LD-Ordie2Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11Jack KlarichNew Member Introduct...New member from FL
ADSavarese11woodyNew Member Introduct...New member from FL
LD-Ordie2LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11hardwickbvNew Member Introduct...New member from FL
ADSavarese11ol' schoolNew Member Introduct...New member from FL
ADSavarese11GorillaNew Member Introduct...New member from FL
ADSavarese11Marc HNew Member Introduct...New member from FL
ADSavarese11ADSavareseNew Member Introduct...New member from FL
ADSavarese11Phu CatNew Member Introduct...New member from FL
ADSavarese11trike ladyNew Member Introduct...New member from FL
ADSavarese11Uncle FesterNew Member Introduct...New member from FL
ADSavarese11rhino 2New Member Introduct...New member from FL
Likes Likes:  37
Thanks Thanks:  2
Page 3 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 41 to 60 of 289
Thread: starting my 3.8 v6 super charged trike build
  1. #41
    450+ Posts irmagoo's Avatar
    Dec 2012
    washington il.
    Default Re: starting my 3.8 v6 super charged trike build
    Quote Originally Posted by Dragonponics View Post
    Great build I will fallow this one I have a 04 impala I wrecked and have been thinking of doing the same with it just didn't know where to start
    hey dragonponics
    hows the world treating ya??
    glad this got you think'n... i hear that texas has a problem with home built projects... it that true?
    hope its not and you get something going !!
    magoo
  2. #42
    May 2014
    Belton,tx
    Well there is a lot of red tape to go through but not to bad
  3. #43
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    Same here on rebuilding wrecked Vehicles with Insurance Company Salvage Titles...can still be done, but the Laws and Restrictions keep getting tougher and tougher.....
  4. #44
    Dec 2012
    washington il.
    well its Thursday.. been over to sons shop cut up another 20 foot of 2x2x1/8 tubing this should be the end of square tubing...this will enclose gas tank etc. on to bending up some round from here on i think.
    I have been busy working on the boring stuff on trike project where/how to mount gas tank, rad, fuel pump stuff like that once i make a little real progress i'll post some pics,,
    also been looking at seats found some nice looking seats at appletreeauto.com,, they call them "race trim seats" black vinyl at around $200.00 each has anyone had any experience with appletree or these seats??
    well folks it'll be a week or so before i get much done- wife is getting knees replaced. she will keep me jump'n and out of shop I'm sure....
    this surgery is what is keeping us from coming to ark. for the rally... we like it over there beautiful area and hope to make it next year..
    more later....
    magoo
  5. #45
    1750+ Posts slick rick's Avatar
    Aug 2012
    Dora Al
    Tell the wife best of luck ,,one of my sisters just had one replaced last week .
    we all have our faults .....others point them out to us......guess we know what theirs are
  6. #46
    Apr 2010
    GOOD LUCK to our Wife on Her Surgery....
  7. #47
    Dec 2012
    washington il.
    thanks for well wishes for wife!!
    she's home and doing great...
    I even got to sneak away to shop and work on a motor mount...
    the side mounts were part of car sheet metal ...long gone it all got to get done you just don't see any progress when you look at the project!!
    magoo
  8. #48
    Dec 2012
    washington il.
    well the wife gave me few hours off today(she took a nap) for good behavior
    so... off to the shop I went,, the motor mounts are about finished
    1. right side mount.. needed to be removable to change belts..
    2. another angle of mount I think you can see how tight it is and it needed to be offset some to clear everything ..I will add a piece of tubing to tie in at top like you will see on other side
    3. left side mount this end is attached to motor mount and mount is attached to chain housing..
    4. you can see it needed to be offset to miss spring/strut that I moved in 2.5 inch...
    5. you can see that I make this mount removable also that way if I need to jack up other side to change belts I will have a little more side motion...the engine/trans are fully isolated on all 4 sides at last!
    slow going but moving forward!!
    magoo
  9. #49
    Aug 2012
    Dora Al
    ,,,Glad to hear the wife is doing well ,,and good work on the build . I'm really looking forward to see how this turns out , keep us posted on progress .
  10. #50
    Apr 2010
    Quote Originally Posted by slick rick View Post
    "DITTO".....
  11. #51
    Dec 2012
    washington il.
    worked on trike today...removed the power steering pump and a/c compressor will use a a/c delete pulley, shorter belt, grooved idler and change the way belt is run ...also built the base for radiator and mounted fans... not to exciting just work..waiting on more steel should get Monday or Tuesday I'll start on front half of trike can't wait !! guess I need to order seats.....
    magoo
  12. #52
    Dec 2012
    washington il.
    well the seats are on the way ...metal didn't show up ...guess I get it when I get it..
    magoo
  13. #53
    Aug 2012
    Dora Al
    ,,,Tomorrow is another day my friend !!!
  14. #54
    Apr 2010
    Quote Originally Posted by irmagoo View Post
    magoo
    Late Material Arrival used to drive us crazy when I built Race Cars....."I wanna' build it, and I wanna' build it now"..........Good Luck on Your Metal Arrival.....
  15. #55
    Dec 2012
    washington il.
    Quote Originally Posted by skuuter View Post
    hi skuuter
    waiting on material for frame, waiting on new belts, pulleys, a/c delete and more...
    now this morning wife said" maybe you should put a/c on trike like stallion has"
    ....I said well lets worry about that after I finish the build...
    we have been riding for 45 years or so together with out a/c...for 30 years or so I would not have a radio
    guess the world is changing..... not sure I'll catch up!!
    magoo
  16. #56
    Apr 2010
    hi skuuter
    magoo
    "HI".......have You thought about Cruise Control, installing Windows just so You can electrically roll em' up and down, maybe actual power steering, etc. ...........no worries, I won't suggest it to Your Wife.........
  17. #57
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    No ruff sketch of the layout yet?
  18. #58
    100+ Posts butchvoss's Avatar
    Jul 2013
    patrick SC
    i cant wait to see this build. If you do power steering, share the plans .lol
  19. #59
    Dec 2012
    washington il.
    hey no power windows what will we do !!
    I think it will not need power steering with proper front end geometry...so that's what i'll shoot for!!
    and yes I do have a ruff draft...vary ruff!! i'll try and clean it up and post it. until then heres the seats!!...and...,
    no!!
    the tv is not for the trike, I may try installing ice maker under you know who's seat!!
    cut steel this afternoon will weld in the am!! I'm pumped....well
    ok as close as an old guy can get to being pumped
    magoo
  20. #60
    Dec 2012
    washington il.
    ok its not much but heres kinda how I see it..
    like I said drawing is ruff but hope you can see where i'm heading.. its not chiseled in stone.. may change some I would like it a little shorter in the wheel base..
    magoo
  1. Super Brace on a trike
    By Bill Reber in forum Honda Trikes
    Last Post: 01-24-2016, 12:05 PM
  2. SUPER BRACE on a Gold Wing 1800 Trike Report Thread
    By skuuter in forum Honda Trikes
    Last Post: 07-26-2014, 02:58 AM
  3. starting a new build
    By Wayne D in forum Home Built Trikes
    Last Post: 01-28-2012, 06:33 AM
  4. just starting
    By trikefan in forum New Member Introductions
    Last Post: 09-23-2011, 06:49 PM
  5. Trike coversion is finally starting
    By Ndvtxrdr in forum Honda Trikes
    Last Post: 02-15-2011, 02:46 AM
