Results 1 to 11 of 11
Thread: Brake fluid for Champion rear brakes?
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    Default Brake fluid for Champion rear brakes?
    I can't find anything on what type of brake fluid to use. Does it use the same Dot 4 as Honda uses for the front? I've got a 2010 Gl1800 with a conversion to S/A done in 2011. It uses VW pads.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
    Default Re: Brake fluid for Champion rear brakes?
    I do not have a gold wing conversion but I would bet that the DOT 4 was used. DOT 4 and DOT 3 can be used together but NOT DOT 5.
    1500+ Posts leo3wheel's Avatar
    Aug 2011
    Cranford, NJ, USA
    Maybe reservoir cap is labeled.
    Leo TOI #617
    (Jeannette)
    09 RSV Black on Red with Hannigan trike conversion
    Nov 2011
    <div class="bbcode_quote">
    <div class="quote_container">
    <div class="bbcode_postedby">
    <img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>leo3wheel</strong>
    <a href="showthread.php?p=170188#post170188" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
    </div>
    <div class="message">Maybe reservoir cap is labeled.</div>
    </div>
    </div>
    </div>No, it's still the original Honda Goldwing. This is a pet peeve of mine. The trike kit manufactures don't want to release any infor for you to do it yourself. I'm speaking of Champion of which is the only experience I've known.
    LES
    Prowler # 67
    Iron Butt #33529
    Aug 2011
    Cranford, NJ, USA
    Hmm... Just assumed our original rear fluid reservoir is being used for our Hannigan brakes. Looked around and didn't see another reservoir. If they use the original reservoir, then the original markings should hold true.
    Leo TOI #617
    (Jeannette)
    150+ Posts Teal's Avatar
    Jun 2011
    tenn
    i would follow the GL 1800 spec for the master cycl. its been working 4 me
    1500 2011 Champion trike
    KR4VA
    US Navy Aviation
    Surely Goodness and mercy shall follow you all the days of your life:)
    Nov 2011
    <a href="showthread.php?p=170275#post170275" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
    </div>
    <div class="message">Hmm... Just assumed our original rear fluid reservoir is being used for our Hannigan brakes. Looked around and didn't see another reservoir. If they use the original reservoir, then the original markings should hold true.</div>
    </div>
    </div>
    </div><div class="bbcode_container">
    <img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>Teal</strong>
    <a href="showthread.php?p=170285#post170285" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
    </div>
    <div class="message">i would follow the GL 1800 spec for the master cycl. its been working 4 me</div>
    </div>
    </div>
    </div>I guess what both of you are saying is that the master cycl. is what determines what type of fluid? I've always been courious of this and wonderer if the rest of the system had any influence on it.
    LES
    Prowler # 67
    Iron Butt #33529
    Nov 2011
    Quote:<br />
    Originally Posted by leo3wheel <br />
    Hmm... Just assumed our original rear fluid reservoir is being used for our Hannigan brakes. Looked around and didn't see another reservoir. If they use the original reservoir, then the original markings should hold true. <br />
    <br />
    Quote:<br />
    Originally Posted by Teal <br />
    i would follow the GL 1800 spec for the master cycl. its been working 4 me <br />
    <br />
    I got an answer from Champion and they said use whatever it says on the master cycl. resevoir. I'd be courious what makes a system dot 3 or dot 4.
    LES
    Prowler # 67
    Iron Butt #33529
    30+ Posts Doorman's Avatar
    Oct 2010
    Alto,Mi. USA
    I have been told that the difference is how much heat the calipers can create. Dot 4 will be better in larger calipers.
    :wave4:
    200+ Posts THEREALTRIKKY's Avatar
    Dec 2011
    Tyler, TX
    As far as the differences, there are a few.. DOT 3 is very common in the automotive world as the fluid doesn't need the increase in temperature stability that motorcycles do since motorcycle brakes create much more heat that automotive brakes.<br />
    Now, what most DO NOT realize, is DOT 4 also wicks moisture into it, which is why DOT 4 brake fluid containers say to discard any unused. It's also why in manuals, they tell you to flush the fluid every 2 years, or so many miles. When water gets into the brake lines and works its way to the calipers, it can create steam in the line causing excessive brake fade and even failure. <br />
    <br />
    DOT 5 is my personal preference because it's overall a better fluid, but more expensive and IN NO WAY compatible with DOT 3, or 4 fluids.. Which means you must fully flush your entire system before making the change to DOT 5. Dot 5 has a higher temperature resistance as well which is why it's especially ideal on high performance motorcycles as well.
    Nov 2011
    Quote Originally Posted by THEREALTRIKKY View Post
    As far as the differences, there are a few.. .
    Thanks, I've always wondered about this.
    LES
    Prowler # 67
    Iron Butt #33529
  1. Brake fluid
    By roscoe 07 in forum Honda Trikes
    Last Post: 06-26-2013, 07:08 AM
  2. Champion rear brake issue
    By scribe5 in forum Honda Trikes
    Last Post: 05-22-2013, 01:49 PM
  3. Brake Fluid Replacement on Champion
    By Shimpy in forum Honda Trikes
    Last Post: 02-05-2013, 02:18 PM
  4. Brake fluid replacement on Champion.
    By Shimpy in forum Champion Trike
    Last Post: 01-25-2013, 04:10 PM
  5. Brake switch recall...NO REAR BRAKES!
    By rwhgme in forum Harley Tri Glide
    Last Post: 11-18-2011, 04:13 PM
