Results 1 to 4 of 4
Thread: Best final gear ratio for V Star 1100 trike ?
    20+ Posts
    Jul 2013
    Casselman,Ontario Canada
    Default Best final gear ratio for V Star 1100 trike ?
    I am presently in the process of converting my 2000 V Star 1100 to trike. I am using a a narrowed 1991 Ford mustang differential. Now I have the choice of 3.73 and 2.73 gear ratio. Can anyone tell me which gear ratio would be best ?
    350+ Posts
    Aug 2009
    Wayne, Mi USA
    Default Re: Best final gear ratio for V Star 1100 trike ?
    For comparison I had a 05 Venture with a Tri-Wing conversion. That bike had a 3:42 gear ratio. It raised the rpms at 70mph about 250 rpms over the stock gearing. I now have a Hannigan trike which uses a 3:73 gear ratio and that raises the rpms to about 500 rpms over stock at 70mph.
    Comparing the performance between the two bikes, I prefer the 3:73 gearing, especially when towing my trailer or riding in mountainous areas. The 3:42 gearing required more down shifting, but it did give a slight edge to gas mileage when just out riding.
    Larry
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Larry has much more trike experience and understands the required changes much more than I do.All I can add is the stock ratio is 2.875.Keep in mind your choice in tire diameter will affect your actual difference.
    750+ Posts
    Jan 2010
    east windsor ct
    there is no exact science here, i would go with the one that is closest to stock then choose the tires that will make the result a slightly higher ratio.that is.. about 200-500 rpm higher at about 60mph you might find a couple tires at the junk yard to try for size before spending the $ on a set that dont work
  1. V Star 1100 trike rear tire size ???
    By Pre-1898 in forum Yamaha Trikes
    Last Post: 01-13-2015, 08:05 PM
  2. My own trike conversion for V Star 1100
    Last Post: 05-18-2014, 07:25 PM
  3. Need trike exaust adaptor kit for V Star 1100
    Last Post: 08-03-2013, 05:26 PM
  4. motor trike rearend question gear ratio
    By MACHINIST15 in forum Honda Trikes
    Last Post: 07-22-2013, 10:52 PM
  5. Shadow Final Drive Ratio, Anyone?
    By geputten in forum Honda Trikes
    Last Post: 10-09-2012, 07:45 PM
