Results 1 to 20 of 21
Thread: Trike rear master cylinder problem ??
    20+ Posts
    Jul 2013
    Casselman,Ontario Canada
    Default Trike rear master cylinder problem ??
    Hi everyone, I have converted my 2000 yamaha VStar 1100 to a trike and the rear master cylinder does not seem to move enough brake fluid to make the rear drum brakes work properly. I have adjested my brake , I bled the system bu still not enough stopping power.
    Can anyone help me ? will I need to swith the master cylinder ? If so what will I need to buy ?
    thanks for your help !
    Default Re: Trike rear master cylinder problem ??
    To start you need to puit a 10# residual valve in the line.one on each side, that should do the trick. it holds presure in the line takes less to engage the drum.
    You can find them on ebay or a hotrod shop
    20+ Posts
    Jul 2013
    Ok thanks for the tip ! My rear brake line makes a " y " do I still need to put two residual valve or one between the master cylinder and the " Y " splitter would do ? the way my brake lines are made between the wheel cylinders and the " Y " splitter it can be a bit difficult to put the residual valve. so I am wondering if one just behind the master cylinder would work ?
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    I finally got past that problem with a power bleeder, Took some time and was frustrating but it worked.
    20+ Posts
    Jul 2013
    My brake line ' Y ' splitter is at the highest point of my rear swing arm, therefore much higher than my master cylinder. Shall I relocate it in order to keep it the lower possible ?
    Feb 2013
    casper,wy. usa
    I would sure be a lot more comfortable with y splitter being below the level of my master cylinder.
    If you develop a leak on the master cylinder seal i would think gravity would take over and drain the fluid out of the lines?
    I really don't know your set up.
    When you say there is still not enough stopping power, am i to assume your pedal travel dosent feel like you have any brakes?
    Or is it a matter of using the brake enough to wear the glaze from the brake pads?
    I sure wouldnt discount the use of the residual valve, the man sounds like he knows what he is talking about.
    I really can't answer your question about one or two valves My trike has dual disc brakes.
    20+ Posts
    Jul 2013
    You are right ! when pushing the rear brake pedal it goes all the way down and it barely slow down the trike.
    Feb 2013
    casper,wy. usa
    Did you try the power bleeder?
    They can be had from harbor freight fairly cheaply.
    How are your slave cylinders?
    60+ Posts Leathel's Avatar
    Oct 2013
    Waikato New Zealand
    Is your master cylinder piston big enough to drive both slave cylinders?
    http://i222.photobucket.com/albums/d...5a2673ece8.jpg
    Hunting, Fishing, Riding...its all good,VT750 2005 (Soon to be a trike),VT1100C 1993 my Ride, DRZ400 Dirt ride, TRX300 Hunting, fishing hack
    20+ Posts
    Jul 2013
    the master cylinder is the original one from Yamaha and the wheel cylinder are originally made for a 1991 Ford mustang Lx. I honestly dont know how to rate the compatibility between them.
    Oct 2013
    Waikato New Zealand
    Quote Originally Posted by Pre-1898 View Post
    So you have a master cylinder from a single brake setup trying to drive 2? The piston will not be able to shift enough fluid to engage the brake fully..... A trip to a brake and clutch specialist will be in order to get a mater cylinder with a larger piston, they generally don't cost much and a bigger clutch one may work well
    Feb 2013
    casper,wy. usa
    Name:  paul and trike in tetons.jpg
    20+ Posts
    Jul 2013
    Is there anyone here who could tell me what type of rear master cylinder I shall use for my 2000 V Star 1100 trike with rear drum brakes ?
    Dec 2009
    Phoenix, AZ
    I have the same issue, what did you end up doing?
    20+ Posts
    Jul 2013
    Ok I was told to install residual valves and to keep my master cylinder higher than my wheel cylinders. In order to have the wheel cylinders at a lower level, Shall I flip my backplates upside down so my wheel cylinder go lower ? Would that affect breaking performance ?
    any help would be appreciated !
    750+ Posts
    Jan 2010
    east windsor ct
    if you flip em the bleeders will be on the bottom making it most impossible to bleed them
    the residual valves may help
    does the pedal feel spongy or bottom out or feel good just not enuff pressure
    i had the same problem w a v65 honda w a subaru rear an drum brakes had several problems the drums were small diametr an had tall tires,,, mc was a little small tried several mc an different leverage... change to disks end of problem
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    What kit did you use? The manufacturer should be able to answer all your questions. My 1300 vtx Champion stops on a dime. I seldom use the front brake.
    20+ Posts
    Jul 2013
    Quote Originally Posted by Leathel View Post
    I checked with a company who make trike kits with the same differential I used ( Ford 7.5) using the same drum brake system and they told me they are using the VStar stock rear brake master cylinder so basically It shall be OK. I wil try lowering my brake lines as they are higher than my master cylinder and will add some residual valves. was told this shall fix the problem ! hope it does !
  19. #19
    60+ Posts
    Apr 2014
    Arizona Territory
    Please forgive the intrusion, but just wanted to offer some possible confirmation about what you've been discussing and also want to thank you for confirming something I had a question about as well.
    I've got a 2002 Suzuki-Lehman trike and am renewing the brake system. In matching brake parts, near as I can tell, Lehman used a Ford 6 3/4" rear differential from a Mustang II (model years 1975-78) This trike is powered by a Suzuki VS800cc engine, but Lehman used a rear brake master cylinder (motorcycle) from a VS1400cc, so I believe you're probably good to go with your 1100cc trike.
    On the residual pressure valves, Lehman used only one (not two) and it's probably rated at 10 psi, that goes into the "Y" fitting which is located near the top of the axle tube and then the brake lines from the "Y" fitting run along the top of the axle tubes to connect to the wheel cylinders. This is where I want to thank Y'all. I'd suspected that the residual pressure valve was a valve and not simply a brake line fitting, but wasn't able to confirm that until reading Y'all's thread here just now. Thanx very much and all the BEST with your build
  20. #20
    60+ Posts
    Apr 2014
    Arizona Territory
    Just a quik-correct here.....I was wrong about my trike having a residual pressure valve. It doesn't have one. What threw me was that the end of the brake line that comes from the master cylinder and threads into the "Y" fitting has a short adapter, hex shaped, that transitions the brake line to the larger fitting that threads into the "Y". I mistakenly thought the hex shaped piece was an RPV, but it isn't.
    I want to thank Lee H. Mann for giving me the right lowdown on this and also wanted to offer Y'all the courtesy of this correction.
    Keep on choppin' and build on!
  1. Master cylinder for rear brake
    By jimmib in forum Harley Trike Conversions
    Last Post: 07-15-2020, 12:49 PM
  2. Master cylinder question
    By burkslaw in forum VW Powered Trikes
    Last Post: 06-19-2013, 08:11 AM
  3. what master cylinder to use on my trike?
    By memetriker in forum VW Powered Trikes
    Last Post: 05-11-2013, 06:37 AM
  4. Master Cylinder Touring
    By Gorilla in forum Harley Trike Conversions
    Last Post: 06-30-2011, 11:33 AM
