Likes Likes:  14
Thanks Thanks:  2
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 40 of 62
Thread: The Tire Thread / Answers Questions / Gives Options / Use at your own risk.FYI - ONLY
  1. #21
    1250+ Posts bustedwing's Avatar
    Mar 2012
    Hermansville, Mich. USA
    Default Re: The Tire Thread / Answers Questions / Gives Options / Use at your own risk.FYI -
    I have just installed a Michelin Commander on my trike and would like to know what the break in process is for this tire. Thanks, Bud.
  2. #22
    550+ Posts Solidbob's Avatar
    Tx
    Well I'm confused, if its for the GL1500 in the Avatar that should be a 160/80X16 size and they do not make the Commander II in that size / now they do make it in a 150/80X16 which is slightly slimer. They do show to be Bias Ply and in that size its a Rear Tire for your front. I've never used that tire so I guess you will be our tester... I'd run it just like the Pilot Activ at 40 - 41 PSI and keep us informed about mileage....
    Guess you'll be able to tell us how they work on the front of the GL 1500.... Keep us informed....
  3. #23
    Mar 2012
    If I remember right it was 130/70hX18 and so far it rides a lot smoother than the radial tire I replaced.
  4. #24
    Tx
    Quote Originally Posted by bustedwing View Post
    You must own a GL1800.....
  5. #25
    Tx
    Quote Originally Posted by RichM View Post
    Thank you Bob, very informative. I am having my conversion done as we speak and since I am a newbee to trikes did not know about replacing the front tire with a rear for better performance. I am going to replace my stock front with the Michelin. Since we are on the conversation of tires, when I choose my Motor Trike kit there was an option for the rear to upgrade from 15" to 17". I called MT and they said it is just a matter of preferance/apperance that it will not effect performance. Any opinions on this? Thank you.
    Depending on tire profile used by MT the 15" may be easier to work with and clear the fenders easier. Most companies that offer different sizes of rims make up the changes in profile by height so the 17" wheels will use low profile tires I bet to keep the speedo near correct.... Just FYI
  6. #26
    Jan 2014
    Harvard
    Good info. thx.
    97 wing with B-stone G-709, 8 k miles and worn to wear bar. Don't use.
    Sy Brule
  7. #27
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Bridgestone rear tires wore out in 8k?
    If it is on the font , than read about rear tire mounted on front in different section of this forum.
  8. #28
    200+ Posts Hocky's Avatar
    Jun 2014
    Delray Beach, Florida
    PO put 17" on rear of 2003 GW/Roadsmith. Not raked, no Super Brace. I get lots of headshake when weight is shifted during shifting & decelerating. It's new to me so I'm still getting used to this trike. Should I look towards rake kit, Super Brace, or play with the rear tire pressure? Or, "I" might need more miles on it 1st to get more experience? I've tried 24 to 28 lbs so far.
    Thanks, Ron
  9. #29
    200+ Posts
    Aug 2011
    Maryville, Tennessee
    Many thanks!!!
  10. #30
    Jan 2011
    Bristow Ok USA
    This is probably elementary to you guys, but my Honda trike has a bias tire in the steer and radials on the rear. Why is that? Also does a rake make steer tires last longer of do I need one? I was told it makes big difference in handling and stops low speed shimmy.
  11. #31
    Tx
    Your drive tires can be radials, but your front tire should be a Bias Ply Rear Sportbike tire in the correct size for your front tire. The stock radial bike tires were made for a leaning bike to stay in the middle of the tire, and radials tend to roll on their sides when used with a raked non- leaning trike. The bias tire will have almost twice the amount of rubber in a wider center tire area, and the Bias tire has a stronger sidewall and won't roll in turns. Most trike guys like the MPA Michelin Pilot Activ or the BT45 Bridgestone Battleax ... if you have a non raked trike they are harder to steer as you steer a trike not lean, adding a EZ Steer or rake kit 4.5 to 6 degrees will give you power steering, and takes a bit to change-over to but your arms will thank you if riding twisty roads...
    "There comes a time in your life, when you walk away from all the drama and people who create it. You surround yourself with people who make you laugh. Forget the bad, and focus on the good. Love the people who treat you right, pray for the ones who don't. Life is too short to be anything but happy. Falling down is a part of life, getting back up is living."
  12. #32
    1750+ Posts Ol' Man Jeb's Avatar
    Sep 2013
    Bettendorf, Ia
    Got some Q's need some A's I have a '96 GL1500A w/Motor Trike conversion. My rear tires are BF Goodrich Radial T/A P225/60 R15 95S M+S and are in good shape. My front tire is a Dunlop 130/70 B18 63H with only 2/32nds tread left. I want to replace it with an Avon Cobra AV71 130/70 R18.These tires came with my purchase. Am I climbing the wrong tree? Thanks for your input.
    "The difference between genius and stupidity is that genius has its limits". Albert Einstein
  13. #33
    80+ Posts 6X3's Avatar
    Nov 2014
    Lincoln, Nebraska
    Quote Originally Posted by Ol' Man Jeb View Post
    You are on the right track IMO. I will get the Avon when my B.S. is done.
  14. #34
    Jun 2014
    Any more "experience" with the Avon Trike front tire would be appreciated.
  15. #35
    Tx
    Default STATES: COBRA TRIKE on the tire....
    Just make sure you are buying the correct tire for a TRIKE.. this WILL be a Radial Tire #90000020646 (Do Not Mount Reverse)
    I have no experience with this tire yet but will change to it next time if everyone claims show good results....
    Avon Front Cobra Trike AV71 130/70R-18 Blackwall Tire - 90000020646
    Overview of Avon Front Cobra Trike AV71 130/70R-18 Blackwall Tire - 90000020646
    Specially designed for Trikes, the new Avon Cobra Trike is the perfect choice for this increasingly popular, easy to handle, three-wheel motorcycle option. Made with the exceptional technology that has gone into the development of the other Cobra products in the line, the new Cobra Trike tire offers a flatter lean profile for longer wear, better handling and stability.
    • Advanced Variable Belt Density (A-VBD) construction uses a densely wrapped belt in the center of the tire for stability, wear and mileage
    • Belt is less dense on shoulder for a huge, compliant contact patch
    • Lifetime Profile Engineering (LPE) for consistent handling and stability for the life of the tire
    • Enhanced Aqua Flow (EAF) tread pattern for optimal water dispersal
    • Enhanced Stability System (ESS) design reduces tire flex for improved grip and stability
  16. #36
    Tx
    Default No Changes I see...
    This is from the AVON NORTH AMERICA site and I see only (2) two changes and that is the addition of Free Road Hazard Warranty and adding 15,000 miles Mileage warranty... Tire numbers are all the same.... Make sure to copy this for warranty situations.. Here's a copy and paste....:
    Cobra Trike
    Style and performance for cruisers, customs and tourers
    • Road Hazard Warranty included
    • 15,000 Mile Warranty included
    • Specifically designed for the GL1800 front trike
    • Flatter profile to resist the scrubbing off effect normally seen on front tires
    • Bigger blocks of rubber to resist irregular wear
    • Sidewall has “Trike” emblazoned on it to differentiate from regular motorcycle tires
    • Special construction to deal with heavy loads
    Cobra Trike Front
    AV Model
    Tire Size
    Service Index
    Rec Rim
    Rim Min-Max
    OW mm
    OW Inches
    OD mm
    OD Inches
    Depth mm
    Revs per km
    Revs per Mile
    Shop Now!
    90000020646
    AV71
    130/70R18
    63V
    MT3.50
    3.50 - 4.00
    127
    5.00
    648
    25.5
    4.5
    505
    813
  17. #37
    40+ Posts
    Apr 2016
    Fort Madison, Iowa, USA
    Quote Originally Posted by Solidbob View Post
    Solidbob, I just triked a "98 Valkyrie that had recently new tires. The front tire is a Dunlap 150/80/R17 72H. There is a 6 degree raked tree on it. I have pushed the trike pretty hard through a couple of corners. At least what I felt was hard . I get what you are saying about leaning a bike vs driving a trike through the corners, so, the questions is, until such time that the front tire needs replaced how agressive should I be in the corners?
    Or, would it be best to lay back a little?
    Also, it appears that when it is time to replace the front rubber it will have to be bias ply. Should they run in a certain direction?
  18. #38
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    Smile
    I also have Valkyrie Trike.
    I use a Dunlop 404 130/90-17 bias rear on the front in a reverse rotation.
    It has 16,400 on so far, and it still passes the “Penny Test”.
  19. #39
    Jul 2016
    Redfield, Arkansas USA
    Default Front tire throws off the speedo
    I have a 2000 Valkyrie I/S with a Motor Trike kit on it. It has a MPA 150/70/17 rear tire on the front, and it throws my speedometer off by 4-5 miles. Is there anything I can do to get closer to the correct speed. Right now, when I am showing 70 on the speedometer, I am actually only doing about 65-66(according to my gps).
  20. #40
    600+ Posts keepinon's Avatar
    Dec 2011
    New Caney, Tx
    Quote Originally Posted by Mike in Ar View Post
    I've owned (& ridden for myself) a '97 Tourer & a '98 Triked Standard. I also re-habbed (bought/repaired/sold) four others. Every one of them had the same speedometer discrepancy. Even when dark-sided, I never went short enough on the tire to make much difference.
    I just had to learn to ride, figuring in the 5 mph fast reading.
  1. Tire Pressure Thread
    By WEB in forum Tires, Wheels, Brakes, Front End
    Last Post: 06-17-2014, 08:42 AM
  2. 07 Venture / Hannigan Trike options questions.
    By Craigatcsi in forum Yamaha Trikes
    Last Post: 03-30-2014, 06:38 PM
  3. Answers to Trike Questions from "Those People".....
    Last Post: 12-17-2012, 04:05 PM
  4. Front Tire questions
    By SJR in forum Harley Trike Conversions
    Last Post: 06-18-2011, 11:21 AM
