ADSavarese1ADSavareseNew Member Introduct...New member from FL
dthorn1dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
Likes Likes:  0
Results 1 to 14 of 14
Thread: proper lean
    5+ Posts
    Apr 2012
    boynton beach fl usa
    Default proper lean
    I am new to Trikes, and was wondering re leaning when in a fast, sharp turn, to help counter-balance the feeling, imagined or real, that you and the trike are being thrown to the outside?
    800+ Posts SMSgt's Avatar
    Sep 2012
    Cedar City, Utah, USA
    Default Re: proper lean
    I lean, to the inside of the turn, in fast sharp turns, probably more out of habit than necessity, and sometimes even apply some extra pressure to the inside floorboard. There is a thread on turning you might want to give it a look see there is some great info there. It helped me when I was first trying to figure things out. http://www.triketalk.com/forum/honda-trikes/1065.htm
    Lost In The 50's rmrc51's Avatar
    Feb 2009
    Palmyra, Virginia
    Thumbs up Re: proper lean
    Quote Originally Posted by SMSgt View Post
    Ditto!
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    It's real hard to overcome the urge to lean but it is not necessary if you have the suspension setup to minimize body roll and can keep your body "mid-ship" allowing better control of the trike.
    As mentioned putting increased pressure on the outboard foot helps keep you centered and setting up. Also gripping the inside leg/foot/knee against the side of the trike helps. I've found when I have my feet out on the highway pegs it's even easier.
    Fine-tuning you technique for riding curves will make it even easier and much more enjoyable. If you haven't already, take a look at that thread SMSgt mentioned. There is a wealth of experience there.... Some of the ideas work for everyone some only for some riders. Choose what works and ENJOY !!
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Maybe it's just me, But i drive my T/G like it's supposed to be driven' It's not a sportbike. I sit bolt upright in turns and use very little body english. I guess i got the burning the corners riding over with ten years ago on sportbikes, Thats why i ride Trikes, I want to smell the roses and not low side into them.
    2019 Tri-Glide.......
  6. #6
    1750+ Posts Trent's Avatar
    Jul 2011
    Meridian, ID. USA
    Some of us still like to burn the corners!!!
    2011 Cool Blue TriGlide with full stage 4, a lotta other upgrades, and a lotta shiny stuff.
    Hi..My name is Trent and I am a Chromaholic.
  7. #7
    1500+ Posts
    Oct 2011
    salt lake city, ut
    ...I think it can be affected by the type of suspension you have. I find myself leaning toward the inside of a curve on my trike with IRS (which leans a bit more than a straight axle).
    ...With my trike that has the Lehman (no lean) straight axle...I find my self not leaning much because it doesn't lean....
  8. #8
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    Look as far through the corner as You can EVERY TIME...seriously...this will help get rid of the "I'm Leaning The Wrong Way" feeling that's common when You start riding Trikes. As suggested above, take some of the roll/lean out of the Trike...this does help also, but remember, as You take out roll, You lose "road feel"...You can reach a point in this adjustment that the Trike's roll is so much stiffer that it can lose road traction without You getting that "early warning feel".....
    ..if it has WHEELS, I'm in...ThumbUp
  9. #9
    9750+ Posts Rod69's Avatar
    Dec 2011
    Lawrenceville Il. USA
    I find I am like rhino 2. Dont lean and try to drive sensibly.
    Rod69 Illinois TOI #900
    Joan71 Illinois TOI #901
  10. #10
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    My S/A trike doesn't lean in corners, but it's only natural to lean in to counteract the centrifugal force that wants to throw you to the outside.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
  11. #11
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Quote Originally Posted by Rod69 View Post
    I'm a pretty conservative rider, and I still find myself leaning instinctively to the inside of a turn. It seems to counteract the sensation that the inside wheel is lifting in a curve.
    "The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility, it's right. If it disturbs you, it's wrong until either the machine or your mind is changed." - Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
  12. #12
    600+ Posts berngren's Avatar
    Jun 2011
    Saginaw, TX
    To answer your question - It has to do with the experience of the rider. He must know his limitations. I always believe that safety comes first. You should learn the fundamentals of riding a trike first. That is so important. Once you have master them - then experience is the next thing. All turns are not the same. After riding for a while - experience will dictate what to do.
    Just take it easy in the beginning. First get familiar with turns - then you can slowly try different things that will make you comfortable. Speed is a factor in most turns - dependent on the terrain. Personally - I take turns slow because I'm in no hurry - and I'm out to enjoy the ride. I can take turn fasts if I choose to - but I don't.
    My advice is - learn to ride the trike - understand what the trike is capable of doing - and practice fundamentals maneuvers in turns. You may have to slow down in the beginning while you are learning. Eventually - you'll pickup your speed after awhile.
    Ride safely and take it easy. You'll be alright after that.
  13. #13
    May 2011
    San Angelo
    Quote Originally Posted by berngren View Post
    VERY WELL SAID !!!!!!
  14. #14
    800+ Posts FLTR2008TRIKE's Avatar
    Sep 2009
    Near Myrtle Beach SC
    Body weight and position will dictate center of gravity on your trike until the force overcomes it with too much inertia involved.
    Learning to use your weight by leaning into a turn slightly, using your strength with both your arms and shoulders to push/pull to steer along with your legs to hug the frame and push down on your floorboards will help you control your trike in most situations.
    One other thing that many dont consider is having to control your trike in a sudden stop situation. Its best to take the time to find a empty parking lot and practice stopping in a turn going both directions. This will give you a feel for how the trike responds and will give you the opportunity to learn this without having to deal with it in a real situation at the last second.
    Overcoming Adversity is the path to better ideas!!
    2008 Roadglide w/ MOTOR TRIKE Kit
    S&S 124" Headwork & Custom designed cams by John
    Custom made right side shifter (Lost my left leg above the knee due to a hit n run driver) SOOS's custom made floorboard spacer
  1. Long and Lean in Tennessee
    By V-driver in forum Trike Builds
    Last Post: 06-02-2015, 10:42 AM
  2. No-Lean vs Independant suspension
    By baitman in forum New Member Introductions
    Last Post: 09-13-2013, 07:46 PM
  3. To Lean
    By trike1 in forum Harley Trike Conversions
    Last Post: 04-29-2011, 06:14 AM
