LD-Ordie7ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken16KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie7trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie7SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken16LD-OrdieHarley Tri Glide2024 Tri glide
LD-Ordie7LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  0
Results 1 to 11 of 11
Thread: Harleys like the movies
    150+ Posts Frang's Avatar
    Apr 2011
    Massachsetts.,USA
    Default Harleys like the movies
    I ordered a oil temp gauge for my 2011 back in September. Called the other day to see what the status was on it and was told it is due to be released on Oct 15. I thought usually only movies or prisoners had release dates.
    100+ Posts Dragonrider's Avatar
    Jan 2012
    Crowley, TX. USA
    Default Re: Harleys like the movies
    Maybe they want more ransom money for it?
    Well when I got the oil temp gauge for my 2011 it took a while for me to get it too. It took about a month or so if I remember right.
    Dan
    Jan 2012
    Crowley, TX. USA
    Wow, that sounds ridiculous. Seems that this would be a part that they kept in stock at dealers.
    Rider
    Jun 2013
    West Central WI
    Are you writing about the in fairing temp gauge or the oil dip stick with temp gauge? Had my in fairing temp gauge in one week back at end of August, but the dip stick temp gauge took about a month when ordered in early July. I know they had issues with the dip stick temp gauge retaining moisture, so heard they were only shipping new version. Still have the problem. My dip stick temp gauge will fog up after riding in heavy rain or after washing. I am now cautious when washing not to run direct spray on to the gauge.
  6. DKCustoms postbit
  7. #6
    200+ Posts Lizard's Avatar
    Aug 2013
    Nashville, TN USA
    There's a difference between the regular dip stick gauge and the trike gauge. Most dealers will stock one and not the other. When I ordered mine several weeks ago, I found out the dealer I got it from had never had one in stock before.
    2013 Triglide, SE254E Cam, Arlen Ness Air Cleaner, Fullsac X-Pipe, CVO Mufflers with Fullsac 1.75" cores, 480# clutch spring with ClutchWiz, TTS Mastertune with custom tune.
  8. #7
    300+ Posts 0pini0nated's Avatar
    Oct 2012
    Willow Grove, PA Turnpike, Exit 343
    The "release date" may be the date the container ship (from China) docks. When there was a dock strike last year (Ports of Los Angeles and Long Beach) my new "special order" fuel gauge delivery date was delayed, then delayed again. I finally cancelled the "special order" and found one in a shelf locally in Pennsylvania.
    2005 FXST Softail Std | 2015 FLRT Freewheeler | 2015 FLD103 Switchback
    *14-year Member, ABATE of PA- ABATE.ORG
    * MRF- MRF.ORG
  9. #8
    20+ Posts
    Sep 2013
    Hollister, MO
    Does anyone know what the difference is between the Oil Level and Temperature gauge for the one approved for the trike vs. the other touring models. I kept the one off my 2011 Street Glide and have been using it own my 2014 trike. It seems to be accurate. Really surprised to discover they are different.
  10. #9
    Rider
    Jun 2013
    West Central WI
    Quote Originally Posted by Will Parish View Post
    I was told the dip stick although still swivels to allow entry, has a different sensor strip to account for trike being level not on Jiffy stand. If you have compared using the original dip stick to know where the oil is at, and you know the slight difference, there should be no problem. Your risk would be level of oil not perfect, but hey I run just a tad lower than full anyway to eliminate air cleaner blow by.
  11. #10
    20+ Posts
    Sep 2013
    Hollister, MO
    Well that makes sense...measured full when I took delivery and full after the 1k. Thanks.
  12. #11
    Apr 2011
    Massachsetts.,USA
    Quote Originally Posted by Fusionfool View Post
    Fairing gauge
  1. Its a bad day for harleys
    By pcombe in forum General Discussion
    Last Post: 09-29-2013, 09:52 AM
  2. Harleys new Trike
    By Goober in forum Harley Tri Glide
    Last Post: 03-02-2012, 06:50 PM
  3. Why are all the harleys on the Honda page?
    By Boscoporp in forum Honda Trikes
    Last Post: 06-11-2011, 06:44 AM
  4. Harleys don't float
    By Big_Steve in forum General Discussion
    Last Post: 10-26-2010, 01:10 AM
