Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  14
Thanks Thanks:  2
Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 62 of 62
Thread: The Tire Thread / Answers Questions / Gives Options / Use at your own risk.FYI - ONLY
  1. #61
    70+ Posts
    Nov 2018
    San Angelo, TX, USA
    Cool Great information on tires
    Hello, thank you for researching and posting all this wonderful information in one spot.
    Good job my friend,
    David Hilton Ret. USN ETC/SS
  2. #62
    500+ Posts
    Feb 2008
    Planet Earth, Alpha Quadrant
    Quote Originally Posted by Bullishwwd View Post
    I am new to TRIKEs and don't understand the logic of putting a 'rear tire on front' of Trike,
    It will handle much better and the front end will remain planted on the ground. it will also give you a more confident feel
    'reversing tire direction'
    Controversy here.
    I could get in to the science of overlapping belt joints and blah blah blah...
    But the most glaring reason is that the read direction on a normal mounted rear tire is revers from the front tire. you run it backwards so that the directionality of the treads is maintained
    and running 41 psi in front tire while only 20 psi in the big rear tires.
    42 - is the normal recommended setting for a front mc tire, Trike or not.
    For the rears its a different matter. A car weighs more, and therefore the tire is inflated to hold up that weight., and maintain a flat contact patch.
    On the other hand a trike weughs considerably less and if you inflate it to the recommended pressure it will bulge at speed like an overinflated tire. thus wearing ot in the middle. Secondly because there is not as much weight, the sidewalls are not going to fles, ie giving you comfort..
    Most usually run about 22 - 26 pounds depending on the trike and personal tastes
    Rake...
    Never had it....
    Never will...
  1. Tire Pressure Thread
    By WEB in forum Tires, Wheels, Brakes, Front End
    Last Post: 06-17-2014, 08:42 AM
  2. 07 Venture / Hannigan Trike options questions.
    By Craigatcsi in forum Yamaha Trikes
    Last Post: 03-30-2014, 06:38 PM
  3. Answers to Trike Questions from "Those People".....
    By skuuter in forum General Discussion
    Last Post: 12-17-2012, 04:05 PM
  4. Front Tire questions
    By SJR in forum Harley Trike Conversions
    Last Post: 06-18-2011, 11:21 AM
