Yes, good post Patch, have to agree since I got my conversion at the Daytona Trike Shop. Been happy with my RS Trike, which happens to be a 2005 GW/2012 conversion.
I just found out (after owning my trike for 2 weeks) what kind it was!! The dealer I bought it from said it was a Lehman. Nothing I was seeing on the bike made sense. I found out it is a Roadsmith. Now...what kind of brakes go on the rear? I ordered an 8 degree triple tree. Now I see they said a 6 degree is what I need!! Is this going to make a difference? HELP??
Congrats on the "new to you" trike! Valkyries do make great trike conversions. Particularly like the extra chrome on those bikes. The rear brakes are a VW application. If looking for replacement brake pads, here are a couple common suppliers with their part number. EBC (DP-105), Napa (TS-755), Federated (D30A).
A six-degree steering kit will work just fine on the trike. An 8-degree might be a little too much. Let us know if any more questions or anything else we can help with.
Jim
2005 GW with 2012 RS Conversion., Owner's manual says add 1 qt not over 1" from fill hole. Did I read somewhere that the 2012 conversions had two different differentials, one was a bit less that 1 quart? That fill hole is difficult to get to to feel 1" from top. Guess my question is, if I put 1 quart in, is there a chance overfill?
Thanks Jim, man it is tight getting to that filler with the aux tank and the trunk, is there a special procedure, special wrench, deep socket?
Bikerbillone - our guys use a deep socket and ratchet to get the fill-plug off. You may want to consider filling the differential through the drain plug (hole) using a hand-pump similar to those used to fill the lower-unit of an outboard motor. You can find them at a marina or auto-parts store.
Jim
I have a 2006 GL1800 with a 2012 Roadsmith trike kit. I have 54K miles on the rear tires, and the left tire has what looks like negative camber wear ( inside tire wear on inner edge of tire)
Has anyone out there had this problem, and if so what did you do to correct it. Is there such a thing as a "wheel alignment" for the rear wheels of a trike.
The right side tire is wearing normally
Mike
Northern MI
Just guessing, I probably have 40K on my RS tires and they're wearing really well. I have Ride-On in them from early on, it works for me. I have no interest in the product, it just works for me.
Hi Mike - thanks for your post. 54,000 miles is pretty much at the end life of the rear tires. Even though it may seem that the tires should last forever given the light duty application, its actually the quicker acceleration and braking from a trike application that wears down the tires. There is no "easy" adjustment for camber, and considering the mileage you received out of these tires, and the fact only one tire is worn, I would suggest putting on a new set of tires and keep an eye on them. Let us know if you see any unusual wear within the first 10,000 miles. That's a good indicator of potential suspension issues.
Jim
I already have new tires on, so I will look at them around 10,000 miles
I'm ordering my RS HDTR tomorrow with Lucky Cycles. Please expedite the shipping. Thanks.
Seeya...
Was glad to see Dan running the Roadsmith shop out of All Out Powersports
on Beach Blvd in Daytona ... Old shop closed and for those who do not know
the Daytona Beach shop is right across the parking lot from the old shop .. Have a
good retirement Dick .. You will be missed around the old digs ...
G. Marshall Gammon (USN-Ret)
New Bern, NC
2015 Can Am Spider RT S
Good afternoon RoadSmith,
In Apr2016 we purchased a 2008 GL1800 w/ the HTS Conversion. The Aux Fuel Tank had been added to that conversion. My question is this; when re-filling the aux tank we seem to have a problem w/ splash-back. I have tried every trick that I can think of to stop that splash back but now have to wonder if that may be a venting problem?? Is this a common occurrence w/ the HTS 1800 Kit? A very good Friend also had an 08 GL1800 w/ the HT100Kit, he did not have that problem when re-filling his Aux Tank. Any info and or guidance will be greatly appreciated. THX and looking forward to hearing from you
Hutch
(ME)
I agree, that fill pipe is tricky with a curve down in there that's restrictive especially as the tank fills. I think the capacity is 5 gallons, correction pls if I'm wrong. So when I get to 4 gallons I am very careful maybe moving the nozzle up to allow an air escape and I can see a little bit down into the nozzle, doing the off/on thing with the handle. Even then, some of the spring loads are so strong, it's difficult to squeeze There are times when I'm careful as possible and still get some slosh on the fender. Bottom line, I don't know any way to be perfect in the aux tank refuel. However, fuel up that aux tank, and ya get a better ride.
It is a bit problematic but it is what it is I guess. At some point may consider pulling the Trike body and checking the vent lines but until then..... And agreed with the better ride, and just having the comfort of knowing you have that extra mileage is well worth the aggravation of keeping it full.
THX and Merry Christmas to All!
Hutch
SORE SHOULDERS?
Get The Right Cure
TriGlide Rake Solutions
Get Info HERE
Support YOUR Trike Talk Forum Community & Get Upgraded Features & Free Merch with a Gold Club Membership!
Click Here For Information
Visit Cut-N-Shoot Customs Website
Text or Call Papa: (346) 800-7946
Email: info@cutnshootcustoms.com
