Likes Likes:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: Clutch Switch Issue
  1. #21
    250+ Posts MDGeorge's Avatar
    May 2013
    Pensacola, Fl
    Default Re: Clutch Switch Issue
    UPDATE: Adjustments done. Radio works.
    Backup lights and running lights do not.
    Honda Tech has called CSC.
    CSC has referred to their engineers.
    Pfff.
  2. #22
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Back up lights, you have back up lights?
  3. #23
    May 2013
    Pensacola, Fl
    LOL.
    Yep
  4. #24
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    Quote Originally Posted by MDGeorge View Post
    I appreciate your input. Thanks.
    If it were the side stand, would it not cut the ignition off?
    Depends on the builder. Since the kick stand was going away he may have decided to use that part of the wiring to power the stereo and didn't know what he was doing.
  5. #25
    May 2013
    Pensacola, Fl
    FIGURED IT OUT...
    The ancillary ground from the kit was not grounded.
    That's it.
    Everything works.
  6. #26
    100+ Posts
    May 2013
    N.W. Okla USA
    if you have taken your top shelter off check to see if the antenna is plugged in good. sounds like when your standing still it is making contact but when your moving it is not.
  7. #27
    80+ Posts cmore's Avatar
    Mar 2010
    North West TN
    UPDATE: Adjustments done. Radio works. Backup lights and running lights do not. Honda Tech has called CSC. CSC has referred to their engineers. Pfff.
    So MDGeorge, the side stand switch was your problem with the audio sound? If I remember mine would not run if the side stand switch was set wrong. I had to adjust mine to or it would die when I put it in gear (if I remember right ). Mine starts and goes down the road fine.
  8. #28
    Jun 2021
    Cromona Ky USA
    Default Radio issue here also
    FIGURED IT OUT...
    That's it.
    Everything works.
    Where is the ancillary ground location?
  9. #29
    Sep 2021
    Gambrills, MD
    Quote Originally Posted by davi5894 View Post
    This thread just helped me greatly. I had the same exact issue and bike. (2012 GL18 CSC Viper).
    The ground wire I needed was the white wire from CSC Body (harness on left side with backup wiring). My issue was battery was replaced and white wire was on battery positive instead of negative.
  10. #30
    Quote Originally Posted by HPSC View Post
    Shawn.........Welcome To Trike-Talk..............
  11. #31
    Shawn welcome aboard. we are here to share our knowledge.
  1. Blower Motor Switch Issue
    By Heart Stoppper in forum Stallion Trikes
    Last Post: 11-19-2015, 10:41 PM
  2. OK, Here's My Issue
    Last Post: 02-25-2014, 09:42 PM
  3. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
  4. Acc Switch
    By Lazermanmike in forum Harley Trike Conversions
    Last Post: 07-27-2011, 03:22 AM
  5. Clutch switch
    By Patches in forum Honda Trikes
    Last Post: 02-03-2009, 07:29 AM
