Results 1 to 15 of 15
Thread: Alternator Output on 2014 Triglide
    60+ Posts
    Feb 2013
    PORTLAND OREGON
    Default Alternator Output on 2014 Triglide
    I seem to be having a heck of a time trying to find out what the 2014 Triglides have for alternator output.
    Do they have the standard 50 amp system like the '13 and earlier, or do they have the new high output charging system in there?
    I keep getting conflicting answers. Does anyone know for sure?
    2015 Triglide Vivid Black
    2013 TriGlide Vivid Black - sold /'99 FLHTCUI - sold /'97 FXSTC -sold
    :wave4:
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Default Re: Alternator Output on 2014 Triglide
    Quote Originally Posted by hARLEY jOE View Post
    The only model with the high out put charging system is the CVO Ultra Limited, the rest still have the same system as the 13's. FWIW the difference is only about 5 amps or about 60 watts which in the grand scheme of things isn't much.
    200+ Posts PIGGI's Avatar
    Nov 2012
    Sahuarita, Arizona
    Quote Originally Posted by msocko3 View Post
    Especially since all the lighting is LED.
    Sep 2009
    NE Ohio
    Quote Originally Posted by PIGGI View Post
    Good point, LED lighting sure does save some energy.
    Well I can't say for sure but I seriously doubt they would have went to a higher out put charging system especially seeing as the Head and passing lamps are now LED on the 14's which takes a considerable amount of load off the charging system over the standard head and passing lamps. But any Harley service tech or parts person should be able to give you a definite answer.
    Dan
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Every scrap of information I've read says 50 amps.
    Sep 2009
    NE Ohio
    I've seen it referred to as 49 & 50 amp, take your pick difference is only 12 - 13 watts between the 2 numbers.
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    The lighting might be LED & draw less current, but the '14's also have an electric water pump, & two cooling fans to operate that weren't there before. Also how much does that big screen informant stereo system draw over the old stereo ?
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
    "The lighting might be LED & draw less current, but the '14's also have an electric water pump, & two cooling fans to operate that weren't there before. Also how much does that big screen informant stereo system draw over the old stereo ? "
    I guess I wasn't thinking about that stuff. I was just thinking the LED lights draw less. Thanks for posting that info. Definitely something that needs to be figured in to the total equation.
    So I'd say the question is not only what the out put is of the charging system on the 14's but also what the actual load is on the system too. I doubt the big screen informant stereo system draws much. That electronic stuff usually don't. But the electric water pump, & two cooling fans could draw quite a bit.
    Dan
  11. #10
    300+ Posts
    NE OHIO
    I would like to know that also. How close will I be to maxin out the system. I installed the Ultra Cool oil cooler that has 2 fans, and now I'm gonna add the Werks Fans for the heads.
    Hope it's not pulling too much? Has anybody else installed both?
  12. #11
    Sep 2009
    NE Ohio
    Quote Originally Posted by eighty80 View Post
    I think you'll be good to go. There are folks who run 2 sets of heated clothing on them, I've not heard any complaints.
  13. #12
    300+ Posts
    NE OHIO
    Thank's Mike, that's what I was hopin.
    P.S. I walked from the house to the mail box yesterday, gettin better.
  14. #13
    Sep 2009
    NE Ohio
    Great, hope you have a good Thanksgiving.
  15. #14
    300+ Posts
    Dec 2011
    Iowa
    I guess I don't understand why would you need those fans if you have a 2014 Tri Glide?
  16. #15
    300+ Posts
    NE OHIO
    Quote Originally Posted by rap47 View Post
    You probably don't I guess?
    Mine is a 2012 with a 120R c.i. motor. A little different.
  17. DKCustoms postbit
  1. 2014 triglide recall
    By GARYD in forum Harley Tri Glide
    Last Post: 10-12-2013, 07:07 AM
  2. 2014 TriGlide
    By BubbleHead in forum Harley Tri Glide
    Last Post: 09-25-2013, 09:20 AM
  3. Question about the 2014 Triglide...
    By AzDaven in forum Harley Tri Glide
    Last Post: 09-19-2013, 10:19 AM
  4. Got a 2014 Triglide
    By Beorn of Ga in forum Harley Tri Glide
    Last Post: 09-09-2013, 01:38 PM
  5. VW motor powered trike with 90 degree output
    By BIBS in forum VW Powered Trikes
    Last Post: 03-31-2011, 06:24 PM
