Results 1 to 10 of 10
Thread: Electronic tech needed!
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    Default Electronic tech needed!
    My Hiney, is rather chaffed!
    Mother Harley in her infinite wisdom no longer produces the fuel guage sending unit to fit my 1989 tour glide part # 75040 and i have had absolutely no luck in obtaining one! I have been trying for two months. I did buy a used one that had the same problem as mine, but thats another story!
    It's time to explore different avenues.
    The very small wires in the squirrel cage that transmit the signal are broken.
    The rest of the sending unit is fine.
    You know i'm willing to bet that harley davidson didn't make the half moon shaped wire cage that the sending unit uses to register?
    Heck it's probably made in china?
    I would almost bet that that same wire cage is used in other applications?
    ARE THERE ANY ELECTRONIC TECHS OUT THERE THAT COULD HELP ME OUT ON THIS?
    I bet Someone makes that particular little part of that sending unit.
    If i could find out who, and figure out a part #, i would have half my problem solved?
    Then i would only have the luxury of trying to obtain one little part instead of a whole sending unit?
    Any ideas about who i could take that unit to that may be able to take it apart and re-wrap the wires?
    __________________
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    Default Re: Electronic tech needed!
    Harley might be able to tell you since they no longer service the part who made the part for them.
    Just getting someone to care might prove a problem.......
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
    Oct 2010
    USA
    Not sure if these guys can help or not??
    Rebuilt Fuel Sending Unit Specialist
    50+ Posts
    Feb 2012
    CHISHOLM MN USA
    http://www.narleychoppers.com/images...oppersLogo.jpg
    Go to this dealers web site, it looks like they have it or the replacement for it.
    Feb 2013
    casper,wy. usa
    I love it! i shot them an email. Thank all of you for your efforts on my behalf!
    Paul
    Feb 2013
    casper,wy. usa
    Quote Originally Posted by Sloufoot View Post
    yep! thats the problem!
    Feb 2013
    casper,wy. usa
    Attachment 8297
    Attachment 8298
    Attachment 8299 click pics to enlarge
    Attachment 8300
    Here are pictures of what i am talking about.
    Is that plastic piece called a rheostat?
    There are very small wires in the bottom of the plastic peice that are broken.
    Feb 2013
    casper,wy. usa
    I found out that the rheostat is wound with a nickel chromium wire.
    Does anyone know what it is coated with?
    Feb 2013
    casper,wy. usa
    Here is a copy of the conversation between myself and a wire dealer.
    What do you think?
    He talks more about a coating holding the wires in place, rather than a special coating for spark arresting?
    I have sold nichrome wire to other people that were redoing their fuel guage
    sending unit so probably yours uses nichrome, too. You would need to use
    exactly the same gauge as the original for it to work properly so you would
    need to measure the diameter with a micrometer or calipers. Since I only
    sell bare nichrome wire, you would need to make sure that two adjacent coils
    don't touch each other so would need to wind it with string between the
    coils or some other strand for spacing. The existing one probably has a
    coating on at least a portion of the coils to keep them in place and you
    would need to do the same and I have no idea what kind of material is used
    for the coating. Search the internet for sending unit rebuilding or
    something like that and maybe someone mentions how they do it and what they
    use for a coating, even though the sending unit they are talking about is
    for a totally different vehicle. Good Luck, hope this helps some.
    Regards,
    Gary Jacobs
    Jacobs Online LLC
    jacobs-online.biz
    -----Original Message-----
    Sent: Friday, July 5, 2013 3:06 PM
    To: sales@jacobs-online.biz
    Subject: what is proper wire?
    Harley davidson no longer makes the fuel gauge sending unit for my 1989
    tour glide motorcycle.
    I cannot find a replacement and can't seem to find out who made the
    rheostat.
    The wires in the rheostat are broken.
    I would like to rewire the rheostat on the fuel gauge sending unit on my
    old Harley Davidson. What would the proper type of wire be as it sit in a
    fuel tank.
    Do you know what the size might be by chance?
    I have had a terrible time trying to address this problem.
    Thank you for your efforts on my behalf.
    Paul Combe
  11. #10
    Feb 2013
    casper,wy. usa
    Here is a copy of a conversation i Had with Jacobs. He talks more of a coating to hold the wires in place than for spark arrest.
    What do you think?
    Quick set epoxy on the backside of the rheostat?
    Regards,
    Gary Jacobs
    Jacobs Online LLC
    jacobs-online.biz
    rheostat.
    fuel tank.
    Paul Combe
  1. Are there any electronic techs out there?
    By pcombe in forum General Discussion
    Last Post: 07-08-2013, 02:16 PM
  2. Replies: 3
    Last Post: 04-03-2013, 03:11 AM
  3. Champion Tech Service
    By meredog in forum Champion Trike
    Last Post: 11-07-2010, 03:08 PM
  4. New Tech Article
    By Nana in forum General Discussion
    Last Post: 01-22-2010, 01:06 PM
