Likes Likes:  76
Thanks Thanks:  2
Page 7 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 121 to 140 of 228
Thread: We're Here to Help!
  1. #121
    Sponsor - Roadsmith Trikes
    TrikeTalk Sponsor
    Roadsmith Trikes's Avatar
    Mar 2008
    MN
    Quote Originally Posted by Sally View Post
    Thank you Jim !!
    Wow!!
    That was a lot of info and I will pass the tire recommendations along to my hubby, the "mechanic"
    Comes in handy to be able to do a lot of the work ourselves and he did tell me that he'd been in contact. Very impressed how you offer your help to Roadsmith owners no matter if we're the original, second, third owner!! It's much appreciated !!
    Sally
    Thanks Sally! Again, let us know how it all works out. Have a great weekend.
    Jim
  2. #122
    400+ Posts mgwtrike's Avatar
    Nov 2014
    Loving the Southern Life in Central Florida
    Can you tell me were the Roadsmith service centers are in central Florida.
    I live near the villages south of Ocala.
    Thanks.
    Goldwing:
    A real butt kicking, wheel popping, tire burning old man's bike.
    MIKE W.
  3. #123
    30+ Posts
    May 2015
    Yulee Florida USA
    Default Roadsmith
    Check their website
    I believe there is one in Inverness at Trikes r Us. If not Trike Shop Daytona is a nice day ride for you. See Dan. He is top notch and a pleasure to talk with and a experienced and knowledgeable Roadsmith guy
    Hope this helps
    Jim
    Jim
    2015 Wing / Roadsmith:banana-cyclops:
    :banana-cyclops:
  4. #124
    TrikeTalk Sponsor
    Mar 2008
    MN
    Quote Originally Posted by mgwtrike View Post
    Thanks.
    Dawg is right - we have a dealer in Inverness. Great company called Trikes by Design - Larry will take care of you. Alternatively, The Trike Shop of Daytona can help also. Information below.....
    Trikes by Design - Larry - 866-344-8637
    The Trike Shop of Daytona - Anne or Dan - 888-396-8139
    Let me know if need any more information or anything else I can help with!
    Jim
  5. #125
    200+ Posts Hocky's Avatar
    Jun 2014
    Delray Beach, Florida
    Default Roadsmith aux tank
    Quote Originally Posted by Roadsmith Trikes View Post
    Hi Everyone! Roadsmith Trikes is here to help with answers to questions or anything else you might need for your Roadsmith Trike. We will be checking this forum regularly and promise to get back to you as quickly as we can. If you need immediate assistance, please don't hesitate to call the main factory number 800-331-0705! Thanks and we look forward to chatting with you!
    2003/2004 RS/GW trike. Never used the aux tank, concerned about using whatever is in the aux tank so I'd like to drain/flush it out prior to use it. I'm at least the 2nd owner. Suggestions please!
    thx.......
  6. #126
    Sep 2012
    Lakeland, FL
    Default Rotor Warp
    This is not a complaint, only a comment, I love my Road Smith. My problem a warped rotor, or rotors. I think it's the right rear, where the manual brake engages. Right now, it's in the the Trike Traders in Lake Afreld shop 'cause I did not want to make that long trip to Daytona with those logistical problems. The owner put his run out gauge on both rotors, couldn't find a problem, seems the rotor began to flex out of round as it warmed up on the ride and got worse as the ride continued, the feel was 'very pronounced'.
    Since the owner could not locate the problem in the shop, he probably did the only thing he could, ordered two new rotors from Road Smith. At $90 a pop for rotors, shipping and labor, this is gonna be costly, but it is what it is. By the way, this owner is a good builder, been doing it for years, I have no reason to doubt his abilities.
  7. #127
    TrikeTalk Sponsor
    Mar 2008
    MN
    Quote Originally Posted by Hocky View Post
    thx.......
    Hocky - I checked with our lead trike installer, and he stated the easiest way to clean the tank (other than physically removing from chassis) is to drain the tank via the main transfer line. To do so, locate the transfer pump on the main trike frame. There is a fuel line coming out of the lower part of the auxiliary tank that you can follow up-stream to the pump. Clamp the line before the pump, remove line from pump, and remove clamp to drain the residual fuel into a suitable container. Depending on what you see coming out of the tank, may want to flush tank with fresh gas before reassembling the line.
    If you have any questions about doing this, or help locating the pump, PLEASE call 800-331-0705 and ask for Mark. He is always happy to help.
    Thanks!
  8. #128
    TrikeTalk Sponsor
    Mar 2008
    MN
    This is not a complaint, only a comment, I love my Road Smith. My problem a warped rotor, or rotors. I think it's the right rear, where the manual brake engages. Right now, it's in the the Trike Traders in Lake Afreld shop 'cause I did not want to make that long trip to Daytona with those logistical problems. The owner put his run out gauge on both rotors, couldn't find a problem, seems the rotor began to flex out of round as it warmed up on the ride and got worse as the ride continued, the feel was 'very pronounced'. Since the owner could not locate the problem in the shop, he probably did the only thing he could, ordered two new rotors from Road Smith. At $90 a pop for rotors, shipping and labor, this is gonna be costly, but it is what it is. By the way, this owner is a good builder, been doing it for years, I have no reason to doubt his abilities.
    Bikerbillone - Sorry to hear about the rotor issue. Hope all gets fixed right and no more "pedal pulse". You are right about the folks at Trike Traders. They know trikes!
  9. #129
    Sep 2012
    Lakeland, FL
    Thanks much, good vote of confidence for Doug at Trike Traders, I'll pass it along. I think my problem is only with the rear right rotor, the hand brake rotor. Several months ago, I had it slightly engaged when I thought it was fully in the released mode, so I could smell it getting warm in a mile or so, I immediately knew the problem and fully released the hand brake, but probably not before there was some damage to the rotor metal. Oddly it took a while to get to the noticeable pulsating. I'm probably paying an extra $90 plus freight for the left rotor, but it's all good if it cures the problem. I thought a full post on this might shed some light on the problem...Again, thanks for the response.
  10. #130
    Sep 2016
    Springfield, Mass. USA
    I just converted my beloved 2010 Honda Goldwing into a Roadsmith.. I just took my first ride on a trike two days ago [3/6/17] my question is also that I don 't have an owner's manual either..
    I found that I took to a trike like a fish in water (I didn't have a problem adjusting to it at all) and I've been two wheeling it for over 50 years..
    I had it converted by the trike shop in Keene New Hampshire...
    I do have a couple of questions, and would love to talk to someone with trike experience, it's easier to talk to a real person instead of texting....I'm totally glad I made the switch, and love the new ride..
    Springfield, Massachusetts
  11. #131
    Sep 2016
    WoW! Am I a happy boy here, I call the 800 # to Roadsmith and spoke with a gent named Jim, he was very, very helpful and answered my questions.. I have to admit after I hung up with him I had a smile on my face....I'm totally a newbe here and his answers totally relaxed my mind...
    Thank you Jim
    Ronnie from Springfield Massachusetts
  12. #132
    TrikeTalk Sponsor
    Mar 2008
    MN
    Let me know what Doug finds out. Thanks!
    Jim
  13. #133
    TrikeTalk Sponsor
    Mar 2008
    MN
    Thank you Jim
    You're welcome Ronnie! Thanks for the nice comments and thanks for being our customer. All of us at Roadsmith appreciates you!
    Jim
  14. #134
    Sep 2012
    Lakeland, FL
    Will do Jim, picking up it up this morning, I'll quiz him. I know this is gonna be financially painful, so if I'm doing something wrong, I want to know it and correct. I'm not hard on braking, so I'm not sure where I can improve. As I mentioned in a previous post, it's possible I left the manual hand brake engaged just a bit, could have heated the right rear rotor so there was some molecular change in the rotor metal cause heat transfer to the rotor causing a pulsating warp. just my opinion which ain't worth squat.
  15. #135
    Sep 2012
    Lakeland, FL
    Jim, as promised, just got home and talking w/Doug, he could not specifically pin point the cause, and he's been in the business a very long time. He's seen many out of round rotors on cars and some on trikes, with no apparent cause, the fix is to replace. According to Doug, attempts to turn the rotor may be a losing proposition, if the rotor/rotors get warm again, then it may do the same thing.
    He could not positively identify the out of round rotor, so both were replaced. He has the rotors, so if you'd like to have them, then he could do that. He has no idea that you could identify if the rotor/rotors were defective in manufacture, or whatever the cause, considering the cost of return, that might be a negative, but he has them if you want them.
    He's convinced it was not a dragging brake, or some mechanical thing. He's not willing to ship them back at his cost which make sense. I touched checked the rotors after the ride home, they were warm and not hot to the touch, the pulsating problem is gone, nice smooth ride now. The OEM replaced rotors had 31,777 miles on them.
    What I might do is disconnect the manual brake so there's no issue there, if there ever was one. One last thing, this fix cost me a whopping $420.94, so I'm taking every precaution I can so this does not happen again.
  16. #136
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Thank you Jim
    Ronnie,
    That gent named Jim is the owner of Roadsmith, or actually one of the two, the other one being Doug. Jim is the guy answering all the questions here and knows his stuff and is a pleasure to talk to. I talked to Jim yesterday myself and was smiling too. Attaboy Jim!
  17. #137
    Sep 2012
    Lakeland, FL
    Default 3M (?) Fender Protectors
    RS, I had the clear fender protectors put on when I got my 2012 conversion. Is there anywhere I can buy these protectors and put it on myself?
  18. #138
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Look on the interweb , there are a few that sell it by the roll.
    all you do is cut to size.📞
  19. #139
    Sep 2012
    Lakeland, FL
    Thanks, but don't need a roll of that stuff and I'm awful with scissors, think I'll try for the precut if I can find it. I know Road Smith put it on precut, so it's out there, somewhere, hopefully they will monitor this and respond. I'll call them if they don't comment here, I thought someone else could use the information, that's why I posted on the Road Smith "We Can Help".
  20. #140
    10+ Posts Patch's Avatar
    Mar 2017
    Almond, NY USA
    Post Thanks
    The smartest thing we’ve done, over all the years attending Daytona Bike Week, was revisit Roadsmith Trike in 2017. With age reminding us three wheels brings the fun back to cruising, we stopped in the shop, saw a 2005 Goldwing Trike, and a few days later, purchased it.
    Anne, the Manager, and the crew walked us though the
    transition from 2 to 3 wheels. The honest answers to our questions made things happen. Anne had us out of the office quickly with a pink slip. She provided a shipping agent to deliver the Trike to a cycle dealer in Western NYS. The Trike was delivered in a brief time. Roadsmith Trike forwarded the previous owner’s accessories, manuals and parts in the trunk.
    The service agent at Arkport Cycle, a man that has serviced several cycles purchased in Arkport, did a NYS Inspection, and Serviced the Trike. He was impressed with the Trike and found no issues of concern. If you’re thinking of shifting to a Trike, and are in Daytona, it would be worth your effort to stop at Roadsmith Trike of Daytona Beach! Check their http://www.roadsmithtrikes.com/daytona/ postings.
Tags for this Thread
