Results 1 to 4 of 4
Thread: V Star 1100 trike rear tire size ???
    20+ Posts
    Jul 2013
    Casselman,Ontario Canada
    Default V Star 1100 trike rear tire size ???
    Hi, can anyone tell me what size of tire I shall put on my V Star 1100 trike to keep the speedometer on track with the real speed ?
    my rear differential as a 2.73 gear ratio and size 14 rims
    any help is greatly appreciated !
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Default Re: V Star 1100 trike rear tire size ???
    I will try to do some measuring tomorrow but I think I had determined a 205 65 15 would be real close if you want to stay with the 14 rims 205 70 or 75.The stock gear ratio is like 2.8 so your gaining a bit there so a bit shorter tire than the stock would help compensate but really I don't think your dealing with enough to worry much about plus it should hep correct the speedo which usually shows fast on the stock bike.
    20+ Posts
    Jul 2013
    When ever you have a chance, please let me know. Morethan possible I want to keep 14" weels as It goes on a 4 lugs 4.25 pattern.
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    Who made your conversion kit? I would ask them what size tire they recommend to keep the speedometer as close as possible. You could also add a Speedo Healer http://www.bluemonkeymotorsports.com/ and correct the problem for what ever size tire you run.
    Happy TRAils/NSD
    Paul
  1. My own trike conversion for V Star 1100
    By Pre-1898 in forum Yamaha Trikes
    Last Post: 05-18-2014, 07:25 PM
  2. Best final gear ratio for V Star 1100 trike ?
    Last Post: 08-21-2013, 07:31 AM
  3. Need trike exaust adaptor kit for V Star 1100
    Last Post: 08-03-2013, 05:26 PM
  4. rear tire size/brand question
    By stargzr57 in forum Tires, Wheels, Brakes, Front End
    Last Post: 04-11-2013, 12:41 PM
  5. Rear Tire Size
    By mcdonaldroadcapt in forum Harley Trike Conversions
    Last Post: 05-05-2011, 03:33 PM
