Results 1 to 5 of 5
Thread: Mid engine Trike ?c
    Mar 2014
    Foothills of NC
    Default Mid engine Trike ?c
    I m laying out my first Trike. I was woundering what trans do they use. Is it a 914 or modified bug?
    550+ Posts
    Feb 2012
    tupelo MS
    Default Re: Mid engine Trike ?c
    Turn the ringgear around, it goes the other way. VW bug.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    It is fairly simple to flip the ring. Pull the whole differential unit out one side and stick it in the other side. The ring and pinion is helical not hypoid in the vw diff so it does work. Check your backlash/ shimming when you do.
    You building a swing or a cv?
    Narrowing it?
    How low are you wanting to go?
    I have my mid very low. 3-1/2 inch to the drain plug.
    Mar 2014
    Foothills of NC
    I have both swing and IRS trans. I also have a set of 3" narrower swing axles left over from a drag car that I might use if I with swing axle set up. I m trying to educate myself and gathering up front end parts.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Of course you know a swing is easier.
    So how low ya wanna go?
    They build them like this in Sweden all the time. Most them guys run very short tires to get it low like a motorcycle.
    You can squat an irs as long as the axles stay long enough.
    I did the machine work and run my swing upside down old school formula v style.
    O... and it is a 65 short axle that is cut 6 inch each side. 48 inch wide total to the outside widest point.
  1. Trike with GPZ500 Engine
    By atilacarmen in forum Home Built Trikes
    Last Post: 07-04-2014, 02:32 PM
  2. Replies: 10
    Last Post: 11-04-2013, 09:50 AM
  3. GW Trike Engine Oil Over-Filled
    By Goldrush in forum Honda Trikes
    Last Post: 10-16-2013, 08:10 PM
  4. Engine size/trike-weight vs. MPG
    By Beast-of-Burden in forum General Discussion
    Last Post: 10-30-2011, 11:32 PM
  5. Mid Engine Trike
    By ralco in forum General Discussion
    Last Post: 09-10-2011, 08:52 PM
