Results 1 to 20 of 27
Thread: Reverse not working
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Default Reverse not working
    Reverse quit working for me a couple of days ago.
    It is not the breaker, the reverse motor is secure, all wires that I can see and feel are tight.
    When I push the reverse button I see the voltmeter drop, and hear a small click, but no other noise or action.
    To further complicate things, out of the last 15 or so times I have tried it, it worked twice.
    Any thoughts?
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    Default Re: Reverse not working
    Quote Originally Posted by TG-Kevin View Post
    Any thoughts?
    Be sure & manually trip the breaker with the red button on top, then reset the lever firmly sideways. Also check the cables connections. Check the voltage at the solenoid, & across the breaker terminals. Your voltage drop could be just the solenoid coil. If that don't work let the dealer solve the problem. That is what your warranty is for if you have any. If not raise a little hell about the problems with the infamous Harley reverse. There is an upgraded motor that they sent out to replace the failing motors. There have been motors replaced even after warranty. They have failed before...... It mostly depends on your dealer, or maybe you should call MOCO direct & complain to them about a piece of junk.
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Sloufoot View Post
    Be sure & manually trip the breaker with the red button on top, then reset the lever firmly sideways. If that don't work let the dealer solve the problem. That is what your warranty is for. They have failed before......
    Yeah, I've manual tripped it and reset it half a dozen times.
    Stopped at 3 different dealers going thru Canada, no one has a clue and I don't want to wait a day or two in my trip while they may or may not figure it out.
    In the meantime I am being careful where I park, and if I can't get it working before getting home, will let my dealer at home sort it out.
    Oct 2010
    USA
    sounds like the motor from what you are decribing..Hard to troubleshoot from a computer too..Unless you can locate a volt meter and check the input and output voltage at the breaker..
    Have fun on the trip and enjoy the ride for now..
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    I agree, sounds like something with the motor. I'd avoid messing with it anymore while on a trip unless I have a desire to become stranded for several days in a town I only wanted to pass through.
    200+ Posts patriot's Avatar
    Jun 2008
    Hampton, GA
    Sounds like the problem I had. R&R the control relay, problem fixed.
    Great people are common people who have committed themselves to uncommon goals.
    Dr. Robert Schuler
    2012 Tri Glide Ultra Red SunGlo/Marlot
    tGlide Wind Deflectors, Lift Kit, Tour Box Kit
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Thanks guys...will wait til I return. Thought I might have been missing an easy fix.
    200+ Posts sprinkman's Avatar
    Sep 2011
    Ashland,Ohio USA
    I think my motor went out this weekend. I had it replaced once in 2011.When did the upgraded one come out. I have the extended warranty or is this something that should be changed on their dime.
    Oct 2010
    USA
    Quote Originally Posted by sprinkman View Post
    new one will has a tube close to one end of the reverse motor..bring it in if under warranty..for over 1K on the mtr let them do it..
  11. #10
    Sep 2009
    NE Ohio
    Let the extended warranty foot that expensive bill.
  12. #11
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    Sounds like the same problem I had. Dealer first said it was the clip that held the gear on, wrong. Then he said it was the solenoid relay, wrong. Then he finally said the motor, right. All of this took him 2 weeks because he had to order each part each time. I am an electrical engineer and told him in the beginning it was the motor. So he kept the bike for two weeks trying all his crazy troubleshooting methods instead of checking the motor. They ended up putting a used motor from a trike that had been traded in. It was the same year bike at least and has worked now for over a year.
    Problem was in the beginning it would work sometimes and then just kept getting worse until it would not work at all.
    Rear lift kit, and tour pak relocation, Road Zepplin Air seat, Chrome front forks, SE 120 ST engine, Headers by V&H, Stock mufflers, SE 259E cams, TTS tuner and SE Air Cleaner, 58 mm Throttle Body, Tank lift, Wind Deflectors, DIY Crankcase Breather, Floorboard Ext.
    Amateur Radio : W4WNG
  13. #12
    40+ Posts
    Oct 2012
    W.Paducah Ky. U.S.A.
    Mine quit working today .Checked it out motor is bad took it to dealer they agreed motor is bad . New upgraded motor on the way. dealer said my motor had vent that allowed water to enter motor. upgraded motor has vent tube to prevent water from entering it. warranty covered $1500.00 problem.
    Semper-Fi
    68-71
  14. #13
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Hmmm, well with what we have been riding thru, would not surprise me if MUD was in there!
    I have been careful with my parking and will get it to the dealer after we return.
  15. #14
    100+ Posts
    Feb 2010
    Charleston, SC
    Mine quit yesterday. Dealer says he will fix it under extended warranty but will take ten days to get the parts !
  16. #15
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Finally got around to taking the TG into the Dealer today. It is the motor. They have a new one on order. When it comes in I will take the TG back in for them to install it under the extended warranty.
    They also found that one of the heim joints on the panhard rod was bad. HD does not sell just the heim joints, so am getting the entire panhard rod replaced under the extended warranty.
    www.DKCustom.com
  17. DKCustoms postbit
  18. #16
    100+ Posts Krautster's Avatar
    Jul 2013
    Holly Springs, Ga.. USA
    im glad I went to a manual rev when I had my kit put on.. read all the bad points here
  19. #17
    Oct 2010
    USA
    The factory trikes dont give you any choice..electric..thats it..
  20. #18
    150+ Posts bullet 10's Avatar
    Oct 2010
    climax springs,MO
    Why can't these reverse motors be rebuilt ?
    ttom, wife and triglide:clan:
  21. #19
    Jul 2012
    Chubbuck Idaho
    Quote Originally Posted by bullet 10 View Post
    No doubt you can do just that. Harley does. In fact I would bet there are other motors that would work in it's place. Probably one with more power. Seems odd that no one has offered an after market motor, IMPROVED !
    A lot less than $1300-$1400 !
  22. #20
    Jun 2010
    Coram, NY USA
    The weird thing is that after I had all my initial problems with reverse on my '10 TG, they replaced switch, breaker and motor with a stronger one.I haven't had a problem in years. I would have thought all newer bikes had that beefier stuff initially. Maybe they are using up old stock and hoping for the best.
  1. A/C not working?????
    By Backdraft in forum Stallion Trikes
    Last Post: 09-27-2013, 07:30 PM
  2. Not all of us were working today......
    By werewolf in forum General Discussion
    Last Post: 05-21-2013, 09:51 PM
  3. Working under the trike
    By dadorfman in forum General Discussion
    Last Post: 04-14-2013, 10:42 AM
  4. Calendar is working
    By Lucky in forum General Discussion
    Last Post: 01-06-2013, 02:15 AM
  5. 2009 Reverse not working
    By tri glider in forum Harley Tri Glide
    Last Post: 08-14-2012, 04:19 PM
