Outstanding pictures must have been a seriously good ride.
Rode 225 miles just for kicks with the new Stage 2 kit and new axle bearings and DK plates . 725 mile review of Feuling Stage 2 with 472 cam coming soon !!! 👍😁😁😁💯
Installed Oil Cooler from DK Customs, and went for 150 mile ride in the low 8's, seem to run cooler.
2019 Tri Glide
IBA #77718
Retired US Army
Brought it home , no rear breaks ! Not in the mood to check rear master fluid . Tomorrow……
Yesterday we got up and going around 8 AM a breakfast ride, we totaled 121 miles, no wind and around 80 degrees, it doesn't get much better than that.
Hay Jack, what’s involved in checking the rear brake master fluid on a 12 tri ?
Not a whole lot, clean the cover before removing, once the cover is off look at the level and color of the fluid, if it is low you can top it off or I prefer to suck out as much as I can, wipe the inside and bottom ( where the compensating port is) real good with a lint free cotton towel or a clean Q tip.
Then you can refill the master, use a couple of slow half pumps of the brake pedal, if it is firm and does not fade, you are good to go, if it is spongy, bleed the rear calipers.
One of these is a very handy tool to have for checking your brake fluid.
What a stunade I am . The rear master is in front of the pedal . And here I’m looking under the exhaust by the brake light switch. If it wasn’t for my age , I’d of seen that emeditly . And I’m told it only gets better !
A very bad design, who puts a brake light switch and a master cylinder behind an exhaust pipe right?
Harley did and bad JUJU happens every time
If I had a nickel for every master and switch I have replaced I could own the MOCO
A new battery installation . All went A-Ok 👌..
Good on you Frankie
Went on a 285-mile trike ride a few days ago. Beautiful weather. 85 degrees. Got home. Backed up in my garage. Dismounted the trike, I used my driver's footboard, like I always do. The rear bolt of the mount broke off. Had to take into the dealership to get the remaining part of the bolt. I would think it would be under the warranty. But, no it wasn't. Granted that they had the trike for a day and a half, the price wasn't too bad/ $75.00 Never had I ever had this problem before. Now the weather went to crap. Have to wait a few days to ride again.
2022 Tri-Glide Black.
