 to 8 of 8
Thread: motor trike rearend question gear ratio
    50+ Posts MACHINIST15's Avatar
    Jun 2012
    BARNUM IA usa
    Default motor trike rearend question gear ratio
    i have a gold wing 1500 with a motor trike older classic conversion
    it has no tag on rear end , but pinion is gone
    it is a ford 7.5 rear end much like newer straight axle conversion
    i need to replace some parts , but don't know gear ratio ,
    308
    343....
    anybody know whats in theres sure even the 1800 are same ratio ?
    May 2011
    San Angelo
    Default Re: motor trike rearend question gear ratio
    I know some are 3.08 but don't know if they all are. You best bet is to call MotorTrike and ask them. You'll need the kit number that is stamped on the top of the input shaft housing. MotorTrike keeps records based on that number. Just in case you don't have their # it is (800) 908-7453.
    Good luck with the fix.
    2015 GL1800/Roadsmith HTS1800
    200+ Posts THEREALTRIKKY's Avatar
    Dec 2011
    Tyler, TX
    Quote Originally Posted by Gold Rush View Post
    Good advice Gold Rush!! However, if you look closely at those numbers, one of them will be followed by an "X"; this is the gear ratio - EX - 2.73X, 3.08X, etc... This will also save you from having to make a call when the information you need is directly on your bike!
    May 2011
    San Angelo
    Quote Originally Posted by THEREALTRIKKY View Post
    Thanks!!! I didn't know that... Never looked myself for those numbers since my conversion is an IRS and the number is in a totally different place.
    I'll remember that for next time.
    10+ Posts Luxo2r's Avatar
    May 2013
    Goose Creek, SC
    I have the 3.08 gears as I replaced with 2.73 in my wifes 1500SE last year. I'll make anyone a great deal!
    100+ Posts
    Jan 2012
    Ontario, Canada
    Hey Jerry, So where is the number on an IRS model? in case I need it.
    Take care.
    Black Metalic 07 GL1800 2012 Motortrike Adventure
    [I]GWRRA # 353526
    TOI# 00957
    May 2011
    San Angelo
    I can't take credit for this photo but it gives you a real good idea where to look. There is a support member just aft and under the differential. The four digit number is stamped into that support. It's pretty close to the center of the differential. Mine had lots of dirt on it so I had to wipe it off before I could read the number. Guess I shouldn't ride so many miles pepper
    Quote Originally Posted by Blackwillow View Post
    Take care.
    Sep 2012
    op ks.usa
    273 ford ranger in my 06 1800 highest gear they come in to bad Honda cant come out with a 6 speed trans.
  1. A question about Motor Trike shocks.
    By JaysGone in forum Honda Trikes
    Last Post: 05-19-2019, 03:33 PM
  2. Best final gear ratio for V Star 1100 trike ?
    By Pre-1898 in forum Yamaha Trikes
    Last Post: 08-21-2013, 07:31 AM
  3. motor trike rearend gear oil
    By driver10 in forum Honda Trikes
    Last Post: 05-28-2013, 10:48 AM
  4. Motor Trike Kit Question
    By Rebel in forum Honda Trikes
    Last Post: 08-24-2011, 10:41 AM
  5. Need help with gear ratio
    By REOFL in forum Honda Trikes
    Last Post: 10-05-2010, 09:42 PM
