Results 1 to 11 of 11
Thread: Difficult to find neutral gear for 2013 GW + CSC Trike when engine is on
    90+ Posts MMH's Avatar
    Sep 2013
    Brandon, FL, USA
    Default Difficult to find neutral gear for 2013 GW + CSC Trike when engine is on
    When the engine is on, can't find neutral. Slides easily into neutral when only the ignition is on and the engine is off. Not a major concern, really like how she rides...just curious if it's common for GW 1800's. Appreciate any feedback. Thanks!!
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Default Re: Difficult to find neutral gear for 2013 GW + CSC Trike when engine is on
    I haven't had any problems finding neutal with my 2012 GW. I do know I had to get a little softer touch when it comes to clicking from 1st to neutral on the Wing vs the HD's I've owned.
    100+ Posts Grandpa1's Avatar
    Apr 2013
    Wichita Falls, TX
    I noticed it was real touchy to find neutral on my 2012 Wing with CSC Viper too. We need it a lot too since we have to use reverse quite often.
    I just put a Kury heel/toe shifter on it and I think it made it easier to find neutral but I'm not sure yet.
    Lost In The 50's rmrc51's Avatar
    Feb 2009
    Palmyra, Virginia
    I have a Kury Heel/Toe shifter on my 05 Wing/Roadsmith and you have to "lightly" hit the shifter to get her into neutral or you'll go right into 1st, lol.
    Jun 2010
    Indianapolis, In.
    Found early on, it is much easier to find neutral if you shift into 1st gear then "lightly" lift your foot on the shifter!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    700+ Posts
    Jan 2012
    Cayce SC
    The wing does most things right except the transmission is Junk , in compairison the sport bikes
    Sep 2009
    NE Ohio
    Quote Originally Posted by Grandpa1 View Post
    Reverse is one thing I've seen a triked Wing does not do well. I've only done it a couple times and it gives me the feeling reverse will die an early death moving that extra mass. Now I selectively park and use the Flintstone method.
    Sep 2013
    Brandon, FL, USA
    Quote Originally Posted by MMH View Post
    This cured it...from a tip from Sethan12- on 1st gear, let the clutch out a bit and tried to change to neutral...at first, didn't work but now it's falling to neutral from both 1st and 2nd! I am so happy, Thanks Again!!!
    100+ Posts turboman1354's Avatar
    Sep 2011
    Laurinburg NC
    I`ve never had any trouble with my wing getting to neutral.Sometimes it`s easier to get to neutral from 2nd gear than it it from first.
    800+ Posts SMSgt's Avatar
    Sep 2012
    Cedar City, Utah, USA
    Quote Originally Posted by Bill Reber View Post
    "in comparison to the sport bikes" that's almost the dumbest things I've ever heard. Who would ever compare a GL1800 to a sport bike. That's like comparing a Cadillac to a Corvette and complaining that the Vet doesn't have much trunk space.
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Now you know how almost all Harley owners feel. I haven owned a Harley (6) that didn't have a problen going into neutral.
  1. Trike won't start in neutral
    By Huelshorst in forum Harley Trike Conversions
    Last Post: 06-28-2013, 06:28 PM
  2. Start Engine in Neutral?
    By BinIdaho in forum Harley Trike Conversions
    Last Post: 01-23-2013, 03:19 PM
  3. It was a difficult build
    By PhilGilbert in forum Suzuki - Kawasaki Trikes
    Last Post: 09-19-2011, 07:32 PM
