SSpoon6rhino 2New Member Introduct...Hello from VA
SSpoon6trike ladyNew Member Introduct...Hello from VA
gfaltersack1gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon6SullyNew Member Introduct...Hello from VA
SSpoon6Jack KlarichNew Member Introduct...Hello from VA
SSpoon6GorillaNew Member Introduct...Hello from VA
SSpoon6SSpoonNew Member Introduct...Hello from VA
Likes Likes:  3,192
Thanks Thanks:  185
Page 168 of 194 FirstFirst ... 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 ... LastLast
Results 3,341 to 3,360 of 3866
Thread: What did you do to Your Tri-Glide Today?
  1. #3341
    100+ Posts
    Apr 2022
    Bridgewater, New Jersey, USA
    Swapped out whatever the crap my dealer put in the trans for Redline Shockproof heavy. I used this in my other Harleys with great results. Didn't dissapoint. Shifts much smoother but still can't find neutral unless I'm rolling to a stop. With my old Ultra all I did was rev it up a bit and look for it while it was winding down. Worked evertime. My trike, not so much.
  2. #3342
    300+ Posts
    DOKK's Avatar
    Dec 2020
    Manchester TN USA
    I found out why the trike felt so “loose” after the rear shocks were installed. I had the FST system installed in the forks and everything tightened right back up. I added 10w fork oil as well for a little firmness in the front. It doubled the improvement over adding the rear shocks. I came home from work and they are working on the interstate. They have cut out the old dotted lines for a lane shift and it’s like a washboard down the middle of the lane. This new FST suspension doesn’t even feel it. I don’t have stagger now going through the zone. I may even increase the preload on the rears to firm them up some as well. Out of everything I’ve done to the trike since I’ve had it, this has been by far the best upgrade and best money spent. Period. I will be hitting 50k within the next month or so and look forward to 50 more.
    2016 Tri Glide, More DK than HD. Just shut up and ride.
  3. #3343
    300+ Posts
    Mar 2018
    Waelder, Texas
    Quote Originally Posted by SmittysTrike View Post
    Smutty, you’re probably as experienced with Harley as I am, but I feel primary lube is more directly related to that elusive neutral. I’m not going to start trouble by making a recommendation, but check out some options and make sure you don’t overfill. Also, I don’t believe your trike came with a heel shifter. Maybe consider one, even if you only use it for finding neutral. An extended lever should not get in your way.
    Good luck!
    Last edited by RKplus10; 07-03-2022 at 09:34 AM. Reason: Make an additional comment
  4. #3344
    100+ Posts
    Apr 2022
    Quote Originally Posted by RKplus10 View Post
    Good luck!
    Always hated the heel shifter. Too confining for my riding style. I do remember doing some fluid swaps in my primary on my old Ultra and finding that ATF made it much easier to find neutral but didn't seem to last very long. And then there's that compensator thing to think about. I might just try putting the heel shifter back on to see if it makes it easier. If it does I can always get an extended one to get it out of the way.
  5. #3345
    300+ Posts
    Mar 2018
    Waelder, Texas
    First of all, apologies for misspelling your name. Yeah a buddy of mine really liked the ATF. I’m using Rotella 15w-40 which is JASO DH-2, JASO MA/MA2 for wet clutches. Works well for me. Formula Plus seems to be a good choice as well.
    There, I’m a troublemaker.
  6. #3346
    100+ Posts
    Apr 2022
    The "I" is next to the"U" so no need to apologize. Plus I've been called worse. Guess I'll try some different lubes in the primary too.
  7. #3347
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    Trouble finding neutral might be a bit too much fluid. Make sure you have the exact amount. I had 2 ounce too much in my primary and I had a hell of a time finding it. Took 2 oz out and Voila
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
  8. #3348
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    I have the same problem with people miss spelling my name…They always spell it backwards…But by now I’ve gotten use to it…😁..
    2019 Tri-Glide.......
  9. #3349
    300+ Posts
    Mar 2018
    Waelder, Texas
    That’s pretty funny boB, I’ll try to control my dyslexia in the future.
  10. #3350
    550+ Posts
    520fd's Avatar
    Aug 2010
    Davenport, Iowa USA
    Had a new Lock switch put on by the dealer. Had to order a new one with the correct key number. Works good now.
    2022 Tri-Glide Black.
  11. #3351
    100+ Posts
    Apr 2022
    Good luck!
    I put the heel shifter back on. I have to admit that I can find neutral much easier.
    But twice now I've put my foot down and inadvertently slammed it in gear.
    I'm trying to be more careful now while I wait for the new extended shifter to come in. Thanks for the suggestion. It really does work better.
  12. #3352
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Changed the oil today… The last few changes I’ve been letting the dealer do I’m just getting too old to crawl down and play around with it but the dealer was too busy and my son said get the stuff and he’ll do it and we did it ‘ That is to say he did it I was just the gofer…And clean up guy…
  13. #3353
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Just to add about the cleanup when I was at the Harley dealer to get oil and filter I bought one of those funnel things that go under the filter to catch the drips: The parts guy said that you’re still going to make a mess sure you want it I said yeah why not and sure enough it did make a mess but I change in my garage and I have a hot water hose hook up and after everything was buttoned up i sprayed the whole bottom of of the engine with degreaser washed it off with hot water and it was good to go I think I’ll just leave the funnel/Drip catcher on my shelf next to all the JC Whitney crap I bought over the years
  14. #3354
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Bob, have u flushed your clutch fluid?
    Before I change oil, i put a piece of cardboard under the filter, poke 2 holes in the filter
    Pull the drain plug, let it and filter drain for 15 minutes, no mess even from the filter area
  15. #3355
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Only 8 k on the Trike…. As far as the mess like I said I have a hot water hose And spray degreaser dry it up and done…
  16. #3356
    150+ Posts RareSS's Avatar
    Sep 2021
    Abilene, Texas, USA
    I haven’t done much with the Tri with all of the hot weather, but I did have a Rockford Fosgate 2 sound system installed and I moved the usb plug in the pocket to my tour pack with the help of a USB data extension cable. Now, I have Apple car play with my phone secured in my tour pack. The pocket will hold my keys or whatever from now on.
    (Haven’t finished the third brake light hook-up, I am waiting on the LED stop/turn/run side lights. I can install it all in one big swoop, being I have the tour pack apart!)
    I am solo, so I am debating the tour pack relocator unit.
    The mods never end. ��
    Texas; 254 counties and I have ridden through them all! Got my pin from my Congress Lady congratulating me on completing my journey.
  17. #3357
    300+ Posts
    Mar 2018
    Waelder, Texas
    So Jack, is the cardboard formed into a funnel to divert the oil or to soak up the oil? What about the holes you punch? Are they in the end or the side of the filter? Do you rotate the filter to locate the holes toward the bottom? Over the years, I’ve gotten pretty good at cleaning up my mess, but I will try your method next time. I think I’ve tried everything else (without any success).
  18. #3358
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    Jack, I’m curious, why do you put two holes in the filter? I punch one at 12 o’clock and rotate the filter (loosen) until the hole is at the 6 o’clock position, then let drain. Am I hopelessly antique?
  19. #3359
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Olddog View Post
    I think it drains better, the bottom hole is the drain, top hole is incoming air to help drain
  20. #3360
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Unhooked the trailer from the trike, unpacked both trike and trailer, washed them both and dried them. We just got back yesterday from riding the Blue Ridge Parkway.
  1. Purchased New Tri Glide Today
    By Marv1 in forum Harley Tri Glide
    Last Post: 12-11-2021, 04:56 PM
  2. I sat on one today
    By werewolf in forum Can Am Spyder Trikes
    Last Post: 11-11-2013, 01:30 PM
  3. Low mileage 2010 tri glide trike street glide
    By jwkhd1 in forum Harley Tri Glide
    Last Post: 09-20-2012, 07:54 AM
  4. Got it today
    By hitime in forum General Discussion
    Last Post: 09-06-2009, 06:53 PM
