Results 1 to 17 of 17
Thread: Air pressure settings
    200+ Posts rayg5102's Avatar
    Nov 2012
    New Market MD
    Default Air pressure settings
    I'm sure this has been asked, but I searched and can't seem to find it.
    I have 2010 HD trike and trying to figure the best tire pressure.
    Tire says 44 PSI for rear but that seems high.
    Also the pressure for the shocks. 50 seems recommended in the manual.
    So I just wanted to see what others are doing
    any suggestions?
    40+ Posts
    Aug 2012
    meridian, id
    Default Re: Air pressure settings
    Quote Originally Posted by rayg5102 View Post
    any suggestions?
    36-38 in the front.
    24-26 in the rears.
    50 lbs. In shocks Is max with max. weight and two up. 30-32 lbs is what I run. You should play around with the shocks to find your own comfort.
    Trike Talk Executive Chef
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    Yep,
    36 in front
    26 in rear
    I run 20 lbs in the shock for me.
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
    Member Patriot Guard Riders
    250+ Posts Shriner Jim's Avatar
    Apr 2010
    Greeneville, TN
    36/26 PSI. Can't go wrong.
    60+ Posts chiefbuc's Avatar
    Dec 2010
    Versailles, Missouri, USA
    Rear tires: 25/26
    Front tire: 35/36
    Rear shocks: 50 with wife and I
    I have ran these pressures in both my 2010 and 2014 TG's and I feel for myself that the handling is better with a passenger. Other pressures I do not feel comfortable while maneuvering in traffic and turns.
    Have a good summer.
    Jun 2010
    Indianapolis, In.
    Those rears are car tires, as I'm sure you already know. Pay no attention to the max pressure molded in those tires.
    Posts above are correct. 26psi is a good starting place to "see" what's best for you as is 36psi for the front.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    250+ Posts
    Jul 2013
    lake wales, fl. usa
    i run 38lbs. in front radial tire and 25lbs in rear tires. shock air pressure is set at 20 to 25 psi whether i ride one or two up. if i load the trunk and luggage rack i will go up to 30psi i shocks.
    450+ Posts tbear's Avatar
    Sep 2013
    Carleton, Michigan
    38lbs Front,24 rear tires,40 in air shocks (progressive shocks) 2 up. Be careful with rear tires at low pressure if you have bad roads in your area (pot holes etc) could come up with a bent rim if you hit one with low air pressure in tires. Blew the right rear air shock (originals) hitting a pothole. Seal blew and oil all over the place! Got the better Progressive HD shocks and hope they do better.
    Here in Michigan, us 3 wheelers look like we are drunk going down the road trying to get around the pot holes!
    TBEAR
    2010 Triglide Harley Davidson
    V&H Exhaust,True Duals, Big Sucker Ac,,557 S&S Cam,SE Compensator 2014, oil cooler,EBC r.brakes,Progressive air-shocks,Floorboard extensions,rear fender bras, Dynoed,krome-werks 2+2 bars, and a sheep wool butt protector....
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    38 front, 22 rear. This is what I ran all the way up to the arctic circle & back with no issues...and at this link you can see some of the roads we encountered.
    http://www.triketalk.com/forum/threa...Back-Pic-Heavy
    For rear shock PSI, the suggested PSI in the manual does not seem to have any relationship to reality.
    I have found the best way to get the best PSI in the rear shocks is to find a road with a rough section that I can make multiple passes on.
    I pick an arbitrary PSI and make a pass over the rough spot. I then change the PSI 2 lbs and make another pass. I keep doing this, making the 2 lbs psi change (BOTH above and below my starting psi) until I find the "sweet spot".
    www.DKCustom.com
  11. #10
    60+ Posts
    Sep 2010
    St. Ann Missouri USA
    I think the factory settings in the manual were just copied from the 2 wheeled touring specs. The mpg is the same as are many other settings. I think harley figured they weren't changing much in the way of drive train etc. Why revamp the manual? It kinda makes sense, but kinda don't!
  12. #11
    Nov 2012
    New Market MD
    I like the idea of multiple passing down the same track. Good idea.
    I thank all for the inputs.
  13. #12
    100+ Posts 470004's Avatar
    Sep 2013
    Astoria, New York, USA
    Quote Originally Posted by Sully View Post
    Yep,
    36 in front
    26 in rear
    This is what I run.
  14. #13
    Sep 2013
    Carleton, Michigan
    You could come to Michigan and have no problems finding roads to test the Shocks, Springs, etc......
    TBEAR
  15. #14
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by tbear View Post
    I've been on some of those roads up your way.
    www.DKCustom.com
  16. #15
    100+ Posts mcdonaldroadcapt's Avatar
    Oct 2010
    Canton, Georgia
    Figured out today from trial and error that 225/50/15 needs 32.0 lbs. Lower than that, tire looks flat and effects mileage. 32 perfect ride and visual perfect from sidewall. Still run 40 in front. Set air shocks at 30. Beautiful handling and comfort. Well pleased.
  17. DKCustoms postbit
  18. #16
    5+ Posts Mojave's Avatar
    Jul 2014
    USA
    I tried a few combinations in the rear with 36 up front, but the HD engineers do have some experience, so I go with 36/26 and 30ish in the shocks without a guest or fully loaded, otherwise it's 50 and there's no complaints. The only real issue is riding a really bad road on a trike. It dances around like a dually on crack. But I'm tough. :-)
  19. #17
    60+ Posts Alan Oakley's Avatar
    Apr 2010
    Peeltown, TX
    14 Triglide......36 front 22-24 rear and 15 shocks....seems to work best for me based on local roads
  1. tire pressure???? suspension pressure???
    By flangar in forum Stallion Trikes
    Last Post: 05-10-2014, 09:53 PM
  2. air pressure
    By catfan in forum Harley Trike Conversions
    Last Post: 06-23-2013, 03:36 PM
  3. oil pressure
    By grampadonut in forum Harley Trike Conversions
    Last Post: 05-25-2011, 07:34 AM
  4. Air pressure
    By molinoman in forum Stallion Trikes
    Last Post: 05-28-2010, 07:07 AM
  5. air pressure
    By jim peacock in forum General Discussion
    Last Post: 04-22-2009, 10:07 PM
