ADSavarese2rhino 2New Member Introduct...New member from FL
ADSavarese2ADSavareseNew Member Introduct...New member from FL
dthorn1dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
Likes Likes:  3,199
Thanks Thanks:  185
Page 166 of 194 FirstFirst ... 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 ... LastLast
Results 3,301 to 3,320 of 3869
Thread: What did you do to Your Tri-Glide Today?
  1. #3301
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by Cagmo View Post
    I applied three coats of the new Rain-X plastic protectorate prior to running the Natchez Trace Parkway last week. I was hoping for good results, but when I hit rain, the windshield just beaded up. Maybe somebody else has better luck, bit I would recommend spending your money elsewhere. This product does not work on an LRS windscreen.
    Also the Rain -X will leave a coat of wax type film and in time also leave a blue haze on the shield…I learned that years ago when the product first came out…😱..
    2019 Tri-Glide.......
  2. #3302
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Went for a 325 mile ride through the southern Ohio hills . Beautiful day .Now for the bugs all over the front..
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
  3. #3303
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Installed the Dakota Digital gauges. These are the bomb. Absolutely great enhancement to the TG.
  4. #3304
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Last week we had temps in the mid to high 90's.
    Yesterday was a perfect 82 degrees. Rode 120 miles, most tree-lined country roads. (took the really long way to work and back )
    Almost 64 and still enjoy riding as much as I did half a century ago.
    www.DKCustom.com
  5. #3305
    1000+ Posts
    Aug 2012
    Pendleton, Oregon USA
    Default Dakota
    Quote Originally Posted by ultrafxr View Post
    I did the same awhile back, SAME RESULT……
    Pete
  6. #3306
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Wiped the dust off the Trike with my Kozak Cloth…..Gets the dust off without water and doesn’t scratch the paint..👍..
  7. #3307
    300+ Posts
    DOKK's Avatar
    Dec 2020
    Manchester TN USA
    I've had a few days now with the new rear suspension and riding both back roads and interstate. What I find at higher speeds on the interstate is it feels more "nimble" or "light", almost a little "loose" to use a racing term. Is this a normal feeling after upgrading the suspension on these? It's not like "oh s***" loose but definitely feels much different than before. I have been riding pretty much every day though since getting it back and it is so much smoother.
    2016 Tri Glide, More DK than HD. Just shut up and ride.
  8. #3308
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by DOKK View Post
    There are two different things going on:
    1. The shocks are giving a smoother ride and keeping the trike "flatter" in the curves. You have already mentioned how much more comfortable a ride it is. That is due to the dynamically adjusting shocks and the better angle the shocks are on due to the Comfort Lift.
    2. The Comfort Lift, along with the taller shocks, have made the rear of the trike sit just a little higher. This results in easier steering. The handlebars require less input to make a slow speed turn, it is not so sluggish, does not require near as much force. This is what so many talk about when they say the steering is so much easier with a Comfort Lift, regardless of the shocks.
    BUT, this also means at speed, there is less input needed. This translates into what some call a twitchy feeling, or loose, or just that the steering is overly sensitive at speed. We are so used to the heavy hands needed to steer the Trikes, it can take a little while to adjust to the handlebars needing less input.
    Here is a LINK to an article on the technical aspects of the subject.
    I realize I may not have understood you correctly, and that there is something that is actually loose. Please make sure that the Comfort Lift brand bolts and the top and bottom shock mount bolts are all tight.
    Ride Free,
    www.DKCustom.com
  9. #3309
    300+ Posts
    DOKK's Avatar
    Dec 2020
    Manchester TN USA
    Ride Free,
    You understood and described it perfectly. I guess I just gotta relearn the trike. Lol.
  10. #3310
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Received the oil analysis report on my 2020 TG. Looking good.
  11. #3311
    200+ Posts New Orleans Kevin's Avatar
    May 2021
    Arabi, LA USA
    Had to put the right-side KW muffler back on. It came loose from the header. not the first time either, had put a new clamp on it about 300 miles ago and torqued it up but it came off again. Also cleaned the bugs off and planning on riding some more.
  12. #3312
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    Let the Sumbitch sit there today and riding my Electra Glide… better gas mileage on solo rides and it’s gonna be 105 with heat index,I need all the open air I can get and my EG has no lowers.
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
  13. #3313
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    That is a great report!
    www.DKCustom.com
  14. #3314
    May 2021
    Arabi, LA USA
    Washed, polished, waxed. Cleaned junk out of tour pak and trunk. Loaded beverages on board. Riding to Gulfport Blowout in the morning!!!!
  15. #3315
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    Default What did you do to your Tri glide today.
    Installed DK Customs floorboard extensions and 1.5” tank lift on my 2021 Tri Glide; tired (I’m 80), but happy with both products.
  16. #3316
    1000+ Posts
    Aug 2012
    Default Tired
    Quote Originally Posted by Olddog View Post
    KEEP ER GOING, take your break then ENJOY THE RIDE!
  17. #3317
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    Took her out this morning for a 100 mile ride. The difference in felt heat from the engine is a blessing. The footrest extensions keep my boot heel off of the exhaust.👍👍
  18. #3318
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    The TG was filthy from a lot of riding in the rain and many hours of sitting in dusty parking lots.
    Took the time today to wash her up. Would rather be riding than cleaning, but I do like how easy it cleans up with the ceramic coating.
    www.DKCustom.com
  19. #3319
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Short 160 mile ride for Italian Dinner in Cincy Yesterday. Today 150 mile ride to Cranberries rest. for the famous reuben & onion rings. Dam their good.. & then we rode all the way around Indian Lake & then home. Need cooler temps,so we can wash the ol girl.
  20. #3320
    550+ Posts
    520fd's Avatar
    Aug 2010
    Davenport, Iowa USA
    I put on a set of Hywy pegs/rests. Felt pretty good getting my leg away from the heat. The last 3 days, I had to wait at home. Had to sign for my new cell phone. First day, it didn't show up. 2nd. day, it showed up late in the day. Today, I ride. Nice day here in Iowa. Also, synced my cell phone in the trike.
    2022 Tri-Glide Black.
  1. Purchased New Tri Glide Today
    By Marv1 in forum Harley Tri Glide
    Last Post: 12-11-2021, 04:56 PM
  2. I sat on one today
    By werewolf in forum Can Am Spyder Trikes
    Last Post: 11-11-2013, 01:30 PM
  3. Low mileage 2010 tri glide trike street glide
    By jwkhd1 in forum Harley Tri Glide
    Last Post: 09-20-2012, 07:54 AM
  4. Got it today
    By hitime in forum General Discussion
    Last Post: 09-06-2009, 06:53 PM
