LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Results 1 to 15 of 15
Thread: LED tail lights
    30+ Posts
    Sep 2013
    United States, Dacula, GA
    Default LED tail lights
    2013 TriGlide. Considering LED brake lights. Radiantz are $139 each and Badasslights are $199. Is there much of a difference between the two. It seems radiantz pulse patterns cannot be adjusted but how about the brightness difference?
    20+ Posts
    Apr 2013
    Indiana
    Default Re:
    I can tell you this brightasslights or good I have them on my trike have had other rides behind me and they get there attend
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Default Re: LED tail lights
    I will use nothing but Hyper-Lites on my bikes. I had a guy in a car follow me into a Gander Mountain parking lot just to find out where I got them.
    And the prices are waaaaay lower then these others lights. My set cost me $69. I'm thinking on installing 2 sets on my new TG.
    I recommend them with the highest authority. pepper pepper pepper
    A week ago I purchased the H-D LED tail lights because it's too cold to install the Hyper-Lites until spring. I could not find the plugs to plug in the module so I brought it back to the dealer. Service manager said I'll put it on for you(free-believe it or not). He did but he said I didn't need the module on the '14 TG. The only thing different will be the flash indicators will flash faster then the actual tail lights. I said I don't care how fast they flash as long as there is no other problems. He said there will be none.
    Well, he was wrong - the indicators do not automatically shut off, so the module must be required.
    It's going to be interesting to see how he hooks up the module since, like I said, there is no plugs to plug it into.
    20+ Posts
    Sep 2013
    Haverrhill, MA
    GARYD, I put LED front turn signals on my 2014 TriGlide and the LED lights worked great, but the flasher on the dash was very fast. When I installed the Harley LED tail-lights it fixed the flasher and now everything works as normal. Around the same time I installed a battery tender and had to unhook the battery for a few minutes. You may want to try disconnecting the battery because I can't remember if that solved the flasher issue or if installing the LED tails-lights did!!
    ___________________________________
    Mine: 2014 Triglide, Mysterious Red Sunglo / Blackened Cayenne Sunglo
    Hers: 2005 Sportster with Frankenstien Kit
    1975 Honda CB200 1973 Honda CB350F
    Oct 2010
    USA
    I believe it messes with the secuirty system thus causing the lights to hyper flash..had the same problem with mine until the load equalizer was installed.
    GLEN ELLYN, IL. USA
    trikermutha, thanks, I'll let my dealer know that.
    Jim, did you install the module?
    Oct 2010
    USA
    Hey one last thing make sure they plug the module in before the tail light inverter under the seat or they will not work correctly either..
    250+ Posts
    Jul 2013
    lake wales, fl. usa
    i really not sure about the lights you guys are talking about but i switched out my 1056 tail light bulbs to LED replacements, no rewiring just put them in. i was going thru to many 1056's and since putting the LED's in i have not replaced one since. i bought them on e-bay for about $5.00 each and i think they were 18 leds each and are brighter than the originals.
    20+ Posts
    Sep 2013
    Haverrhill, MA
    No I did not, didn't need it.......
    Jim
  11. #10
    GLEN ELLYN, IL. USA
    Now there's a decision. Some people say they had to install a module and some say they didn't.
    They are all LED's so shouldn't it be the same type of install???
    I've always heard that LED's needed some kind of module in order to replace a standard light.
    Need some professional enlightenment here.
    captdanwh, do you ride with the brakes on???
    I think in 40 years of riding - cars and bikes, I maybe have replaced 5 light bulbs. I can't believe I'm that lucky.
  12. #11
    1750+ Posts Trent's Avatar
    Jul 2011
    Meridian, ID. USA
    It is weird Gary...Every light on my TG is LED, plus several additional lights added beyond stock, with no module installed, and everything works perfectly. I asked my favorite tech about the modules, and he said he has never installed one in any bike that he did electrical mods on and has never seen or heard a problem.
    2011 Cool Blue TriGlide with full stage 4, a lotta other upgrades, and a lotta shiny stuff.
    Hi..My name is Trent and I am a Chromaholic.
  13. #12
    Sep 2009
    Near Myrtle Beach SC
    The module is for the turn signal flasher when LEDs lights are installed in place of the filament bulbs. The module is a resistor to keep the turn signal flasher working at the required interval flash correctly
  14. #13
    9750+ Posts Rod69's Avatar
    Dec 2011
    Lawrenceville Il. USA
    Have LED turn signals and taillights from Ride Time Tech. Also have tour pac turn signals and brake lights and LEDs in the tour pac lights. Didn't need any modules.
    Rod69 Illinois TOI #900
    Joan71 Illinois TOI #901
  15. #14
    Apr 2015
    Amityville,New York, usa
    Default LED tail light kit install,
    I have the same problem, I've spent a least 3 hrs. looking for those plugs, just wondering if your dealer found a solution.
  16. #15
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Dealer said "Canbus (2014/15) will learn LEDs and adjust flash rate. Just install, hook-up battery tender, and put on the emergency flashers for 5 minutes or so." Looking at doing the custom dynamics front turn signals on mine. My plug & play rear Radiantz LED strobe tail lamps worked perfectly out of the box.
    Bob
  17. DKCustoms postbit
  1. Champion tail lights
    By Greydog in forum Harley Trike Conversions
    Last Post: 04-24-2013, 09:26 PM
  2. Tri Glide LED Tail Lights
    By trikermutha in forum Harley Tri Glide
    Last Post: 05-12-2012, 06:56 AM
  3. blinking tail lights
    By Jimsjinx in forum Accessories
    Last Post: 07-27-2010, 10:54 PM
