ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Results 1 to 15 of 15
Thread: Service Bulletin Rear Brake Rotors
    100+ Posts delta's Avatar
    Mar 2012
    Manchester, NH
    Default Service Bulletin Rear Brake Rotors
    For your information:
    http://sdrv.ms/1d0uCqA
    Hopefully the link to my Sky Drive works.
    2012 Trike, FM107, Wood 555 cams, CNC "B" Heads
    Rider
    Jan 2009
    United States
    Default Re: Service Bulletin Rear Brake Rotors
    Works fine... thanks
    Jun 2010
    Coram, NY USA
    Keep in mind that bulletin was amended end of June. Look for my post under "Brake Noise..." on Sept. 6th where I posted a copy. On a quick glance, the difference looks to be about who is covered. They just added an "A" to the end of number.
    Mar 2012
    Manchester, NH
    Just saw where you did post this. Never hurts to keep the info flowing I guess. I recently changed my pads to the Lyndall Golds and solved all my problems. So it looks like with no noise, this doesn't apply to me. Still glad I went with the Golds.
    Rider
    Jan 2009
    United States
    My Golds are on the way. Already have Z's on the front. My dealer will simply swap out my rotors by handing me the new style. I'll put them on. He knows how anal a Wizard can be.
    Jul 2012
    Wisconsin
    Last Weds. my dealer changed rotors to the new compound and installed the Lyndall gold pads. All I was charged was the difference in price of the pads. Very happy with the results.
    100+ Posts
    Punta Gorda Fl
    Wiz, In the bulletin it says for the tech to check for "off brake" noise. I'm assuming this means getting a noise from rear brakes without them being applied. Mine squeaks only when applied. Think they'll cover it under warranty? Willie
    Rider
    Jan 2009
    United States
    Sorry for the answer that I'm about to give but here goes.
    It will depend on your dealer. Some will, some will argue.
    Best thing to do is go ask them.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    I do not doubt anyone having brake problems on their TG. But I'm not going to let a dealership touch my brakes!
    My 2011 has close to 50K miles on it and I am on the original pads and they still have about 50% of the material left.
    They function fine. I practice emergency stops regularly.
    I can also lock up the front or rear brakes easily.
    Not sure what is different...but I had heard they wear quickly, so I have had some Lyndal pads for over 1.5 years now...just stitting on the shelf, waiting for when they are needed.
    www.DKCustom.com
  11. #10
    Sep 2012
    Lakeland, FL
    Yes, some/most dealerships are questionable at best. At $90/95 an hour they should be customer friendly and know what the hell they are doing. Got into one of those contests on the gl forum with some dude about that very subject. Finally put him on 'ignore'.....Go figure.
  12. #11
    40+ Posts
    Oct 2012
    W.Paducah Ky. U.S.A.
    Printed out the service bulletin went to dealer They weren't aware of the bulletin .New updated rotors and pads were installed got home pulling into garage brakes still squealed .Like someone on here said its a HOG and Hogs squeal You would think They could de-squeal a $30,000plus Hog. Does INDIAN make a Trike? A drum beat has to sound better.
    Semper-Fi
    68-71
  13. #12
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    Quote Originally Posted by usmc68 View Post
    Not yet for Indian. But everyone should keep quizzing them about it. Maybe they will get the Idea!
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  14. #13
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    I just had my trike serviced. The dealer said they would fix my brakes and they would be cover under the service bulletin. Then they called HD to get approval, HD refused to cover them. They said brakes are a wear item and not covered under the extended warranty. The dealer made a few calls and the final answer was "Not Covered". They said if my trike was less then two years old and on the original Harley warranty they would be covered. My pads were almost worn out so had them do the work anyhow. The new rotors are different material than the original and the pads look like they have more lining on them. At least they don't squeak like crazy anymore.
    Rear lift kit, and tour pak relocation, Road Zepplin Air seat, Chrome front forks, SE 120 ST engine, Headers by V&H, Stock mufflers, SE 259E cams, TTS tuner and SE Air Cleaner, 58 mm Throttle Body, Tank lift, Wind Deflectors, DIY Crankcase Breather, Floorboard Ext.
    Amateur Radio : W4WNG
  15. #14
    40+ Posts
    Oct 2012
    I had no problem as mine was still under original warranty. when they were first replaced the new ones still squealed after a few more miles the squeal is gone for now. I also had the front rotors replaced under warranty as both were warped but they reused my front pads guess they aren't covered under warranty but new pads for the rear were covered??
    Semper-Fi
    68-71
  16. #15
    Jan 2011
    The Villages, FL
    Had both front rotors replaced under warranty. When applying the front brakes bike shook and vibrated like crazy. I paid for new pads as they would not replace them and were going to put them on the new rotors.
  17. DKCustoms postbit
  1. just a pic of '09 t/g rear brake pad
    By eagle1 in forum Harley Tri Glide
    Last Post: 08-21-2012, 07:22 PM
  2. Service Bulletin M1325
    By patriot in forum Harley Trike Conversions
    Last Post: 07-10-2012, 08:42 PM
  3. Rear Rotors
    By Paw Paw Willie in forum Harley Tri Glide
    Last Post: 04-22-2012, 06:07 PM
  4. Brake rotors for Hannigan RSV
    By Ragtop69gs in forum Yamaha Trikes
    Last Post: 11-19-2011, 11:46 PM
