Results 1 to 6 of 6
Thread: Fault codes
    50+ Posts Bagger's Avatar
    Jan 2012
    Lexington north carolina
    Unhappy Fault codes
    My 2009 tri glide is showing a fault code of P0113 anyone know what this is and how to fix the problem, engine runs put no throttle and engine light on.
    1000+ Posts screwball's Avatar
    Santa Clarita, SoCa & Bullhead City, Az
    Default Re: Fault codes
    OBD-II Trouble Code: P0113 Intake Air Temperature Circuit High Input
    I don't really understand it, maybe it will make sense to you.
    Good Luck
    http://www.triketalk.com/forum/custo...epic4494_1.gif
    Why 3 wheels?
    because 2 isn't enough and 4 is too many
    We are really Steve & Vesta Brown
    Her: 2014 Tri-Glide Me: 2015 Freewheeler
    Vietnam Vet 1967-68 U.S. Air Force
    Oct 2010
    USA
    check the sensor or for a broken wire for the air sensor..
    Jun 2010
    Coram, NY USA
    If you have extended warranty, HD lives for fault codes. Saves them doing actual diagnostic work. Even if you don't have warranty, they may answer exactly what you need to do.
    Rider
    Jan 2009
    United States
    Unplug the IAC, clean up the terminals and put a little dielectric grease on the plug.
    That's the plug under the air cleaner cover on the left side of the throttle body. There is a push release on the back side. Push it in and pull the plug off.
    When your issue is fixed, clear the code.
    May 2020
    Albrightsville,Pa,USA
    Question Looking for P1010 Missing password?
    Hi 2010 Harley red key light stays on when riding Code is P1010/Missing Password.What is it?
  1. paint codes
    By retiredalaskan in forum Honda Trikes
    Last Post: 09-20-2012, 05:19 PM
  2. HD Triglide Paint Codes
    By eforman48 in forum Harley Tri Glide
    Last Post: 05-20-2012, 07:28 PM
  3. Diagnostic Codes
    By Paw Paw Willie in forum Harley Trike Conversions
    Last Post: 04-05-2012, 06:58 AM
  4. color codes
    By ODDOMAN in forum Stallion Trikes
    Last Post: 11-26-2010, 09:10 PM
