Results 1 to 3 of 3
Thread: Brake woes
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Default Brake woes
    I am helping a good friend build a new HD trike this winter. He is a double amputee above both knees.
    What we want to do is control both front calipers and both rear calipers from one hand brake control. We have found a pretty large brake master cylinder that fits on the throttle side like a regular front brake setup.
    Now, here is the issue: I figured that we could purchase an adjustable proportioning valve that had one inlet and two outlets. Adjust the front to be much lighter than the rear to keep from having the front wheel slide. Hmm, I am not able to find that valve anywhere! It is either one inlet/one outlet, or two inlets/two outlets.
    Am I looking for the wrong part?
    Any ideas/help would be most appreciated.
    Stinger
    200+ Posts THEREALTRIKKY's Avatar
    Dec 2011
    Tyler, TX
    Default Re: Brake woes
    To be honest, I'd recommend going with a double lever brake set up on the front. It won't take near as much space, all of the "homework and r&d" is already done for you. There are several companies that make them for motorcycles. Also, do a web search, there are a few organizations out there that can help with this, and if your friend qualifies, may even be able to get a grant to help with the expense.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Thanks for the reply THEREALTRIKKY!!
    Doing a quick search only shows basically one that is very bulky looking and most likely insane priced
    http://www.disabledmotorcyclerider.com/klever.html
    That is a link to the one I am referring to. I don't see any prices on the site, but I would imagine it is expensive and doesn't have a reservoir for the fluid.
    It is made by Kliktronic who makes an electric shift system that costs over $1,200!
    None the less, that is the only one that I found so far.
    EDIT: I just found a place that carries the mentioned system: http://freebirdcustommotorcycles.com...a40fc4db03ac5c
    They want $2,000 for it!!!!!!!!!!
  1. To Brake or Not to Brake?
    By BELCHER in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-14-2013, 04:28 PM
  2. Gas Tank Woes
    By Doug D. in forum VW Powered Trikes
    Last Post: 02-10-2013, 09:22 PM
  3. Brake Help PLEASE RS
    By Tripacer1 in forum Roadsmith Trikes
    Owners Forum
    Last Post: 07-07-2012, 12:27 PM
  4. Electrical Woes
    By Ozarkryder in forum Honda Trikes
    Last Post: 06-15-2009, 08:54 AM
