Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  2
Results 1 to 13 of 13
Thread: 09+ Stabilizer
    250+ Posts onahog's Avatar
    Aug 2012
    Portage La prairie,manitoba,canada
    Default 09+ Stabilizer
    Has any one tried one of these on their 09+ TriGlide?....
    I did put a dampner style link on the front of engine, but wondered if one of these would be of benefit as well?????
    HaNkB
    800+ Posts FLTR2008TRIKE's Avatar
    Sep 2009
    Near Myrtle Beach SC
    Default Re: 09+ Stabilizer
    Quote Originally Posted by onahog View Post
    HaNkB
    See my post #6
    http://www.triketalk.com/forum/threa...ies-stabilizer
    Overcoming Adversity is the path to better ideas!!
    2008 Roadglide w/ MOTOR TRIKE Kit
    S&S 124" Headwork & Custom designed cams by John
    Custom made right side shifter (Lost my left leg above the knee due to a hit n run driver) SOOS's custom made floorboard spacer
    Aug 2012
    This kit is designed for the 09+ models..It bolts to the starter housing and I presume to the frame near where the right heat deflector goes...I do believe the rear does flex on my trike, and with the dampner style link added to the front, allows the rear end to twist even more...I can see how the rigid link on the front breaks the bolts off the head from swingarm / engine twist and just wondering how this kit would work and if it would put strain on the 2 starter housing bolts, or the frame area for that matter...Hmm...Always new products and we are the testers..!!!
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    When Harley designed the frame for the Triglide they beefed it up, I'd be shocked if it twisted. I've had the front end up a couple times, done some burnouts and hammerd many of windy roads and never felt any flex. I'd be hesitant to stiffen things up more than they are.
    http://i1347.photobucket.com/albums/...pswnuweejq.jpg
    Red Ultra Powered By Head-Quarters 120, Easy Clutch Pull By ClutchWIZ. 2012 GL1800 Hannigan. I've yet to ride a stock Harley which wasn't in need of a mechanical intervention.
    Aug 2012
    Mike...I was referring to the powertrain twisting in the frame, not the frame itself twisting..it seems as even tho the powertrain is mounted on 4 isolators on the 09+ that they still twist..This is what puts strain on the upper front link which tends to break the bolts in the head off...Now that iv put a dampened link on there, it appears to me I have allowed the powertrain to twist, somewhat like the previous 08- version on just 3 isolators...This kit appears to mount to the starter bolts and frame to keep the rear of the powertrain from twisting in the frame...Not sure if its a good idea or not...
    Im just reaserching the product too see if anyone has actually put one on a 09+ chassis, 2 or 3 wheeled..HanKb.
  6. DKCustoms postbit
  7. #6
    Sep 2009
    NE Ohio
    Oops, good old night shift head up the butt ides kind of bit me. I'd watch things real close if you decide to give this a try, its bound to place stress on the inner primary which might crack it or cause a leak.
  8. #7
    100+ Posts FuLong's Avatar
    May 2016
    Munich, Bavaria, Germany
    Default Experience with Alloy Art Touring Stabilizer?
    I have to do some revitalization on this thread
    At the moment I have the problem with a broken bolt on my front motor stabilizer. Hopefully my mechanician can fix it fast, because it's season opening
    The threadstarter mentioned the Alloy Art Touring Stabilizer - has anyone installed this thing on a Tri Glide?
    How is the experience? Especially with a view on the front stabilizer and the force on it?
    OS X is like a wigwam: no windows, no gates and an apache inside!
  9. #8
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by FuLong View Post
    Hans....The broken bolt is an easy fix, If the mechanic gos about it in a calm way, I had mine break on my 11 Tri-Glide, ..I Very lightly with a chisel taped the bolt counterclockwise , It should spin out, The reason it broke was the bolt was loose and the mount guillotined it.. Sometimes the will try an easy-out.....And if their not careful with that they will booger the cylinder head and then that will have to be replaced also...$$$
    2019 Tri-Glide.......
  10. #9
    May 2016
    Unfortunately it is a problem, because it is the inner bolt, covered by a frame tube and, it broke about 0,2 inch deep in the head.
    The thread fortunately seems to be intact, but he has to pull the head, for a save removal of the remaining part of the bolt
    Today is a holidy, he can provide the head seal tomorrow, Monday is the next holiday, so the work starts on Tuesday ... hopefully, the head has no further damage.
    Anyway, fortunately this is covered by warranty.
  11. #10
    2500+ Posts trikermutha's Avatar
    Oct 2010
    USA
    Quote Originally Posted by msocko3 View Post
    Haven't seen Mike on these threads in awhile. I liked his wisedom
  12. #11
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    If it is covered by a warranty?, You did say its a 09...
    Then outside of the downtime....Problem solved.....
  13. #12
    200+ Posts
    Apr 2017
    Murphy, Texas, USA
    I think he was saying the stabilizer fits an '09 to present.
  14. #13
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by Freewheeling Ron View Post
    Ok, Thanks i looked up his profile, And he has a 2015...
  1. stabilizer link
    By waynerid1 in forum Harley Trike Conversions
    Last Post: 04-04-2014, 11:08 AM
  2. DBI Steering Stabilizer
    By ZED in forum Harley Trike Conversions
    Last Post: 08-21-2013, 01:24 PM
  3. Steering Stabilizer
    By Lakeman in forum Harley Trike Conversions
    Last Post: 01-23-2013, 06:31 PM
  4. TG steering stabilizer
    By onahog in forum Harley Tri Glide
    Last Post: 09-30-2012, 06:27 PM
  5. Steering Stabilizer
    By crzrlou in forum Harley Trike Conversions
    Last Post: 01-04-2010, 12:20 AM
