Results 1 to 8 of 8
Thread: Tri-Glide Oil Filter Removal
    Jul 2009
    Tallmadge, Ohio
    Default Tri-Glide Oil Filter Removal
    Just received my 2010 Ultra Tri-Glide, Runs great, but usually change oil at 500 miles, then take it in for the 1000 mile checkup as usual.
    I noticed there is not much room between the filter and the crank position sensor. Has any one removed the filter without removing the position sensor first? The oil cooler adapter moves the filter closer to the sensor than on non oil cooled bikes.
    150+ Posts
    Feb 2008
    Kansas
    Default Re: Tri-Glide Oil Filter Removal
    Motorman,
    Sorry to say, but just bite the bullet and buy the special oil filter wrench from your local HD shop. It's still a pain in the ---to do, but at least it's doable.
    Dwight
    Jul 2009
    Tallmadge, Ohio
    I have a HD strap wrench, but was concerned about how far the filter unscrews before being able to take it out completely., The strap wrench will not come close to the position sensor, so the wrench part of it is not the issue.
    700+ Posts BlueTrinity's Avatar
    Apr 2008
    Central Pennsylvania
    Quote Originally Posted by motorman7 View Post
    Get the HD filter removal tool. It will cost a few bucks but is worth its weight in gold for the time and grief it saves. With the cooler in place it is virtually impossible to use anything else without first removing the sensor.
    Dave
    Those voices in my head may not be real, but they have some really good ideas.
    There is just enough room to tilt the filter as it reachs the end of the threads to clear the sensor.
    Jul 2009
    Tallmadge, Ohio
    Thumbs up Re: Tri-Glide Oil Filter Removal
    Thanks tmigala that's what i was looking for. Even if i could get the filter off with my bare hands i was wondering if it would clear the sensor. Excellent news, as i hate to remove parts unless necessary.
    Thanks again!
    Jul 2009
    Tallmadge, Ohio
    Purchased one of the cutout oil filter wrenches from dealer part # HD-44067A made by Kent-Moore. This company makes a lot of HD tools and it is a quality item.
    I did my 500 mile oil change and the wrench worked great, no clearance problems with engine and the filter came off without a problem with the crank position sensor.
    I used a 6 inch extension on my rachet to clear the shift linkage.
    Cool motorman
  1. Seat Removal
    By VSTriker in forum Honda Trikes
    Last Post: 06-23-2013, 12:01 AM
  2. Backrest removal Tri glide
    By JIMSFLH in forum Harley Tri Glide
    Last Post: 06-22-2013, 07:13 AM
  3. Oil filter leaking on tri glide
    By Bagger in forum Harley Trike Conversions
    Last Post: 05-01-2013, 11:23 AM
  4. Trunk removal
    By SMSgt in forum Honda Trikes
    Last Post: 03-26-2013, 11:08 PM
  5. Windshield removal
    By JimEd in forum General Discussion
    Last Post: 05-24-2009, 02:39 PM
