Results 1 to 3 of 3
Thread: Tow-Pac Alignment & Darkside Tires
    50+ Posts sgmdudley's Avatar
    Longmont, Colorado
    Default Tow-Pac Alignment & Darkside Tires
    I had a 2009 GL1800 with Tow-Pac for 17,600 miles. Most of the time I was running a Darkside tire (Kumho run-flat). Biggest problem was getting the TP wheels aligned with the main wheel.
    I found two pieces of angle iron, predrilled that were just right. Put bolts/washers/nuts just snug to hold the angle iron to the rear wheel. Used 2x6 blocks to hold them up. I was then able to measure from the center of the TP tire to the angle iron. Compared measurements from the front side to the backside and adjusted for a slight toe-in per
    the instructions. See photos. Also Fender Lights I installed for Brake Lite/Running Lites/Turn Signals.
    Robert Dudley
    Longmont, Colorado
    2017 Lvl3/Motortrike
    300+ Posts dadztoy's Avatar
    Dec 2011
    Georgetown, Tennessee, USA
    Default Re: Tow-Pac Alignment & Darkside Tires
    Quote Originally Posted by sgmdudley View Post
    Great idea Robert - I may use that next time I adjust my TP tires... I'm about to try a Yokohama Avid Envigor on mine... Probably have a bit over 2K miles on mine new and really loving it... I bought the Yoko used from a guy complete with TPMS rim and sensor... The tire has only about 2K miles left on it but it will be enough to see if I like it...
    Can you give me your thoughts on going darkside over MC tire with the Tow Pac???
    My lights on the TP are LED and I use the red one for both running and brake using a few isolation diodes and a resistor - works well...
Size:  43.9 KB Name:  rsz_dscn1798.jpg
    Les
    250+ Posts wehrme's Avatar
    May 2014
    Decatur, IL
    Smile Re: Tow-Pac Alignment & Darkside Tires
    ...and that was a fine looking Tow-Pac unit.
  1. Anyone running Darkside with a Tow Pac?
    By dadztoy in forum Outrigger Style Trikes
    Last Post: 10-12-2014, 10:34 PM
  2. Belt alignment problem w/Frankenstein rear
    By buster in forum Harley Trike Conversions
    Last Post: 08-05-2011, 09:20 AM
  3. Darkside
    By azwiz in forum General Discussion
    Last Post: 12-31-2010, 02:11 PM
  4. Alignment of a sidecar
    By cjmitch in forum Honda Trikes
    Last Post: 09-09-2009, 10:26 PM
