- Moderator
- #141
If I remember right the cat was in the muffler in 09 and 10. Moved to the head pipe in 11.
The Project Tri-Glide has been wrapped up. You can see the summary at this thread-
http://www.triketalk.com/forum/thre...ROJECT-TRI-GLIDE-Report-w-Lots-of-Pics/page23
Ya know Kevin - That really is a nice looking Trike....jc
Only the 2009 CVO's came with a cat converter,other than CA. 2010 was the first year for extensive use of one.
I might of missed it but; what Seat and Spark plugs are you running on your Trike? I did read you changed wires but plugs? and rear shocks, now? thx. for any info. back. tbear
That is the stock seat. Running a HD riders backrest. The Tour Pak has been relocated back 3". Mary modified her backrest on the Tour Pak.
I'm running OEM plugs. Many years ago I spent a lot of time testing a slew of different aftermarket plugs, even the HD Screamin' Eagle plugs. Some of them did not work as well as the OEM, others I could not tell any benefit from.
Plug wires are a different story. We did a study a few years back. Tested over 50 new OEM plug wire sets, and over 100 Screamin' Eagle Plug wire sets. There was a high % of them (somewhere around 50%) that were NOT within spec, new, out of the box.
Not only do the engines run better with a stronger spark, with the ION sensing for knock retard being sent over the plug wires, it is really important for them to be in spec to get best power and mpg.
Most bikes that we put These Wires on, there is enough of a performance increase that you can feel it in everyday riding....it's not a lot, but it is definitely there...a bit crisper throttle response.
What have you found works best for rider to rider communications with the HD infotainment system in the 2014 Triglide ??
Thanks for sharing all of your stories with us.
mark
Did you video deals gap with a go pro, if so how did you mount it?
Nice ride. Lots of good ideas
I have 2017 triglide I like what you did with the extra space filler for the back rest and seat after moving the tourpak back
I also had to move mine back and can not figure a good solution for it any way of getting one made up of course i would pay the green for it
Kevin,
Did u monitor the oil temp with the dipstick HD oil temp gauge or did u use something else? I remember u saying at the beginning of this thread your temp gauge died.
Tony
Thanks Kevin for the reply.
Is there somewhere to mount the HD oil temp gauge kit in the dashboard like the '09-'13 by replacing the 'air' temp with the oil temp on a '14+?
Maybe this will work on the '14's and newer? https://www.jescustomaccents.com/20...-Gauge-All-FLs-07-16-Wht-Air-FL-Temp-15OD.htm
