Likes Likes:  0
Results 1 to 12 of 12
Thread: 1st real ride with this VW beast
    Class Clown Bikerbozo's Avatar
    Jun 2010
    Coram, NY USA
    Default 1st real ride with this VW beast
    Took the VW for first extended ride today. 28 miles one way to work. Featured stop and go and highway speeds. It was the toughest riding I have done in years. Takes 200% more concentration to operate this beast. Does handle bumps pretty good. Like the independent suspension. Loud and obnoxious (me and trike). People on the road loved it. Never had so many waves and smiles from car drivers. I thought a couple were going to have accidents because they were busy looking at me. Nothing fancy, just "Mad Max" vintage trike. At least, that's what I call it.
    Since I found out the hard way the other day that it has a 4 gallon tank, I think I will look into some sort of auxiliary gas. With no Speedo/odometer yet, can't be sure, but seems to get just under 30 mpg. Need to also get petcock with reserve on it. Probably get 5 gal gas can for home also to tip it off each day.
    1750+ Posts slick rick's Avatar
    Aug 2012
    Dora Al
    Default Re: 1st real ride with this VW beast
    That's great ,,yep about 29 miles to a gal with twin carbs I also have a marine GPS speedo but if your a techie just use your I phone . You get use to all the waves and it's a heck of a conversation piece and if your like me that's not a problem . Wife says it draws some strange people at times and I guess it does .
    we all have our faults .....others point them out to us......guess we know what theirs are
    Jun 2010
    Coram, NY USA
    Great idea Slick. Didn't even think of GPS Speedo. Just did a couple quick searches and see plenty of Speedo/odometer combo that use GPS. As opposed to full screen GPS.
    Aug 2012
    Dora Al
    Hey BB if you go to Arizona Trikes and click on parts you'll see the extra fuel tank that I run . It mounts between the tire and transmission out of the way and gives you four more gal ,,,,which is a good reserve . I have mine on a electric fuel pump and able to switch between the tanks , some just use shut off valves both will work .
    , I think if you add something like this you may not have to ride caboose again ,,,,just saying !!!!
    TOI - Oklahoma Frozenshrimp's Avatar
    Sep 2010
    Edmond,Ok USA
    BB you mite also check posum pride on an extra tank they have one that goes under the back half of the trike its like a 14 gal.
    Sean Church
    Edmond, Ok
    VW Trike :wave4:
    TOI Oklahoma Chapter Contact
    EMail:frozenshrimp@cox.net
  6. #6
    300+ Posts
    Aug 2013
    Levittown Pa. USA
    Bikerbozo, I'm sure u've posted a pic but I'd love to see the machine
    cooltech
  7. #7
    Jun 2010
    Coram, NY USA
    Quote Originally Posted by cooltech View Post
    cooltech
    Here you go, Cooltech. A couple of pics from different angles. One with wife also on it. And, no, she is usually only a passenger. She will never be given the keys AND there is ZERO chance I could teach her to shift.
    Replaced generator with alternator. Now looking to figure out where to connect Reverse light, so I know when shifting wrong. It's somewhere on that manual tranny. Just haven't spotted it yet. 1970 VW Bug engine and 4-speed tranny.
  8. #8
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Quote Originally Posted by Bikerbozo View Post
    Mine's on the front of the tranny, next to the rod you hook the the linkage to.
    "The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility, it's right. If it disturbs you, it's wrong until either the machine or your mind is changed." - Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
  9. #9
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Like Doug D. said
    On the nose next to the shift rod.
    Not all have it though. I think 66 or 67 was the first year for the switch. So some early swing axles will not have it at all.
  10. #10
    2000+ Posts Rick Kay's Avatar
    Dec 2011
    Huron, Ohio
    Awesome ride!
    Rick
    2006 FLHTI/2012 CSC Daytona
    1987 FLST
  11. #11
    Jun 2010
    Coram, NY USA
    Quote Originally Posted by Rick Kay View Post
    Awesome ride!
    Thanks.
    I think I just solved one of the last big problems. New alternator didn't seem to be charging. Suspected it had something to do with dummy light. Seems LED lights don't pull enough juice to get the voltage cranking. I tried old signal light and can see it dim as I rev engine and now I see voltage at battery go over 13vdc finally.
    Still have to figure out better mounting for brake. My legs are long enough that it is not easy pressing it.
    Also, just took a close look at tranny in daylight. Seems this one just doesn't have reverse light switch.
  12. #12
    20+ Posts
    Sep 2011
    athens,ga,usa
    u r riding a good looking machine. it looks real good to me.
  1. First real ride
    By SMSgt in forum Honda Trikes
    Last Post: 02-22-2013, 05:33 PM
  2. Went for 1st real ride on the roads already
    By JaysGone in forum General Discussion
    Last Post: 01-11-2013, 04:33 PM
  3. First real Ride
    By Paul_Trike in forum General Discussion
    Last Post: 03-13-2012, 06:53 PM
  4. Thinking of triking the Beast.
    By wanderingbear in forum New Member Introductions
    Last Post: 08-02-2011, 02:17 PM
  5. Mini Beast Air Horn
    By lzski326 in forum Harley Trike Conversions
    Last Post: 10-11-2009, 09:20 PM
